    Multiple "Mirrors" from a single device
    Scheduled Pinned Locked Moved Solved General Discussion
    20 Posts 3 Posters 4.7k Views 4 Watching
      sdetweil @DarrenO 0
      @DarrenO-0 in Windows when you want an app to run when started from the command prompt you do
      detach command…
      in linux you add and & as the last character
      comand… &
      now… STOPPING those detached/background things are tough…
      here is one value for pm2… it EXPECTS the script to block
      and so you can kill it thru pm2 stop xxxx
      BUT
      pm2’s JOB is to start and app AND KEEP IT RUNNING…
      so you kill it (ctrl-q) or it fails, pm2 will restart it
      SO, if you want both to run and want to do it manually, open a second ssh session
      until you are happy and then let pm2 run them both
      D 1 Reply Last reply
        DarrenO 0 @sdetweil
        OK, so I launched the second instance of MM via mm2.sh with the “npm run server” command.
        I then launched a second SSH session to the MM device and issued a “pm2 save” command.
        Rebooted the MM device from the second SSH session but the second MM instance didn’t come up.
          DarrenO 0 @BKeyport
          @BKeyport
          isn’t this to run two MM’s on a single display and have the second MM displayed from the 1920th pixel on the x axis?
          I’m wanting to run two MM’s, each instance on isolated displays - one on the display connected to the host in the traditional method and the other on a remote display like another computer, or TV with an in-built browser.
          S BKeyportB 3 Replies Last reply
            sdetweil @DarrenO 0
            @DarrenO-0 and what does the status say?
            pm2 status
            pm2 logs 1 (or whatever the number is of the line for the second ) --lines=xxxx
            where xxxx is the number of the most recent lines in the log for that app
            I have lots of apps on my desktop pm2
            pm2 status output
            | id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
            │ 1  │ MagicMirror        │ fork     │ 27   │ stopped   │ 0%       │ 0b       │
            │ 7  │ MagicMirror1       │ fork     │ 279… │ stopped   │ 0%       │ 0b       │
            │ 0  │ Smart Mirror       │ fork     │ 31   │ stopped   │ 0%       │ 0b       │
            │ 3  │ checkarec          │ fork     │ 0    │ online    │ 0%       │ 3.5mb    │
            │ 6  │ smart-mirror       │ fork     │ 9    │ online    │ 0%       │ 3.5mb    │
            │ 5  │ smart-mirror ttt   │ fork     │ 10   │ stopped   │ 0%       │ 0b       │
            │ 4  │ start_alexa_bk     │ fork     │ 0    │ online    │ 0%       │ 3.5mb    │
            │ 2  │ startspot          │ fork     │ 328  │ stopped   │ 0%       │ 0b       │
            the count under the circle coloum is restarts of that app
              sdetweil @DarrenO 0
              @DarrenO-0 the server side still provides access regardless of where the local display output is configured
              AND if you run server mode, then the config for the local electron isn’t used
                sdetweil @DarrenO 0
                @DarrenO-0 said in Multiple "Mirrors" from a single device:
                just heads up…
                we use the latest Javascript language options
                most/many/all TV’s do NOT have this browser version available and cannot be upgraded.
                so the MM screen will be black (browser crashed)
                when I got here in 2017, I could run MM on my Samsung TV browser
                not anymore
                  DarrenO 0 @sdetweil
                  after running the mm2.sh script (runs as “npm run server”) and then I initiate a new SSH to the MM, I still only see a single instance (the original instance from mm.sh) of MM running when I issue a pm2 status command.
                  Although I can physically see the second MM displayed as desired in my browser, I’m not seeing the second instance via the pm2 status command.
                    DarrenO 0 @sdetweil
                    Fair enough.
                    So i’ll have to have a physical computer like a Pi, NUC or MiniPC attached to the TV via HDMI to display the MM via that computer’s browser.
                    Not a big deal as the TV would be used for viewing TV channels and online streaming content anyway.
                      sdetweil @DarrenO 0
                      @DarrenO-0 how did you add it to pm2 . just doing mm2.sh doesn’t
                      pm2 start xxxx
                      xxx is the mm2.sh
                      or the MagicMirror2.json
                      it should run and you should see with status
                      then pm2 save so that it will be saved to the bootup start list
                        DarrenO 0 @sdetweil
                        yeah, I started it via the mm2.sh script that had the “npm run server” command
                        I’ve now started the second instance as “pm2 start pm2_MagicMirror2_new.json” and “pm2 status” does show both instances running.
                        Ran “pm2 save”, rebooted the host and both instances are showing as expected - MM#1 on the display connected to the host device, with MM#1 and MM#2 via a browser on a remote device/devices.
                          sdetweil @DarrenO 0
                          @DarrenO-0 awesome!!..
                          now select which post is the one that you think ‘solved’ this
                          hit the 3 dots (bottom right of the post) and click on Mark this post as the correct answer
                          • D DarrenO 0 has marked this topic as solved on
                          • BKeyportB
                            BKeyport Module Developer @DarrenO 0
                            @DarrenO-0 Ahh, gotcha. Yes, this is for two on the same system, which linux treats as one huge monitor.
