    MM won't launch at startup, but will launch manually
    13 Posts 3 Posters 4.4k Views 3 Watching
    • A
      ajgonzales
      I installed MM via sdetweil’s script on Ubuntu 24.04. Everything seems to work fine after installation, but after a reboot MM doesn’t start up. Checking the pm2 logs shows these errors, and then it just keeps looping.
      [35781:0511/163537.061675:ERROR:ozone_platform_x11.cc(244)] Missing X server or $DISPLAY
      [35781:0511/163537.061869:ERROR:env.cc(257)] The platform failed to initialize.  Exiting.
      Authorization required, but no authorization protocol specified
      I can run MM successfully using
      npm start
      from the MagicMirror folder. Any ideas on how I can get it to run at startup?
      • majsoftM
        majsoft
        Hi, this is how I’m running it for now, maybe it will help someone.
        I will install PM2 according to the instructions
        I will skip the command “pm2 startup”
        After installation i proceed like this
        i will create another boot file
        cd ~
        nano mm_start.sh
        Add the following lines:
        echo Start PM2......
        pm2 start mm.sh
        read;
        set permissions
        chmod +x mm_start.sh
        we will set up the script after booting Ubuntu
        now i can start and stop services at will.
          sdetweil @ajgonzales
          @ajgonzales what user were you logged on as when you can my script?
          can u try to run the fixuppm2 script? last one on the list of my scripts…
          as a user, not root
            @ajgonzales said in MM won't launch at startup, but will launch manually:
            is 24.04 using wayland instead of x11??
            do
            ps -ef | grep -i way
            is a terminal window
            S A 2 Replies Last reply Reply Quote 0
              @ajgonzales I am downloading 24.04 now to test in vm…
              • A
                ajgonzales @sdetweil
                was logged in as a user, not root. got the same errors after running the fixuppm2 script and rebooting. here are the results from the other command. looks like it does use wayland:
                aj          2524    2226  0 16:06 tty2     00:00:00 /usr/libexec/gdm-wayland-session env GNOME_SHELL_SESSION_MODE=ubuntu /usr/bin/gnome-session --session=ubuntu
                aj          2938    2674  0 16:06 ?        00:00:03 /usr/bin/Xwayland :0 -rootless -noreset -accessx -core -auth /run/user/1000/.mutter-Xwaylandauth.QXB9M2 -listenfd 4 -listenfd 5 -displayfd 6 -initfd 7 -byteswappedclients
                aj        393102  390657  0 19:44 pts/0    00:00:00 grep --color=auto -i way
                  @ajgonzales ok thanks.
                    @ajgonzales yep, I can recreate this… so far no hack fix has helped…
                    I now have my system where it won’t finish booting… pm2 is uninstalled…
                    so something is different between UBUNTU and RASPI OS
                    cause we don’t see this problem on raspi
                    • A
                      ajgonzales
                      In case anyone else has this issue, I was able to able to get it to run via pm2 by running this command first:
                      xhost +si:localuser:[username]
                      Next steps are to figure out how to automatically run that command at startup prior to MM.
                        @ajgonzales add that to the launch script
                        you can find that by doing
                        pm2 status
                        then use the name or number of the row of the app
                        pm2 info x
                        where x is the name or number
                        can you give more info on the system?
                        lsb_release -a
                        uname -a
                        • A
                          I did try adding the command to the first line of the mm.sh script in the installers folder but that didn’t work. Here’s the sequence I run after rebooting, after which I have no issues.
                          pm2 stop 0
                          pm2 start 0
                          Here’s the output from those other two commands:
                          lsb_release -a
                          No LSB modules are available.
                          Distributor ID: Ubuntu
                          Description:    Ubuntu 24.04 LTS
                          Release:        24.04
                          Codename:       noble
                          uname -a
                          Linux [computername] 6.8.0-31-generic #31-Ubuntu SMP PREEMPT_DYNAMIC Sat Apr 20 00:40:06 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
                            @ajgonzales yeh 24.04
                            pm2 has an issue on 24.04 during boot up. I opened an issue a couple weeks ago.
                            https://github.com/Unitech/pm2/issues/5820
                            I think you are also running the new Wayland display manager…
                            to verify
                            ps -ef | grep wayfire
                            so x11 commands won’t work
                            • majsoftM
                              majsoft
                              cd ~
                              nano mm_start.sh
                              pm2 start mm.sh
                              read;
                              set permissions
                                sdetweil @majsoft
                                @majsoft cool. don’t know if we have that on other systems
                                sometimes if you do
                                sudo npm remove pm2 -g
                                then reboot and run the fixuppm2 script in my scripts list
