    Modulo MMM-TelegramBot screenshot
    7 Posts 2 Posters 805 Views 2 Watching
      MMRIZE @nic0rz
      @nic0rz
      To avoid this, the module had to send the image as a file, not an image. But in that case, the preview of the image will not work in the Telegram App. Dillemma. (I’ll consider enabling the selection both ways.)
      N 2 Replies Last reply Reply Quote 0
      • N Offline
        nic0rz @MMRIZE
        @MMRIZE Hello MMRIZE, thank you for the help. You gave me a great idea, and it worked. I changed sendPhoto to sendDocument under case ‘PHOTO_PATH’: in node_helper.js, and now it sends it to me as a file without compression.
        • N Offline
          nic0rz @MMRIZE
          @MMRIZE I just realized that if the screen is turned off, taking a screenshot only shows the background and not the modules.
            MMRIZE @nic0rz
            @nic0rz
            I think that is out of this module’s business.
            • N nic0rz has marked this topic as solved on
            • N Offline
              nic0rz @MMRIZE
              Alright, the issue was resolved after restarting. Thank you so much for the help!
