    Does my MM really need this size of GB?
    9 Posts 3 Posters 1.2k Views 3 Watching
      sdetweil @kusselin
      @kusselin your image didn’t show
      you can only upload images using the next to last icon above the mess editor
      look at the size of the node_moduies folders in each module. the size of the dependencies
      kusselinK 1 Reply Last reply Reply Quote 0
      • kusselinK Offline
        kusselin @sdetweil
        @sdetweil hä, when i click on picture link i can see the picture.
          sdetweil @kusselin
          @kusselin ok, i wont click links in messages, generally don’t recommend them.
          if a new users posts with links without clear text of the url to an known image site i will reject that message. too much theft spam in the world
          links off MagicMirror forums are reviewed as well
          • kusselinK Offline
            kusselin @sdetweil
            @sdetweil so, i installed the MM new in a proxmox container as a server…
            why is the CPU last so high???
              sdetweil @kusselin
              @kusselin what modules are running?
              we don’t have any live code in the base, its all in modules.
              sounds like at least one module has very short refresh cycle
                abuislam
                @kusselin said in Does my MM really need this size of GB?:
                General Discussion
                2 posters
                kusselin
                Oct 31, 2024, 12:17 PM
                Hello everyone, I’m wondering about the GB size of my MM. I have about 10 modules running…can it really be that they need so much disk space or is something wrong?
                Check for log files or cache buildup that might be consuming extra space. Also, verify module configurations to ensure no unnecessary data is being stored.
                  sdetweil @kusselin
                  @kusselin one other quick way to review is to use the du (disk used) command
                  sort -h sorts the 1st field (numbers) in human terms…
                  du | sort -h > somefile.txt
                  if you do a large folder tree (your home folder or root) it can take a while
                  this will give you a sorted list smallest to largest of directories
                  from wherever you start it
                  I did this on my linux desktop from my user folder, just a portion of the end
                  11810208	./vmware/Debian 12.x 64-bit
                  12020248	./Desktop/opencv
                  12144968	./anaconda3/pkgs
                  12219120	./Android/Sdk
                  12219124	./Android
                  12323884	./Desktop
                  13678872	./anaconda3
                  14162920	./vmware/Raspian Buster 4.x 64-bit
                  14874340	./ncs
                  16313000	./vmware/Linux Mint 20.2
                  17014960	./.cache
                  17268312	./vmware/Ubuntu
                  17392988	./vmware/Ubuntu 32bit (2)
                  35216244	./vmware/Zorin 15
                  40893836	./.local/share/Trash/files
                  40896348	./.local/share/Trash
                  41591952	./.local/share
                  41834176	./.local
                  43818540	./vmware/Windows 11 x64 (2)
                  49541680	./vmware/WinDev2003Eval
                  64832512	./vmware/Windows 10 x64
                  66790396	./VMs/Ubuntu 64-bit-2
                  171421968	./Downloads
                  257993020	./VMs/Clone of Mac OS X high Sierra2
                  301040804	./vmware
                  333343640	./VMs
                  1027520228	.
                  • kusselinK Offline
                    kusselin @sdetweil
                    @sdetweil thx sdetweil and the others…
                    i installed the MM new and now all is good
