MMM-OpenWeatherForecast - loading issue
I am also having issues with the module being stuck on loading. In looking at the the debugging (ctrl+shift+i) when magic mirror is up I do get a 404 error for communicating to openweather. I have not changed any settings and do not have a line in my config file with the api base url. Other than that, I’m in the same boat as OP where I signed up to get the free API 3.0 and generated a new key… just can’t get anything working.
@Como 3.0 apikey requires a credit card. today first 1000 api calls are not charged
@Como 404 is not found, so the api url is incorrect
@Como openweather changed their business model, only the 3.0 api is available. any 2.5 api requests will fail
I realize that the api 3.0 is required. I mentioned I signed up for it as seen below.
I also generated a new key which is showing as active. So unless I’m generating keys that are no longer allowed per openweather (which I wouldn’t think is possible), then I’m not sure what the problem is. -
@Como yes, as i said, i will debug this when i get nack to my desk on monday
as for my reiteration of the v3.0 api, you said ‘free api’ , and there is no such thing anymore. just trying yo be precise
Got it. Just wanted to make sure I was understanding too as I feel the oneweathermap site could be a little more clear on their keys. Thanks for all your hard work on this!
Side note: If you are having problems with MMM-OpenWeatherForecast, make sure you are using Tom Hirschberger’s active fork. You can check this by running
git remote -vin the module’s directory. -
@KristjanESPERANTO @Como
rather than spend any time on thisrename your existing module out of the way and install
https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecastno config changes I don’t think… (maybe lat/lon for location/locationID)
Tom is very active in supporting his work… -
@Como did you get this resolved?
