    MMM-NewsAPI
    103 Posts 10 Posters 90.5k Views 8 Watching
    • U
      ufransa
      Hi all, setting up this amazing module but it seems to not work for me and I have no idea why. I tried already:
      • Test api on postman. It works perfectly
      • Check on the console. Nothing seems to be wrong
      • Delete all modules except this one. Nothing changes
      I´m also using it on an vertical screen but I don´t thing the type can make any changes to it. Tried already and nothing.
      This is my config at the moment.
      			module: "MMM-NewsAPI",
      			header: "news",
      			position: "bottom_bar",
      			pages: { "sport": "bottom_bar" },
      				apiKey: "MYAPIKEY",
      				type: "horizontal",
      				choice: "everything",
      				pageSize: 20,
      				sortBy: "publishedAt",
      				drawInterval: 1000 * 30,
      				templateFile: "template.html",
      				fetchInterval: 1000 * 60 * 60,
      				query: {
      					country: "",
      					category: "",
      					q: "",
      					qInTitle: "",
      					sources: "",
      					domains: "bbc.co.uk",
      					excludeDomains: "",
      					language: ""
      Thanks for the help !!
      • mumblebajM
        mumblebaj Module Developer
        Hi. What is the below config for?
        @ufransa said in MMM-NewsAPI:
        pages: { “sport”: “bottom_bar” },
          sdetweil @mumblebaj
          @mumblebaj I think he was doing MMM-pages but got the name wrong, should be classes:
          mumblebajM 2 Replies Last reply Reply Quote 0
          • mumblebajM
            @sdetweil Ah, got you.
            • mumblebajM
              @sdetweil I am assuming he is using your fork of MMM-pages and was probably trying to do the below.
                module:"MMM-NewsAPI",
                classes:"sport",
              If I remember the README from your fork it calls for page1 page2 etc. I kinda remember carousel has the type of config he was trying to implement but a little different.
              @ufransa can you confirm what you are trying to achieve or which module you using for page control?
                sdetweil @mumblebaj
                @mumblebaj said in MMM-NewsAPI:
                yes, the default pages and carousel use the module name in the ‘modules’ or ‘slides’ config. in the pages module this is really the module CLASSname (carousel can ONLY use module NAME in the ‘slides’ config )
                which puts all the config in the pages module, but makes it hard for multi-instance as module name doesn’t work there , so you HAVE to use classes to ADD something unique
                but when looking at config.js, you cant TELL what is where, you have to toggle back and forth between the text and the pages config… (I find this maddening)
                so, just add a name for the page name (page1, dad, mom, billy, sue, stocks, weather, whatever)
                and use that in the classes field on each appropriate module…
                then you can see it right there…
                oh, dad AND weather… easy
                oh, this is the calendar instance I created for billys schedule… easy,… add that to the classes field… done
                I just used page1, page2 as examples to distinguish the groupings of modules
                ------ mmm-carousel does this to look thru the modules
                modules = MM.getModules().exceptModule(this).filter(function (module) { // this looks thru modules, code uses module name
                ------ mmm-pages does this
                MM.getModules()
                .exceptWithClass(modulesToShow) // this filters modules by classname
                • U
                  ufransa
                  Hi ! Nono, I´m not using pages, it´s that another module I assume, right?
                  mumblebajM S 2 Replies Last reply Reply Quote 0
                  • mumblebajM
                    mumblebaj Module Developer @ufransa
                    @ufransa You will need to advise which other module you are using. I am assuming that the config you passing in may not be correct. When I run domains: "bbc.co.uk" it worked fine for me without that extra config. Can you confirm which other module you are using so I can check if you have specified that config setting correct.
                    U 1 Reply Last reply Reply Quote 0
                    • U
                      ufransa @mumblebaj
                      @mumblebaj Of course ! This is all my config file:
                      /* Config Sample
                       * see https://docs.magicmirror.builders/configuration/introduction.html
                       * and https://docs.magicmirror.builders/modules/configuration.html
                       * You can use environment variables using a `config.js.template` file instead of `config.js`
                       * which will be converted to `config.js` while starting. For more information
                       * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
                      let config = {
                      	address: "localhost",	// Address to listen on, can be:
                      	port: 8080,
                      	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
                      	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
                      	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
                      	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
                      	language: "es",
                      	locale: "es-ES",
                      	timeFormat: 24,
                      	units: "metric",
                      			module: "alert",
                      			module: "clock",
                      			position: "top_left"
                      				broadcastPastEvents: true,
                      						url: "calendar.ics",
                      						color: "orange"
                      						color: "green"
                      			module: "MMM-CustomElementTime"
                      			module: "MMM-CountEvents",
                      				/* Common default properties */
                      				locale: null,
                      				refresh: 1000 * 60,
                      				unit: "days",
                      				repeat: false,
                      				ignoreBefore: false,
                      				ignoreAfter: false,
                      				className: "default",
                      				output: `<dl><dt class="title"></dt><dd class="output"></dd></dl>`,
                      				numericAlways: false,
                      				reverse: false,
                      				numberOnly: false,
                      				numberSign: false,
                      				useQuarter: false,
                      				onPassed: null,
                      				onUpdated: null,
                      				events: [
                      						title: "the event",
                      						targetTime: "2025-07-12",
                      						ignoreAfter: 1000 * 60 * 60 * 24,
                      			module: "weather",
                      				weatherProvider: "openmeteo",
                      				type: "current",
                      				lat: 40.5290869,
                      				lon: -3.4765786
                      			module: "weather",
                      			header: "Weather Forecast",
                      				type: "forecast",
                      				lat: 40.5290869,
                      				lon: -3.4765786
                      			module: "MMM-CalendarExt3",
                      			title: "",
                      				mode: "month",
                      				instanceId: "basicCalendar",
                      				locale: 'es-ES',
                      				maxEventLines: 5,
                      				firstDayOfWeek: 1,
                      				// eventHeight: 22,
                      				fontSize: 50,
                      				calendarSet: ['ufransa', 'lupita'],
                      			header: "Noticias del mundo",
                      				apiKey: "APIKEY",
                      				type: "horizontal",
                      				pageSize: 20,
                      				query: {
                      					country: "",
                      					category: "",
                      					q: "",
                      					qInTitle: "",
                      					sources: "",
                      					domains: "",
                      					excludeDomains: "",
                      					language: "en"
                      • mumblebajM
                        @ufransa Ok, I don’t see anything in your config that would cause a problem. However, you do have both MMM-NewsAPI and MMM-calendarExt3 in the exact same position. I am thinking that MMM-CalendarExt3 may be pushing the module off the screen, they both cannot occupy the same space. Try using it in a different position and use the vertical option.
                          sdetweil @ufransa
                          @ufransa pages = MMM-pages
                          my fork which changes the readme for config
                          https://github.com/sdetweil/MMM-pages
                          • U
                            ufransa @mumblebaj
                            @mumblebaj It could be but after I change the position the result is the same, I can see the header tho but not the news and the API and everything works.
                            • mumblebajM
                              @ufransa Can you check if there are any errors? Check the Console Tab in the Developers Window and check in the pm2 logs if you using pm2 or the terminal if you starting MM with npm start
                              • 5 / 6
