    MM won't start after upgrading to 2.29.0
    15 Posts 2 Posters 2.5k Views 3 Watching
      JohnGalt
      @sdetweil and others – I ran Sam Detweil’s update script. Trial mode didn’t show anything worrying, so I re-ran it and applied the changes. I was running pm2 logs in another terminal window and saw it stall…
      I’ve rebooted the machine, and it is stuck in a loop now. What looks like the relevant section of the logs is pasted below. This repeats over and over…
      @sdetweil - I sent you the upgrade log by email.
      0|MagicMirror  | [2024-10-29 15:16:06.807] [LOG]   Starting node helper for: newsfeed
      0|MagicMirror  | [2024-10-29 15:16:06.807] [LOG]   Connecting socket for: MMM-DynamicWeather
      0|MagicMirror  | [2024-10-29 15:16:06.808] [LOG]   Sockets connected & modules started ...
      0|MagicMirror  | Authorization required, but no authorization protocol specified
      0|MagicMirror  | [123146:1029/151606.810294:ERROR:ozone_platform_x11.cc(245)] Missing X server or $DISPLAY
      0|MagicMirror  | [123146:1029/151606.810429:ERROR:env.cc(258)] The platform failed to initialize.  Exiting.
      0|MagicMirror  | /home/al/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
      PM2            | App [MagicMirror:0] exited with code [1] via signal [SIGINT]
      PM2            | App [MagicMirror:0] starting in -fork mode-
      PM2            | App [MagicMirror:0] online
      0|MagicMirror  | > magicmirror@2.29.0 start
      0|MagicMirror  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      0|MagicMirror  | [2024-10-29 15:16:13.638] [LOG]   Starting MagicMirror: v2.29.0
      0|MagicMirror  | [2024-10-29 15:16:13.664] [LOG]   Loading config ...
      0|MagicMirror  | [2024-10-29 15:16:13.666] [LOG]   config template file not exists, no envsubst
      0|MagicMirror  | [2024-10-29 15:16:14.116] [INFO]  Checking config file /home/al/MagicMirror/config/config.js ...
      0|MagicMirror  | [2024-10-29 15:16:14.230] [INFO]  Your configuration file doesn't contain syntax errors :)
      0|MagicMirror  | [2024-10-29 15:16:14.231] [INFO]  Checking modules structure configuration ...
      0|MagicMirror  | [2024-10-29 15:16:14.329] [INFO]  Your modules structure configuration doesn't contain errors :)
      0|MagicMirror  | [2024-10-29 15:16:14.331] [LOG]   Loading module helpers ...
      0|MagicMirro
        sdetweil @JohnGalt
        @JohnGalt can you show me more of the output? after starting Application,
        there is a dump of system data
        like this
        2024-10-29 17:55:20.819] [INFO]  System information:
        ### SYSTEM:   manufacturer: ; model: ; virtual: false
        ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
        ### VERSIONS: electron: 31.7.3; used node: 20.18.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
        ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
        S J 3 Replies Last reply Reply Quote 0
          @JohnGalt this is a pm2 problem…
          SOMEtimes we can fix it like this
          pm2 stop all
          pm2 delete MagicMirror
          pm2 save -f
          sudo npm remove pm2 -g                     # I edited a typo here
          then run my fixuppm2.sh script
          (same place as my install script, near the bottom of the page
            JohnGalt @sdetweil
            @sdetweil – I can do that. Would you want it here or email?
              JohnGalt @sdetweil
              @sdetweil – I sent you an email with extended pm2 logs output.
                sdetweil @JohnGalt
                @JohnGalt did you do this
                https://forum.magicmirror.builders/topic/19089/mm-won-t-start-after-upgrading-to-2-29-0
                  JohnGalt @sdetweil
                  @sdetweil – I wasn’t sure you [still] wanted me to do that before you had a chance to see the extended pm2 logs outputs. I will do it now and get back to you.
                    sdetweil @JohnGalt
                    @JohnGalt the log show me the wayland/pm2 confusion
                    i opened a pm2 issue about this back in the early spring
                      JohnGalt @sdetweil
                      @sdetweil – I did the pm2 work you asked for, and still have the same results.
                      As this is a dev instance it’s not as critical as it might be for the regular [production] instance we use to get actual information. Am I better off just re-installing Magic Mirror from scratch on this machine?
                        sdetweil @JohnGalt
                        @JohnGalt its not MagicMirror its pm2 talking to the display manager
                        you could use raspi-config to set the display manager back to x11
                        without doing anything else
