    Default Calendar stuck on loading
    55 Posts 2 Posters 16.8k Views 2 Watching
      rushmuzik
      Re: Calendar Module not working with Google Calendar
      Magic Mirror Default Calendar not working. Just stuck loading. I get this with the US Holidays link. I installed node-ical@0.16.1 and Electron@28.1.1. I even disabled IPv6.
        rushmuzik @sdetweil
        @sdetweil I reverted back to socket.io@4.7.2 that was used on MagicMirror@2.26.0 and that fixed the issue! I tried socket.io@4.7.5 but that didnt work. So I went back to @4.7.2 and that fixed it. It might just be a compatibility issue with Firefox ESR. Mystery Solved! Thanks for all your help!
          sdetweil @rushmuzik
          @rushmuzik can you show the output of npm start
          be careful some of the messages about calendar contain the full url from config
          S R 3 Replies Last reply
            @rushmuzik new calendar updates coming next release, jan 1
            depend on fixes in node-ical 0.20.1
              rushmuzik @sdetweil
              @sdetweil how do I show that?
                rushmuzik @sdetweil
                  sdetweil @rushmuzik
                  @rushmuzik you have to be in the MagicMirror folder for npm start
                  R 1 Reply Last reply
                    rushmuzik @sdetweil
                    I apologize for my ignorance. Im a noob but I learn quickly. Im using firefox not chromium
                      sdetweil @rushmuzik
                      @rushmuzik i’m confused, that is running my run-start script,
                      but setup for chromium not firefox.
                      if you are using this script and want firefox then you have to add the
                      export external_browser=firefox
                      before you do npm start
                      else my script will just loop
                        rushmuzik @sdetweil
                        @sdetweil after running your script I did the following
                        sudo apt-get remove chromium-browser
                        sudo apt autoremove
                        sudo apt-get update
                        sudo apt-get install firefox-esr
                        DISPLAY=:0 npm start
                        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
                        cd ~/MagicMirror/
                        pm2 start MagicMirror
                          rushmuzik @sdetweil
                          This is what I get from npm start now after running
                            rushmuzik @sdetweil
                            @sdetweil This came after that. Its just stuck here now
                              sdetweil @rushmuzik
                              @rushmuzik did firefox come up? those messages are from the server side
                              but they were initiated by the browser side so some browser started loading the page from the server
                                rushmuzik @sdetweil
                                @sdetweil Yes, it came up and is running. Everything is working except the calendar. Just stuck at loading…
                                  sdetweil @rushmuzik
                                  @rushmuzik and there should be messages on the server side
                                    rushmuzik @sdetweil
                                    @sdetweil Strangly I didnt see any fetch messages for the calendar.
                                      sdetweil @rushmuzik
                                      @rushmuzik interesting, can you show messages after
                                      the point your browser at message
                                      those would be after the browser loads the web page
                                        rushmuzik @sdetweil
                                        @sdetweil This is as far as it goes. for some reason I dont get “Create new calendarfetcher for url:”
                                          sdetweil @rushmuzik
                                          @rushmuzik weird
                                          can you
                                          open the developers window and find the console tab and see if there is an error
                                          i don’t know for sure how to do that on firefox. i will check it out in the morning running this way
                                            rushmuzik @sdetweil
                                            @sdetweil Definitely appears to be some errors in the console. Its CTRL + SHIFT + I to access it in Firefox
                                              sdetweil @rushmuzik
                                              @rushmuzik thanks will review
