    Adding background image to analog clock.
    10 Posts 3 Posters 1.8k Views 3 Watching
      ChrisLeduex
      Hello, I’m trying to add a svg image to the default analog clock module in a way that will allow me to change it’s color along with the other elements using custom.css.
      However the problem is the image hides part of the clock hands and I can’t figure how to fix it. Any suggestions?
      Here’s my entry in the custom.css file:
      .clock-face {
      .clock-face {
        -webkit-mask: url('apple-fresh-fruit-svgrepo-com.svg') center/cover no-repeat;
        mask: url('apple-fresh-fruit-svgrepo-com.svg');
        display: block;
        margin: auto;
        margin-top: 60px;
        height:45%;
        width: 45%;
        background:var(--use_color);
        ChrisLeduex
        I found a way to make this work, though it’s not the cleanest.
        1:
        In the clock.js file I add these lines to the bottom of these sections:
        * Create wrappers for analog and digital clock
        const analogBackground = document.createElement("div");
        analogBackground.className = "clock-grid-background";
        * Create wrappers for ANALOG clock, only if specified in config
        clockFace.appendChild(analogBackground);
        2:
        Added this section to the clock_styles.css:
        Note the “z-index: 0;”
        .clock-grid-background {
          position: absolute;
          display: block;
          z-index: 0;
        I then added “z-index: 99;” to the following sections to make sure they stay on top:
        .clock-circle
        .clock-face
        .clock-face::after
        .clock-hour
        .clock-minute
        .clock-second
        Added this code to the custom.css file:
          //mask: url('apple-fresh-fruit-svgrepo-com.svg');
          display: block;
          margin: auto;
          margin-top: 60px;
          margin-left: 65px;
          height: 120px;
          width: 120px;
          background-color: var(--use_color);
          sdetweil @ChrisLeduex
          @ChrisLeduex cool. you should submit that as an enhancement
          C 2 Replies Last reply Reply Quote 0
            @ChrisLeduex is z-index:99 below above? so would be hidden by module in fullscreen_above. don’t want them peeking thru
              ChrisLeduex @sdetweil
              @sdetweil Larger numbers sit on top of smaller numbers. In this case I wanted to make sure the svg image was always underneath the clock face/hands (z-index: 0) and the clock hands were always on top (z-index: 99). I could have used ‘z-index: 0’ and ‘z-index: 1’ instead but picked a larger number just to be sure the clock is always on top of anything else that might get added.
              I’m still working on it because I’d like to have a solution that doesn’t require any code changes to the module files. I’d like something that only requires using the custom.css file.
                @ChrisLeduex cool, it was just a question of implementation checking… good work
                  Sorry @sdetweil, this is my first MM project and I have no idea what I’m doing. So I didn’t understand that “fullscreen_above” was a position option for modules.
                  In the screen shot below I left my clock the same as before with ‘z-index: 0’ on the apple and ‘z-index: 99’ on all the other classes of the clock. I then set my calendar module to “fullscreen_above” to see what would happen.
                  Not easy to see in the screen shot but all of the components of the clock that have a z-index are on top of the calendar and the date which doesn’t have any z-index values is underneath the calendar. So it would appear that any z-index value, even 0, puts those components on top of “fullscreen_above”. So yes, it should be used carefully because it will peek through.
                  	module: "clock",
                  		displayType: "analog",
                  		displaySeconds: false,
                  	header: "US Holidays",
                  	position: "fullscreen_above",
                  • J Online
                    JohnGalt @ChrisLeduex
                    @ChrisLeduex – Interesting exercise. Where did you put the .svg image[s]? In with the clock faces in the module folder? In the module folder root? Other?
                      ChrisLeduex @JohnGalt
                      @JohnGalt I just put them directly in the CSS folder with the custom.css file while I was testing everything. But they can certainly go wherever you like based on how you organize stuff.
                      • J Online
                        @ChrisLeduex – OK, thanks. I wasn’t sure that the url path went anywhere in particular.
