    installetion error
    5 Posts 3 Posters 274 Views 3 Watching
      Dawcio232v2
      cant run
      npm run install-mm
      https://imgur.com/a/uq8z41R
      S D 2 Replies Last reply Reply Quote 0
        sdetweil @Dawcio232v2
        @Dawcio232v2 correct, we don’t support node 23
        You need to install node 22
        You can do see the Node version of nvm
        sudo npm install n -g
        sudo n 22
        Sudo is required as those commands will update the /usr folder which is protected
          Dawcio232v2 @Dawcio232v2
          @Dawcio232v2thanks it works now
            paddy49
            I did the same thing! Loaded v23.x of Node.js instead of v22.x.
            But how do I UN-install it, so I can do it right next time? Or maybe I don’t need to. Or can I just delete the Magic Mirror folder and start again?
            Somewhere in the documentation, it said I could uninstall using a ‘yum’ command. But it didn’t work.
              sdetweil @paddy49
              @paddy49 see this
              https://forum.magicmirror.builders/post/121607
              node is not IN the MagicMirror folder, it is a system tool
