    Modulo MMM-TelegramBot screenshot
    7 Posts 2 Posters 911 Views 2 Watching
    • N Offline
      nic0rz
      Hello friends,
      I managed to get my MagicMirror working the way I wanted, but I have an issue I can’t solve. It’s about the screenshots I take using the Telegram bot. The image I receive on my phone is 1280x720 pixels, and the problem is that it looks very blurry, making it hard to read or understand what it says. However, on Telegram for PC, that same image looks fine, and I receive it at 1920x1080, which is the resolution of my screen.
      The module I have installed is MMM-TelegramBot.TelegramPC.jpg TelegramMovil.jpg
        MMRIZE @nic0rz
        @nic0rz
        Telegram mobile app will reduce the size of the same image than the desktop app.
          MMRIZE @nic0rz
          @nic0rz
          To avoid this, the module had to send the image as a file, not an image. But in that case, the preview of the image will not work in the Telegram App. Dillemma. (I’ll consider enabling the selection both ways.)
          N 2 Replies Last reply Reply Quote 0
          • N Offline
            nic0rz @MMRIZE
            @MMRIZE Hello MMRIZE, thank you for the help. You gave me a great idea, and it worked. I changed sendPhoto to sendDocument under case ‘PHOTO_PATH’: in node_helper.js, and now it sends it to me as a file without compression.
            • N Offline
              nic0rz @MMRIZE
              @MMRIZE I just realized that if the screen is turned off, taking a screenshot only shows the background and not the modules.
                MMRIZE @nic0rz
                @nic0rz
                I think that is out of this module’s business.
                • N nic0rz has marked this topic as solved on
                • N Offline
                  nic0rz @MMRIZE
                  Alright, the issue was resolved after restarting. Thank you so much for the help!
