    ERROR:network_service_instance_impl.cc(600)
    7 Posts 2 Posters 1.1k Views 2 Watching
      sdetweil @togletree93
      @togletree93 thats outside our app…
      can you try in server mode and
      npm run server
      then open browser to http://localhost:8080
      • T Offline
        togletree93 @sdetweil
        ~ $ npm run server
        npm ERR! code ENOENT
        npm ERR! syscall open
        npm ERR! path /home/togletree/package.json
        npm ERR! errno -2
        npm ERR! enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/togletree/package.json'
        npm ERR! enoent This is related to npm not being able to find a file.
        npm ERR! enoent
        npm ERR! A complete log of this run can be found in: /home/togletree/.npm/_logs/2024-11-12T15_39_23_877Z-debug-0.log
          @togletree93 have to be in the MagicMirror folder for all MagicMirror commands
          • T Offline
            @sdetweil Sorry for not getting back faster but the page loaded in server mode.
            So what does that mean about trying to run it through terminal? is it a software problem?
              @togletree93 yes, electron browser is having trouble again
              i am busy til this evening i will write up and create a script for this
                @togletree93 I added a new script at the end of the scripts page
                this will install my startup script in the package.json
                and update the installers/mm.sh to indicate which browser to use
                (and install the browser you pick from a list if not already installed)
                this will run mm in server only mode and then launch a browser over it like you did manually
                the look is identical, (alth0 midori browser has gotten troublesome with its parameter handling and MAY need to have its window maximized manually
                • D dathbe referenced this topic on
