    Calendar doubling events- Calendar & Calendar EXT3
    20 Posts 3 Posters 3.3k Views 3 Watching
      MMrustykayn66
      I just finished up my first Magic Mirror build. I updated Magic Mirror today as well as other modules it told me where out of date. After updating I started adding re-occurring tasks to my Google Calendar. I realised that these tasks are doubling. They display on the day the are supposed to occur as well as the day after. This does not occur for re-occurring tasks I added before updating.
      Its a pretty Vanilla install I am using the Calendar EXT3 module for my Calendar. I’m not really code literate, just good at following directions
      My Config File
      	port: 8080,
      	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
      	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
      	ipWhitelist: [],
      	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
      	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
      	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
      	language: "en",
      	locale: "en-US",
      	timeFormat: 12,
      	units: "imperial",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_right"
      				//wrapEvents: true,
      				broadcastPastEvents: true, // <= IMPORTANT to see past events
      			fetchInterval: 300000,
      			url: "https://calendar.google.com/calendar/***/basic.ics",
                              name: "Shandra", // <= RECOMMENDED to assign name
                              color: "blue" // <= RECOMMENDED to assign color
      					url: "https://calendar.google.com/calendar/ical/en.usa%23holiday%40group.v.calendar.google.com/public/basic.ics",
                              name: "us_holiday", // <= RECOMMENDED to assign name
                              color: "red" // <= RECOMMENDED to assign color
                  module: "MMM-CalendarExt3",
                  title: "",
                          mode: "month",
                          instanceId: "basicCalendar",
                          locale: 'en-US',
                          maxEventLines: 6,
                          firstDayOfWeek: 0,
                          calendarSet: ['us_holiday', 'abfall', 'mytest', 'Shandra'],
      			module: "compliments",
      			position: "bottom_center"
      			module: "weather",
      				weatherProvider: "openmeteo",
      				type: "current",
      				lat: 44.9429,
      				lon: -123.0351
      			module: "weather",
      			header: "Weather Forecast",
      				type: "forecast",
      				lat: 44.9429,
      				lon: -123.0351
      	module: "MMM-Traffic",
      	position: "bottom_right",
      		accessToken: "pk.eyJ1IjoibW1ydXN0eWtheW42NiIsImEiOiJjbTE0MjFweGYxa3BwMmxvcnJqb2kzZTQ5In0.1_",
      		originCoords: "-",
      		destinationCoords: "-",
      		showSymbol: false,
      		firstLine: "{duration} mins",
      		secondLine: "Home to Schirle Elementary"
      		accessToken: "pk.eyJ1IjoibW1ydXN0eWtheW42NiIsImEiOiJjbTE0MjFweGYxa3BwMmxvcnJqb2kzZTQ5In0.1_HtZ4tllgp8MkK41SkAAQ",
      		originCoords: "-",
      		destinationCoords: " -
      		showSymbol: false,
      		secondLine: "Home to Work"
          module: 'MMM-Remote-Control',
          position: 'bottom_left',
              customCommand: {},  // Optional, See "Using Custom Commands" below
              showModuleApiMenu: true, // Optional, Enable the Module Controls menu
              secureEndpoints: true, // Optional, See API/README.md
              // uncomment any of the lines below if you're gonna use it
              // customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
              // apiKey: "", // Optional, See API/README.md for details
              // classes: {} // Optional, See "Custom Classes" below
      			module: "newsfeed",
      			position: "bottom_center",
      				feeds: [
      						title: "New York Times",
      						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
        sdetweil @MMrustykayn66
        @MMrustykayn66 we worked this offline
        He ended up w 2 instances of calendar module
        1 for ext events past and future
        1 for short list of this week’s next 10 events
        And the updated calendar module in test
          @MMrustykayn66 the calendar has been a recurring problem.
          i have been working on resolving those problems.
          i have a test version you can try i am working on for the next release jan 1
          git fetch origin pull/3587/head:withfixes
          git checkout withfixes
          npm install
          let me know
          M 1 Reply Last reply
            MMrustykayn66 @sdetweil
            @sdetweil I tried pasting into terminal and I got the error
            fatal: not a git repository (or any of the parent directories): .git
            was I supposed to be in the calendar folder when I executed that command
              @MMrustykayn66 you need to be in the MagicMirror folder of course
              corrected the prior post
              M 2 Replies Last reply
                @sdetweil kinda figured something like that was the problem :)
                The double event issue has gone away but it broke other things.
                Calendar EXT3 is no longer displaying any information ( I increased the refresh rate to make sure it wasn’t a pull issue)
                Calendar is no longer showing the double entries but the is a number code bellow the date that is pushing the entire module beyond my layout. 20241113_21h00m48s_grim.png
                  @sdetweil I tried reverting to the version I backed-up before I updated and it exhibits the same doubled entry error. Its version v2.28.0 20241113_21h31m26s_grim.png
                    @MMrustykayn66 ah. i had added that yesterday to debug a testing issue
                    i use ext3 on my test system and don’t see any impacts
                      @sdetweil Curiouser and Curiouser.
                      -I might try a fresh install this evening to see if that fixes the problem.
                      -Im inputting information to Google calendar via an iPhone. Probably not the problem but I will log into Calendar via my computer to see if that makes a difference. Probably not, but might be worth a try.
                      Only ideas I’ve had so far
                      Thanks for the Help , fingers crossed I can get this sorted soon as the significant other is less than impressed with her new calendar 🤣🤦‍♂️
                      S 2 Replies Last reply
                        @MMrustykayn66 the default refresh rate is slow, a few days
                          @sdetweil when I had nothing showing up on EXT3 I upped the refresh rate to every minute to see if that was the problem. Nothing ever loaded.
                            MMRIZE @MMrustykayn66
                            @MMrustykayn66
                            Only Google calendars are affected? How about other calendar? Like the default sample calendar?
                              @MMrustykayn66 i cleaned up the debug, just git pull in the module folder with current branch on my pr, or install it again
                                Re-entering the data via Google Calendars web interface seems to have fixed the problem. I deleted all entries that were added via Google calendar on IOS and re entered them. It seems to only affect events that are reoccurring.
                                Hopefully this provides insight to someone who knows why.
                                Thank you for all your help. Much appreciated
                                S 3 Replies Last reply
                                  @MMrustykayn66 i use ios all the time to manage my google calendar without problem. sometimes i pick the wrong calendar, family instead of personal, when my mirror is showing personal
                                    @MMrustykayn66 did you reload the new calendar module code?
                                    I see there was a bug if your timezone was UTC. fixed. try git pull in the MM folder to get the update
                                      @MMrustykayn66 can you replicate this and show me the ics file (send via email)
                                      and show me your config for the calendar module
                                      (xxx out the private urls)
                                        Sorry for the late reply.
                                        — I am only using two calendars currently. Googles Holiday calendar and one personal Calendar.
                                        — I reverted to the most current update before adding events VIA the web interface. After that I re-installed G Calendar for IOS and added a reoccurring event. I didn’t realise before that it is not doubling events. Its actually displaying the correct event , the same event on the next day and then on that day for all reoccurring events. IE I set up a reoccurring event for Sat at 9. It shows that event, one on Sunday at 9 and then one for every Sunday at 9 moving forward. Magic Mirror is the only place this happens.
                                        — I git pulled the release you are working on. Its giving me the same error it was before. Calendar module shows events correctly but nothing ever loads on EXT3. PM me your email address and I will send over the ICS. EXT3 is up to date.
                                        				maximumEntries: 12,
                                        				//wrapEvents: true,
                                        			fetchInterval: 50000,
                                        			url: "https://calendar.google.com/calendar/ical/teaxxxxxxx",
                                                    title: "",
                                        		    refreshInterval: 60000,
                                                            mode: "month",
                                                            locale: 'en-US',
                                                            maxEventLines: 6,
                                                            firstDayOfWeek: 0,
                                          @MMrustykayn66 me email is the same userid at gmail
                                          by default the cal will NOT show a recurring event on different days . it shows the start . if its Monday and the event starts Tuesday and repeats daily thru Thursday,
                                          then the cal will show up on Tuesday.
                                          if u turn on splitevents then you will see tue/1, wed/2, thur/3
                                          broadcast psst events and # events at 12 will be a problem w large calendars.
                                          we never show past events.
                                          the fetcher gets the events as one big pile in date order then clips the list to the size specified
                                          look at the broadcasting message in the output of the npm start
                                          my calendar has 1600 events, only 3 this week
                                          maximum number of days would be better
                                          we scan back and forward that range. default is a year
                                          Ext3 wont display events that don’t fit in the visual timeframe weeks/month bring viewed
                                            -the test event isn’t supposed to be on Sunday at all. Its only supposed to occur on Saturday. It shows up on Saturday for the first occurrence then the next Sunday and every Sunday after that.
                                            -Should I turn of broadcast past events? I have events set to 12 to push the calendar module out a little bit so everything is more visually balanced. If its not the right side column is a bit crunched and doesn’t line up properly with the left column where I have EXT3
                                            • My Broadcasting only has 579 events. SO a much ‘smaller’ calendar.
                                            • I assume visual event time-frame refers to the data that would only show for the weeks displayed. Nothing displays in the Calendar at all for any of the days, Personal or Holiday Calendar.
