    MMM-OpenmapWeather - Weather still loading
    13 Posts 5 Posters 2.4k Views 6 Watching
      Doppellhelix
      Hello everyone,
      I’m just taking my first steps with MagicMirror and modules.
      Unfortunately, I have a problem with the module.
      The module is loaded in Magic Mirror, but unfortunately the weather is not. It simply says under Forecast: Loading or resp. Laden in German
      I have tried several API keys. I have entered my place of residence, the location id, I have even tried the original configuration from the example with Phoenix, USA. But no weather is loaded.
      I have also changed the apiVersion to 3.0, but then the module does not load when I specify the apiVersion parameter.
      Does anyone have an idea?
      Thanks for the help
      Translated with DeepL.com (free version)
        sdetweil @chris1971
        @chris1971 because this module is written for the older 2.5 api, it will take some changes to make it work.
        I might suggest another module to use instead
        open the 3rd party module list linked above in the menu
        and put openweather in the search field.
          sdetweil @Doppellhelix
          @Doppellhelix the module hasn’t been updated in 3 years . it is still using the old soiverdion.
          Openweather changed their business model this year
          all new api calls require a new apikey, backed by a credit card. they give 1000 calls per day uncharged.
          then the code needs to be changed or new parameters need to be supplied
          this module supposedly has parameters
          you need to set apiVersion to 3.0 and endpoint to onecall
          D C 2 Replies Last reply Reply Quote 0
            Doppellhelix @sdetweil
            Many thanks for the quick reply.
            Unfortunately, openweather seems to be a bit overloaded at the moment.
            I will stay tuned :-)
            C S 2 Replies Last reply Reply Quote 0
              chris1971 @Doppellhelix
              @Doppellhelix : Have you found a solution? I have similar issues…
                seramik
                same in my home
                so i install a new module with new provider
                https://github.com/gonzonia/MMM-BMW-PW
                  @Doppellhelix did you change your config as i suggested? AND get the apikey
                    MyMirror @sdetweil
                    Maybe they have already switched off version 2.5. Weekend … ??
                    Excerpt from an email from Open weather:
                    ”We would like to inform you that we started One Call 2.5 deprecation, and your access to the product will be stopped on November 4, 2024. We would like to inform you that we started One Call 2.5 deprecation, and your access to the product will be stopped on November 4, 2024."
                    BR
                    Jens
                      chris1971 @sdetweil
                      @sdetweil Do you have a description what to do to run MMM-OpenmapWeather in future? I am not an expert in working with the modules and was happy to have a running system… ;-)
                      Thanks, Chris
                        sdetweil @chris1971
                        @chris1971 i will look at it next week when back home
                          chris1971 @sdetweil
                          @sdetweil Thanks for the great support!!!
