    ERROR:network_service_instance_impl.cc(600)
    7 Posts 2 Posters 624 Views 2 Watching
    • T Offline
      togletree93
      Hello, I was finally making way on my MM and then I started getting black screen on start up. When coming out of MM the terminal shows error. I have completely cleared all modules at this point to narrow the problem done and still nothing. I have seen other topics on this but back in 2022 with no resolve. What do yall think?
      > magicmirror@2.29.0 start
      [2024-11-12 08:50:03.016] [LOG]   Starting MagicMirror: v2.29.0
      [2024-11-12 08:50:04.740] [LOG]   Loading config ...
      [2024-11-12 08:50:04.796] [LOG]   config template file not exists, no envsubst
      [2024-11-12 08:50:07.921] [INFO]  Checking config file /home/USERNAME/MagicMirror/config/config.js ...
      [2024-11-12 08:50:08.161] [INFO]  Your configuration file doesn't contain syntax errors :)
      [2024-11-12 08:50:08.164] [INFO]  Checking modules structure configuration ...
      [2024-11-12 08:50:08.530] [INFO]  Your modules structure configuration doesn't contain errors :)
      [2024-11-12 08:50:08.543] [LOG]   Loading module helpers ...
      [2024-11-12 08:50:08.544] [LOG]   All module helpers loaded.
      [2024-11-12 08:50:08.568] [LOG]   Starting server on port 8080 ...
      [2024-11-12 08:50:48.834] [LOG]   Server started ...
      [2024-11-12 08:50:49.239] [LOG]   Sockets connected & modules started ...
      [2024-11-12 08:51:00.756] [LOG]   Launching application.
      [9558:1112/085142.686724:ERROR:network_service_instance_impl.cc(600)] Network service crashed, restarting service.
      [2024-11-12 08:52:05.964] [INFO]  System information:
      ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi Zero 2 W Rev 1.0; virtual: false
      ### OS:       platform: linux; distro: Raspbian GNU/Linux; release: 12; arch: arm; kernel: 6.6.51+rpt-rpi-v7
      ### VERSIONS: electron: 31.7.2; used node: 20.18.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
      ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
      [2024-11-12 08:52:10.010] [LOG]   Shutting down server...
      [2024-11-12 08:52:10.022] [LOG]   Node_helpers stopped ...
        sdetweil @togletree93
        @togletree93 thats outside our app…
        can you try in server mode and
        npm run server
        then open browser to http://localhost:8080
        • T Offline
          togletree93 @sdetweil
          ~ $ npm run server
          npm ERR! code ENOENT
          npm ERR! syscall open
          npm ERR! path /home/togletree/package.json
          npm ERR! errno -2
          npm ERR! enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/togletree/package.json'
          npm ERR! enoent This is related to npm not being able to find a file.
          npm ERR! enoent
          npm ERR! A complete log of this run can be found in: /home/togletree/.npm/_logs/2024-11-12T15_39_23_877Z-debug-0.log
            @togletree93 have to be in the MagicMirror folder for all MagicMirror commands
            • T Offline
              @sdetweil Sorry for not getting back faster but the page loaded in server mode.
              So what does that mean about trying to run it through terminal? is it a software problem?
                @togletree93 yes, electron browser is having trouble again
                i am busy til this evening i will write up and create a script for this
                  @togletree93 I added a new script at the end of the scripts page
                  this will install my startup script in the package.json
                  and update the installers/mm.sh to indicate which browser to use
                  (and install the browser you pick from a list if not already installed)
                  this will run mm in server only mode and then launch a browser over it like you did manually
                  the look is identical, (alth0 midori browser has gotten troublesome with its parameter handling and MAY need to have its window maximized manually
                  • D dathbe referenced this topic on
