    MMM-OpenWeatherForecast - loading issue
    23 Posts 7 Posters 6.5k Views 8 Watching
    • zdenekZ
      zdenek
      Dears
      I tried to find simple way to solve the problem, but Search returns tons of posts and I’ve no clue, whichone is the correct. I know, that there is change in API, so - what I’ve did:
      1. 6effca4c-ce2b-4b11-8e9e-0539450a749a-image.png so new API associated with card
      2.  	    module: "MMM-OpenWeatherForecast",
         	    //header: "Forecast",
         	      apiBaseURL: "https://api.openweathermap.org/data/3.0/onecall?",
         	      apikey: "api_key", //Home_MM Api
         	      latitude: 50.757690,            //number works here
         	      longitude: 15.033640,          //so does a string
         	      iconset: "5c",
         	      language: "cz",
         	      colored: true,
         	      concise: true,
         	      weatherEndpoint: '/onecall',
         	      apiVersion: '3.0',
         	      //requestDelay: "2000",
         	      showFeelsLikeTemp: true
      3) I've generated new key
      ![eb8e0e31-2dcd-4dda-bab8-c93965680d9b-image.png](/assets/uploads/files/1730533193487-eb8e0e31-2dcd-4dda-bab8-c93965680d9b-image.png)
      but MM just "loading" ![f5f2757a-3384-468c-9fc8-e48f897fa4bc-image.png](/assets/uploads/files/1730533324100-f5f2757a-3384-468c-9fc8-e48f897fa4bc-image.png)
      questions:
      do you see any error in Code?
      How do I find, if the new key is 3.0 or old (in the list of keys)?
      Thanks and sorry fo english
      Z
      zdenekZ S 2 Replies Last reply Reply Quote 0
        jms3700 Project Sponsor
        I had to change the node_helper.js to call the right api moet in node_helper.js (3.0 instead of 2.5)
        sudo nano node_helper.js
            //make request to OpenWeather One Call API
        // var url = “https://api.openweathermap.org/data/2.5/onecall?” +
        var url = “https://api.openweathermap.org/data/3.0/onecall?” +
        This solution works for me
        • zdenekZ
          zdenek @zdenek
          hmm, some pics doesn’t upload, so “loading” 37d738f9-4c86-4672-8e57-0e1612f09354-image.png
            sdetweil @zdenek
            @zdenek take off the apiBase, let us handle that
            zdenekZ 1 Reply Last reply Reply Quote 0
            • zdenekZ
              zdenek @sdetweil
              @sdetweil done, but nothing changed - still “loading”
              • Z
                zauberclown
                I am facing the exact same challenge.
                Also followed the guidance as you did.
                So, you are not alone…which makes me think if there might be an issue on openweathermap since everbody is hammering their API with their tests this weekend?
                  Como
                  I am also having issues with the module being stuck on loading. In looking at the the debugging (ctrl+shift+i) when magic mirror is up I do get a 404 error for communicating to openweather. I have not changed any settings and do not have a line in my config file with the api base url. Other than that, I’m in the same boat as OP where I signed up to get the free API 3.0 and generated a new key… just can’t get anything working.
                  S 3 Replies Last reply Reply Quote 0
                    sdetweil @Como
                    @Como 3.0 apikey requires a credit card. today first 1000 api calls are not charged
                      sdetweil @Como
                      @Como 404 is not found, so the api url is incorrect
                        sdetweil @Como
                        @Como openweather changed their business model, only the 3.0 api is available. any 2.5 api requests will fail
                          Como
                          I realize that the api 3.0 is required. I mentioned I signed up for it as seen below. f90f3419-0d5e-429b-818e-eea6b4d8fd20-image.png
                          I also generated a new key which is showing as active. So unless I’m generating keys that are no longer allowed per openweather (which I wouldn’t think is possible), then I’m not sure what the problem is.
                            sdetweil @Como
                            @Como yes, as i said, i will debug this when i get nack to my desk on monday
                            as for my reiteration of the v3.0 api, you said ‘free api’ , and there is no such thing anymore. just trying yo be precise
                              Como
                              Got it. Just wanted to make sure I was understanding too as I feel the oneweathermap site could be a little more clear on their keys. Thanks for all your hard work on this!
                              • KristjanESPERANTOK
                                KristjanESPERANTO Module Developer @Como
                                Side note: If you are having problems with MMM-OpenWeatherForecast, make sure you are using Tom Hirschberger’s active fork. You can check this by running git remote -v in the module’s directory.
                                  sdetweil @KristjanESPERANTO
                                  @KristjanESPERANTO @Como
                                  rather than spend any time on this
                                  rename your existing module out of the way and install
                                  https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast
                                  no config changes I don’t think… (maybe lat/lon for location/locationID)
                                  Tom is very active in supporting his work…
                                  S E 2 Replies Last reply Reply Quote 0
                                    @Como did you get this resolved?
                                      Como @sdetweil
                                      @sdetweil life has been busy. Hopefully I can do it this weekend. I’ll report afterward.
                                          sdetweil @jms3700
                                          @jms3700 never use sudo for MagicMirror things
                                            jms3700 Project Sponsor @sdetweil
                                            Hello Sam,
                                            Indeed, I was wrong to use sudo. Thanks for the reminder!
                                            Jean-Marie
                                            • zdenekZ
                                              zdenek
                                              Hi all
                                              maybe I’ve missed something, but did someone find the solution? If so, can describe setp-by-step how to do it?
                                              thanks
