    MMM-OpenWeatherForecast - loading issue
    23 Posts 7 Posters 6.3k Views 8 Watching
      Como
      I realize that the api 3.0 is required. I mentioned I signed up for it as seen below. f90f3419-0d5e-429b-818e-eea6b4d8fd20-image.png
      I also generated a new key which is showing as active. So unless I’m generating keys that are no longer allowed per openweather (which I wouldn’t think is possible), then I’m not sure what the problem is.
        sdetweil @Como
        @Como yes, as i said, i will debug this when i get nack to my desk on monday
        as for my reiteration of the v3.0 api, you said ‘free api’ , and there is no such thing anymore. just trying yo be precise
          Como
          Got it. Just wanted to make sure I was understanding too as I feel the oneweathermap site could be a little more clear on their keys. Thanks for all your hard work on this!
          • KristjanESPERANTOK Offline
            KristjanESPERANTO Module Developer @Como
            Side note: If you are having problems with MMM-OpenWeatherForecast, make sure you are using Tom Hirschberger’s active fork. You can check this by running git remote -v in the module’s directory.
              sdetweil @KristjanESPERANTO
              @KristjanESPERANTO @Como
              rather than spend any time on this
              rename your existing module out of the way and install
              https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast
              no config changes I don’t think… (maybe lat/lon for location/locationID)
              Tom is very active in supporting his work…
              S E 2 Replies Last reply Reply Quote 0
                @Como did you get this resolved?
                  Como @sdetweil
                  @sdetweil life has been busy. Hopefully I can do it this weekend. I’ll report afterward.
                    jms3700 Project Sponsor
                    I had to change the node_helper.js to call the right api moet in node_helper.js (3.0 instead of 2.5)
                    sudo nano node_helper.js
                        //make request to OpenWeather One Call API
                    // var url = “https://api.openweathermap.org/data/2.5/onecall?” +
                    var url = “https://api.openweathermap.org/data/3.0/onecall?” +
                    This solution works for me
                      sdetweil @jms3700
                      @jms3700 never use sudo for MagicMirror things
                        jms3700 Project Sponsor @sdetweil
                        Hello Sam,
                        Indeed, I was wrong to use sudo. Thanks for the reminder!
                        Jean-Marie
                        • zdenekZ Offline
                          zdenek
                          Hi all
                          maybe I’ve missed something, but did someone find the solution? If so, can describe setp-by-step how to do it?
                          thanks
                            sdetweil @zdenek
                            @zdenek see https://forum.magicmirror.builders/post/121026
                            • E Offline
                              el_georgie @sdetweil
                              @sdetweil I tried that and the module just keep loading…I even tried the default weather and other modules and same, keeps loading. I was using it for years and no issue. Perhaps something with the API?
                                sdetweil @el_georgie
                                @el_georgie did you get a new api key?? 3.0 requires a credit card, only 3.0 available now
