    Default Calendar stuck on loading
    55 Posts 2 Posters 12.0k Views 2 Watching
      rushmuzik @sdetweil
      @sdetweil how do I show that?
        rushmuzik @sdetweil
          sdetweil @rushmuzik
          @rushmuzik you have to be in the MagicMirror folder for npm start
            rushmuzik @sdetweil
            I apologize for my ignorance. Im a noob but I learn quickly. Im using firefox not chromium
              sdetweil @rushmuzik
              @rushmuzik i’m confused, that is running my run-start script,
              but setup for chromium not firefox.
              if you are using this script and want firefox then you have to add the
              export external_browser=firefox
              before you do npm start
              else my script will just loop
              R 3 Replies Last reply Reply Quote 0
                rushmuzik @sdetweil
                @sdetweil after running your script I did the following
                sudo apt-get remove chromium-browser
                sudo apt autoremove
                sudo apt-get update
                sudo apt-get install firefox-esr
                DISPLAY=:0 npm start
                bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
                cd ~/MagicMirror/
                pm2 start MagicMirror
                  rushmuzik @sdetweil
                  This is what I get from npm start now after running
                    rushmuzik @sdetweil
                    @sdetweil This came after that. Its just stuck here now
                      sdetweil @rushmuzik
                      @rushmuzik did firefox come up? those messages are from the server side
                      but they were initiated by the browser side so some browser started loading the page from the server
                        rushmuzik @sdetweil
                        @sdetweil Yes, it came up and is running. Everything is working except the calendar. Just stuck at loading…
                        • 1 / 6
