    MMM-CalendarExt - Startup problem
    7 Posts 3 Posters 1.3k Views 3 Watching
      Bimtronic
      Im having problem starting my config.js since i added the module MMM-CalendarExt to my Raspberry Pi 3 MM.
      (I have installed everything recently so all packages are the latest, it runs fine without MMM-CalendarExt part in the config.)
      These are the errors i get.
      What can i do to fix this?
      [2024-11-24 11:18:27.405] [LOG] Loading module helpers …
      [2024-11-24 11:18:28.801] [ERROR] (node:12995) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘valid-url’
      Require stack:
      • /home/mt/MagicMirror/modules/MMM-CalendarExt/node_helper.js
      • /home/mt/MagicMirror/js/app.js
      • /home/mt/MagicMirror/js/electron.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1232:15)
        at s._resolveFilename (node:electron/js2c/browser_init:2:121498)
        at Module._resolveFilename (/home/mt/MagicMirror/node_modules/module-alias/index.js:49:29)
        at Module._load (node:internal/modules/cjs/loader:1058:27)
        at c._load (node:electron/js2c/node_init:2:17025)
        at Module.require (node:internal/modules/cjs/loader:1318:19)
        at require (node:internal/modules/helpers:179:18)
        at Object. (/home/mt/MagicMirror/modules/MMM-CalendarExt/node_helper.js:3:18)
        at Module._compile (node:internal/modules/cjs/loader:1484:14)
        at Module._extensions…js (node:internal/modules/cjs/loader:1564:10)
        at Module.load (node:internal/modules/cjs/loader:1295:32)
        at Module._load (node:internal/modules/cjs/loader:1111:12)
        at loadModule (/home/mt/MagicMirror/js/app.js:200:19)
        (Use electron --trace-warnings ... to show where the warning was created)
        [2024-11-24 11:18:28.808] [ERROR] (node:12995) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
        Bimtronic @sdetweil
        @sdetweil I got it working reading some other threads :)
        Ran these inside the module-folder:
        npm install request
        npm install valid-url
        npm init -y
        There seems to be some problem though:
        # npm audit report
        request *
        Severity: moderate
        Server-Side Request Forgery in Request - https://github.com/advisories/GHSA-p8p7-x288-28g6
        Depends on vulnerable versions of tough-cookie
        No fix available
        node_modules/request
        tough-cookie <4.1.3
        Severity: moderate
        tough-cookie Prototype Pollution vulnerability - https://github.com/advisories/GHSA-72xf-g2v4-qvf3
        No fix available
        node_modules/tough-cookie
        2 moderate severity vulnerabilities
          sdetweil @Bimtronic
          @Bimtronic see
            Bimtronic @sdetweil
            npm install request
            npm init -y
            # npm audit report
            request *
            Severity: moderate
            No fix available
            tough-cookie <4.1.3
            Severity: moderate
            No fix available
              sdetweil @Bimtronic
              @Bimtronic ignore the audit reports, nothing you can do about them. part of the reason request is deprecated.
                sdetweil @Bimtronic
                @Bimtronic MMM-CalendarExt3 is the latest and gets the data from the default calendar, so it doesn’t have this problem
                  Bimtronic
                  Im struggling to get anything to show in my setup for daily and current bars.
                  I have three local ics-calendars in my MM-Folder that ive adressed in my config, only calendar for “upcoming” bar shows up.
                  Config >
                                      module: 'MMM-CalendarExt',
                                      position: "top_left",                           //anywhere. It is not related to real position of view
                                      config: {                                       // Read below
                                        system:{
                                                      show: ['daily', 'upcoming', 'current'],
                                                        locale: 'sv-SV',                      //when omitted, default value would be your system default locale by moment.js
                                                        showEmptyView: 1,
                                                        fullDayEventLocalize: 1,
                                                        redrawInterval: 30*60*1000,   //minimum 60000
                                                        useProfileConfig: 0,
                                                        startProfile: ''
                                        defaultView: {
                                                        position: 'bottom_bar',
                                                        positionOrder: -1,
                                                        overflowRolling: 0,
                                                        overflowHeight: 0,
                                                        overflowDuration: 2,
                                                        onlyStartingTime: 0,
                                                        timeFormat: 'HH:mm',
                                                        dateFormat: "MMM Do",
                                                        fullDayEventDateFormat: "MMM Do",
                                                        ellipsis: 0,
                                                        limit:1,
                                                        oneLineEvent:0,
                                                        replaceTitle:[],
                                                        classPattern:[],
                                                        classPatternWhere:["title"],
                                                        symbolPattern:[],
                                                        symbolPatternWhere:["title"]
                                        views: {
                                                              weeks: {
        showWeeks: 1,
        weeksTitle: 'Veckor',
        weeksFormat: 'wo',
        weekdayFormat: 'dd',
        titleFormat : 'MMM D',
        overTitleFormat : 'MMM D',
        counts: 2,
                                                              daily: {
        direction: 'row',
        counts: 5,
        titleFormat: "D",
        overTitleFormat: "MMM D",
        subtitleFormat: "ddd",
                                                              weekly: {
        direction: 'row',
        counts: 4,
        titleFormat: "wo",
        overTitleFormat: "gggg wo",
        subtitleFormat: "MMM Do",
                                                              current: {
        title: 'Aktuell',
        useRelative: 1
                                                              upcoming: {
        title: 'Kommande',
        useRelative: 1
                                        defaultCalendar: {
        profiles: [],
        views: ['daily'],
        symbol: "",
        styleName: "",
        replaceTitle:[],
        classPattern: [],
        classPatternWhere: ["title"],
        symbolPattern: [],
        symbolPatternWhere: ["title"],
        maxEntries:50,
        maxDays:180,
        interval: 1800000,
        url: "webcal://localhost:8080/modules/ics/namedays.ics",
        profile: [],
        views: ['daily', 'current', 'upcoming'],
        styleName: "style1",
        symbol: 'us@fi',
        maxEntries: 50,
        maxDays:365,
        interval: 24*60*60*1000,
        url: "webcal://localhost:8080/modules/ics/se_holidays.ics",
        profile: [],
        symbol: 'se@fi',
        maxEntries: 50,
        maxDays:365,
        url: "webcal://localhost:8080/modules/ics/Ansvarsvecka.ics",
        profile: [],
        symbol: 'se@fi',
        maxEntries: 50,
        maxDays:365,
                                      header: "Helgdagar",
                                                              symbol: "calendar-check",
                  • KristjanESPERANTOK Offline
                    KristjanESPERANTO Module Developer @Bimtronic
                    @Bimtronic Try MMM-CalendarExt3 instead of MMM-CalendarExt. MMM-CalendarExt is no longer maintained.
