    Calendar doubling events- Calendar & Calendar EXT3
    20 Posts 3 Posters 2.2k Views 3 Watching
      MMrustykayn66 @sdetweil
      @sdetweil I tried reverting to the version I backed-up before I updated and it exhibits the same doubled entry error. Its version v2.28.0 20241113_21h31m26s_grim.png
        sdetweil @MMrustykayn66
        @MMrustykayn66 ah. i had added that yesterday to debug a testing issue
        i use ext3 on my test system and don’t see any impacts
          @sdetweil Curiouser and Curiouser.
          -I might try a fresh install this evening to see if that fixes the problem.
          -Im inputting information to Google calendar via an iPhone. Probably not the problem but I will log into Calendar via my computer to see if that makes a difference. Probably not, but might be worth a try.
          Only ideas I’ve had so far
          Thanks for the Help , fingers crossed I can get this sorted soon as the significant other is less than impressed with her new calendar 🤣🤦‍♂️
            @MMrustykayn66 the default refresh rate is slow, a few days
              @sdetweil when I had nothing showing up on EXT3 I upped the refresh rate to every minute to see if that was the problem. Nothing ever loaded.
                MMRIZE @MMrustykayn66
                @MMrustykayn66
                Only Google calendars are affected? How about other calendar? Like the default sample calendar?
                  @MMrustykayn66 i cleaned up the debug, just git pull in the module folder with current branch on my pr, or install it again
                    Re-entering the data via Google Calendars web interface seems to have fixed the problem. I deleted all entries that were added via Google calendar on IOS and re entered them. It seems to only affect events that are reoccurring.
                    Hopefully this provides insight to someone who knows why.
                    Thank you for all your help. Much appreciated
                    S 3 Replies Last reply Reply Quote 0
                      @MMrustykayn66 i use ios all the time to manage my google calendar without problem. sometimes i pick the wrong calendar, family instead of personal, when my mirror is showing personal
                        @MMrustykayn66 did you reload the new calendar module code?
                        I see there was a bug if your timezone was UTC. fixed. try git pull in the MM folder to get the update
