    Calendar doubling events- Calendar & Calendar EXT3
    20 Posts 3 Posters 2.1k Views 3 Watching
      MMrustykayn66
      I just finished up my first Magic Mirror build. I updated Magic Mirror today as well as other modules it told me where out of date. After updating I started adding re-occurring tasks to my Google Calendar. I realised that these tasks are doubling. They display on the day the are supposed to occur as well as the day after. This does not occur for re-occurring tasks I added before updating.
      Its a pretty Vanilla install I am using the Calendar EXT3 module for my Calendar. I’m not really code literate, just good at following directions
      My Config File
      	port: 8080,
      	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
      	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
      	ipWhitelist: [],
      	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
      	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
      	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
      	language: "en",
      	locale: "en-US",
      	timeFormat: 12,
      	units: "imperial",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_right"
      				//wrapEvents: true,
      				broadcastPastEvents: true, // <= IMPORTANT to see past events
      			fetchInterval: 300000,
      			url: "https://calendar.google.com/calendar/***/basic.ics",
                              name: "Shandra", // <= RECOMMENDED to assign name
                              color: "blue" // <= RECOMMENDED to assign color
      					url: "https://calendar.google.com/calendar/ical/en.usa%23holiday%40group.v.calendar.google.com/public/basic.ics",
                              name: "us_holiday", // <= RECOMMENDED to assign name
                              color: "red" // <= RECOMMENDED to assign color
                  module: "MMM-CalendarExt3",
                  title: "",
                          mode: "month",
                          instanceId: "basicCalendar",
                          locale: 'en-US',
                          maxEventLines: 6,
                          firstDayOfWeek: 0,
                          calendarSet: ['us_holiday', 'abfall', 'mytest', 'Shandra'],
      			module: "compliments",
      			position: "bottom_center"
      			module: "weather",
      				weatherProvider: "openmeteo",
      				type: "current",
      				lat: 44.9429,
      				lon: -123.0351
      			module: "weather",
      			header: "Weather Forecast",
      				type: "forecast",
      				lat: 44.9429,
      				lon: -123.0351
      	module: "MMM-Traffic",
      	position: "bottom_right",
      		accessToken: "pk.eyJ1IjoibW1ydXN0eWtheW42NiIsImEiOiJjbTE0MjFweGYxa3BwMmxvcnJqb2kzZTQ5In0.1_",
      		originCoords: "-",
      		destinationCoords: "-",
      		showSymbol: false,
      		firstLine: "{duration} mins",
      		secondLine: "Home to Schirle Elementary"
      		accessToken: "pk.eyJ1IjoibW1ydXN0eWtheW42NiIsImEiOiJjbTE0MjFweGYxa3BwMmxvcnJqb2kzZTQ5In0.1_HtZ4tllgp8MkK41SkAAQ",
      		originCoords: "-",
      		destinationCoords: " -
      		showSymbol: false,
      		secondLine: "Home to Work"
          module: 'MMM-Remote-Control',
          position: 'bottom_left',
              customCommand: {},  // Optional, See "Using Custom Commands" below
              showModuleApiMenu: true, // Optional, Enable the Module Controls menu
              secureEndpoints: true, // Optional, See API/README.md
              // uncomment any of the lines below if you're gonna use it
              // customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
              // apiKey: "", // Optional, See API/README.md for details
              // classes: {} // Optional, See "Custom Classes" below
      			module: "newsfeed",
      			position: "bottom_center",
      				feeds: [
      						title: "New York Times",
      						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
        sdetweil @MMrustykayn66
        @MMrustykayn66 we worked this offline
        He ended up w 2 instances of calendar module
        1 for ext events past and future
        1 for short list of this week’s next 10 events
        And the updated calendar module in test
          @MMrustykayn66 the calendar has been a recurring problem.
          i have been working on resolving those problems.
          i have a test version you can try i am working on for the next release jan 1
          git fetch origin pull/3587/head:withfixes
          git checkout withfixes
          npm install
          let me know
            MMrustykayn66 @sdetweil
            @sdetweil I tried pasting into terminal and I got the error
            fatal: not a git repository (or any of the parent directories): .git
            was I supposed to be in the calendar folder when I executed that command
              @MMrustykayn66 you need to be in the MagicMirror folder of course
              corrected the prior post
                @sdetweil kinda figured something like that was the problem :)
                The double event issue has gone away but it broke other things.
                Calendar EXT3 is no longer displaying any information ( I increased the refresh rate to make sure it wasn’t a pull issue)
                Calendar is no longer showing the double entries but the is a number code bellow the date that is pushing the entire module beyond my layout. 20241113_21h00m48s_grim.png
                  @sdetweil I tried reverting to the version I backed-up before I updated and it exhibits the same doubled entry error. Its version v2.28.0 20241113_21h31m26s_grim.png
                    @MMrustykayn66 ah. i had added that yesterday to debug a testing issue
                    i use ext3 on my test system and don’t see any impacts
                      @sdetweil Curiouser and Curiouser.
                      -I might try a fresh install this evening to see if that fixes the problem.
                      -Im inputting information to Google calendar via an iPhone. Probably not the problem but I will log into Calendar via my computer to see if that makes a difference. Probably not, but might be worth a try.
                      Only ideas I’ve had so far
                      Thanks for the Help , fingers crossed I can get this sorted soon as the significant other is less than impressed with her new calendar 🤣🤦‍♂️
                        @MMrustykayn66 the default refresh rate is slow, a few days
                          @sdetweil when I had nothing showing up on EXT3 I upped the refresh rate to every minute to see if that was the problem. Nothing ever loaded.
