    MM won't start after upgrading to 2.29.0
    15 Posts 2 Posters 2.1k Views 3 Watching
      JohnGalt @sdetweil
      @sdetweil – I can do that. Would you want it here or email?
        JohnGalt @sdetweil
        @sdetweil – I sent you an email with extended pm2 logs output.
          sdetweil @JohnGalt
          @JohnGalt did you do this
          https://forum.magicmirror.builders/topic/19089/mm-won-t-start-after-upgrading-to-2-29-0
            JohnGalt @sdetweil
            @sdetweil – I wasn’t sure you [still] wanted me to do that before you had a chance to see the extended pm2 logs outputs. I will do it now and get back to you.
              sdetweil @JohnGalt
              @JohnGalt the log show me the wayland/pm2 confusion
              i opened a pm2 issue about this back in the early spring
                JohnGalt @sdetweil
                @sdetweil – I did the pm2 work you asked for, and still have the same results.
                As this is a dev instance it’s not as critical as it might be for the regular [production] instance we use to get actual information. Am I better off just re-installing Magic Mirror from scratch on this machine?
                  sdetweil @JohnGalt
                  @JohnGalt its not MagicMirror its pm2 talking to the display manager
                  you could use raspi-config to set the display manager back to x11
                  without doing anything else
                    JohnGalt @sdetweil
                    @sdetweil – Humm, I see what you mean. unfortunately this isn’t running on an actual Raspberry Pi so I don’t have that utility available to me.
                    It’s a VM running Ubuntu 23.10. If you can point me in the right direction, I’d be willing to give it a shot.
                      sdetweil @JohnGalt
                      @JohnGalt ok, dont know how to fix that
                        JohnGalt @sdetweil
                        @sdetweil – OK, thanks for the effort!
