    MMM-NewsAPI
    103 Posts 10 Posters 92.5k Views 8 Watching
    • mumblebajM
      mumblebaj Module Developer @dondula
      @dondula I have just tested MMM-NewsAPI with the config that you have and it works just fine.
      Config used:
      Your key seems to be working fine as well using MMM-NewsAPI.
        dondula @mumblebaj
        @mumblebaj
        See below
        disabled: false,
        classes: “hide”,
        module: “MMM-News”,
        position: “middle_center”,
        debug: false,
        apiKey: “”,// set your newsapi.org API Key
        type: “vertical”, // “horizontal”, “vertical” You can make your own type with CSS class selector.
        // See https://newsapi.org/sources for available query options('sources' or `country`, `category`).
        query : [
            sources: "the-verge",
            // A comma-seperated string of identifiers for the news sources or blogs you want headlines from.
            // Too many `sources` at once could make API error. If you want, split them to several queries.
            // `sources` are not able to be mixed with `country` and `category`.
        items: 20, // number of how many headlines to get from each query. max 100
        timeFormat: "relative", // Or You can use "YYYY-MM-DD HH:mm:ss" format.
        drawInterval: 1000*30, // How long time each article will be shown.
        scanInterval: 1000*60*30, // Delay before rescan news (limited to 100 query by day and 50 query for 12 hours)
        touchable: false, // When you have a touchable or clickable interface on your MM.
        templateFile: "template.html"
        mumblebajM 1 Reply Last reply
        • mumblebajM
          @dondula Just thinking out loud, there was a MMM-News which has been archived now I believe. I handed it back to the original author of the module. You can install MMM-NewsAPI if you like? Same config, just need to update the module name in the config.js from MMM-News to MMM-NewsAPI.
          D 1 Reply Last reply
            dondula @mumblebaj
            @mumblebaj
            I appreciate the suggestion, unfortunately someone else built this mirror for me and it has multiple pages of widgets that were preconfigured for me. So the config file is pretty complex and points to that old module in various config settings. When I try to update the name of the old module to the new one and reboot MM, it just goes to a black screen.
            Would you have any idea what the expired certificate error could mean in my previous log post? I’m just wondering if it’s something I can fix on my end to make the old module work again.
            If it’s not too much trouble could you post me a clean config for the new module with the settings from my current one applied? I’m sure some of these old settings are messing with your new module.
            Again I really appreciate your assistance on this.
            • mumblebajM
              @dondula Yeah, MMM-News was handed back to original author and archived. You should install MMM-NewsAPI and use that instead.
              • U
                ufransa
                Hi all, setting up this amazing module but it seems to not work for me and I have no idea why. I tried already:
                • Test api on postman. It works perfectly
                • Check on the console. Nothing seems to be wrong
                • Delete all modules except this one. Nothing changes
                I´m also using it on an vertical screen but I don´t thing the type can make any changes to it. Tried already and nothing.
                This is my config at the moment.
                			module: "MMM-NewsAPI",
                			header: "news",
                			position: "bottom_bar",
                			pages: { "sport": "bottom_bar" },
                				apiKey: "MYAPIKEY",
                				type: "horizontal",
                				choice: "everything",
                				pageSize: 20,
                				sortBy: "publishedAt",
                				drawInterval: 1000 * 30,
                				templateFile: "template.html",
                				fetchInterval: 1000 * 60 * 60,
                				query: {
                					country: "",
                					category: "",
                					q: "",
                					qInTitle: "",
                					sources: "",
                					domains: "bbc.co.uk",
                					excludeDomains: "",
                					language: ""
                Thanks for the help !!
                • mumblebajM
                  Hi. What is the below config for?
                  @ufransa said in MMM-NewsAPI:
                  pages: { “sport”: “bottom_bar” },
                    sdetweil @mumblebaj
                    @mumblebaj I think he was doing MMM-pages but got the name wrong, should be classes:
                    mumblebajM 2 Replies Last reply
                    • mumblebajM
                      @sdetweil Ah, got you.
                      • mumblebajM
                        @sdetweil I am assuming he is using your fork of MMM-pages and was probably trying to do the below.
                          module:"MMM-NewsAPI",
                          classes:"sport",
                        If I remember the README from your fork it calls for page1 page2 etc. I kinda remember carousel has the type of config he was trying to implement but a little different.
                        @ufransa can you confirm what you are trying to achieve or which module you using for page control?
                          sdetweil @mumblebaj
                          @mumblebaj said in MMM-NewsAPI:
                          yes, the default pages and carousel use the module name in the ‘modules’ or ‘slides’ config. in the pages module this is really the module CLASSname (carousel can ONLY use module NAME in the ‘slides’ config )
                          which puts all the config in the pages module, but makes it hard for multi-instance as module name doesn’t work there , so you HAVE to use classes to ADD something unique
                          but when looking at config.js, you cant TELL what is where, you have to toggle back and forth between the text and the pages config… (I find this maddening)
                          so, just add a name for the page name (page1, dad, mom, billy, sue, stocks, weather, whatever)
                          and use that in the classes field on each appropriate module…
                          then you can see it right there…
                          oh, dad AND weather… easy
                          oh, this is the calendar instance I created for billys schedule… easy,… add that to the classes field… done
                          I just used page1, page2 as examples to distinguish the groupings of modules
                          ------ mmm-carousel does this to look thru the modules
                          modules = MM.getModules().exceptModule(this).filter(function (module) { // this looks thru modules, code uses module name
                          ------ mmm-pages does this
                          MM.getModules()
                          .exceptWithClass(modulesToShow) // this filters modules by classname
                          • U
                            ufransa
                            Hi ! Nono, I´m not using pages, it´s that another module I assume, right?
                            mumblebajM S 2 Replies Last reply
                            • mumblebajM
                              mumblebaj Module Developer @ufransa
                              @ufransa You will need to advise which other module you are using. I am assuming that the config you passing in may not be correct. When I run domains: "bbc.co.uk" it worked fine for me without that extra config. Can you confirm which other module you are using so I can check if you have specified that config setting correct.
                              U 1 Reply Last reply
                              • U
                                ufransa @mumblebaj
                                @mumblebaj Of course ! This is all my config file:
                                /* Config Sample
                                 * see https://docs.magicmirror.builders/configuration/introduction.html
                                 * and https://docs.magicmirror.builders/modules/configuration.html
                                 * You can use environment variables using a `config.js.template` file instead of `config.js`
                                 * which will be converted to `config.js` while starting. For more information
                                 * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
                                let config = {
                                	address: "localhost",	// Address to listen on, can be:
                                	port: 8080,
                                	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                                	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
                                	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
                                	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
                                	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
                                	language: "es",
                                	locale: "es-ES",
                                	timeFormat: 24,
                                	units: "metric",
                                			module: "alert",
                                			module: "clock",
                                			position: "top_left"
                                				broadcastPastEvents: true,
                                						url: "calendar.ics",
                                						color: "orange"
                                						color: "green"
                                			module: "MMM-CustomElementTime"
                                			module: "MMM-CountEvents",
                                				/* Common default properties */
                                				locale: null,
                                				refresh: 1000 * 60,
                                				unit: "days",
                                				repeat: false,
                                				ignoreBefore: false,
                                				ignoreAfter: false,
                                				className: "default",
                                				output: `<dl><dt class="title"></dt><dd class="output"></dd></dl>`,
                                				numericAlways: false,
                                				reverse: false,
                                				numberOnly: false,
                                				numberSign: false,
                                				useQuarter: false,
                                				onPassed: null,
                                				onUpdated: null,
                                				events: [
                                						title: "the event",
                                						targetTime: "2025-07-12",
                                						ignoreAfter: 1000 * 60 * 60 * 24,
                                			module: "weather",
                                				weatherProvider: "openmeteo",
                                				type: "current",
                                				lat: 40.5290869,
                                				lon: -3.4765786
                                			module: "weather",
                                			header: "Weather Forecast",
                                				type: "forecast",
                                				lat: 40.5290869,
                                				lon: -3.4765786
                                			module: "MMM-CalendarExt3",
                                			title: "",
                                				mode: "month",
                                				instanceId: "basicCalendar",
                                				locale: 'es-ES',
                                				maxEventLines: 5,
                                				firstDayOfWeek: 1,
                                				// eventHeight: 22,
                                				fontSize: 50,
                                				calendarSet: ['ufransa', 'lupita'],
                                			header: "Noticias del mundo",
                                				apiKey: "APIKEY",
                                				type: "horizontal",
                                				pageSize: 20,
                                				query: {
                                					country: "",
                                					category: "",
                                					q: "",
                                					qInTitle: "",
                                					sources: "",
                                					domains: "",
                                					excludeDomains: "",
                                					language: "en"
                                • mumblebajM
                                  @ufransa Ok, I don’t see anything in your config that would cause a problem. However, you do have both MMM-NewsAPI and MMM-calendarExt3 in the exact same position. I am thinking that MMM-CalendarExt3 may be pushing the module off the screen, they both cannot occupy the same space. Try using it in a different position and use the vertical option.
                                    sdetweil @ufransa
                                    @ufransa pages = MMM-pages
                                    my fork which changes the readme for config
                                    https://github.com/sdetweil/MMM-pages
                                    • U
                                      ufransa @mumblebaj
                                      @mumblebaj It could be but after I change the position the result is the same, I can see the header tho but not the news and the API and everything works.
                                      • mumblebajM
                                        @ufransa Can you check if there are any errors? Check the Console Tab in the Developers Window and check in the pm2 logs if you using pm2 or the terminal if you starting MM with npm start
                                        • 5 / 6
