    Default Calendar stuck on loading
    55 Posts 2 Posters 16.8k Views 2 Watching
      rushmuzik @sdetweil
        sdetweil @rushmuzik
        @rushmuzik you have to be in the MagicMirror folder for npm start
        R 1 Reply Last reply
          rushmuzik @sdetweil
          I apologize for my ignorance. Im a noob but I learn quickly. Im using firefox not chromium
            sdetweil @rushmuzik
            @rushmuzik i’m confused, that is running my run-start script,
            but setup for chromium not firefox.
            if you are using this script and want firefox then you have to add the
            export external_browser=firefox
            before you do npm start
            else my script will just loop
            R 3 Replies Last reply
              rushmuzik @sdetweil
              @sdetweil after running your script I did the following
              sudo apt-get remove chromium-browser
              sudo apt autoremove
              sudo apt-get update
              sudo apt-get install firefox-esr
              DISPLAY=:0 npm start
              bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
              cd ~/MagicMirror/
              pm2 start MagicMirror
                rushmuzik @sdetweil
                This is what I get from npm start now after running
                  rushmuzik @sdetweil
                  @sdetweil This came after that. Its just stuck here now
                    sdetweil @rushmuzik
                    @rushmuzik did firefox come up? those messages are from the server side
                    but they were initiated by the browser side so some browser started loading the page from the server
                      rushmuzik @sdetweil
                      @sdetweil Yes, it came up and is running. Everything is working except the calendar. Just stuck at loading…
                        sdetweil @rushmuzik
                        @rushmuzik and there should be messages on the server side
                          rushmuzik @sdetweil
                          @sdetweil Strangly I didnt see any fetch messages for the calendar.
                            sdetweil @rushmuzik
                            @rushmuzik interesting, can you show messages after
                            the point your browser at message
                            those would be after the browser loads the web page
                              rushmuzik @sdetweil
                              @sdetweil This is as far as it goes. for some reason I dont get “Create new calendarfetcher for url:”
                                sdetweil @rushmuzik
                                @rushmuzik weird
                                can you
                                open the developers window and find the console tab and see if there is an error
                                i don’t know for sure how to do that on firefox. i will check it out in the morning running this way
                                  rushmuzik @sdetweil
                                  @sdetweil Definitely appears to be some errors in the console. Its CTRL + SHIFT + I to access it in Firefox
                                    sdetweil @rushmuzik
                                    @rushmuzik thanks will review
                                      @rushmuzik OK i tested on my desktop ubuntu, and on pi4 with latest PI os (bookworm) 64bit.
                                      I do not see that
                                      what machine are you on? can u show the startup info section
                                      this output comes after Launching application
                                      [2024-12-19 08:19:24.759] [INFO]  System information:
                                      ### SYSTEM:   manufacturer: ; model: ; virtual: false
                                      ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
                                      ### VERSIONS: electron: 31.7.3; used node: 20.18.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
                                      ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
                                      S R 2 Replies Last reply
                                        @rushmuzik
                                        given the error you showed, can you try list change
                                        edit MagicMirror/js/server.js
                                        and down at the bottom
                                        	this.close = function () {
                                        		return new Promise((resolve) => {
                                        			for (const socket of serverSockets.values()) {
                                        				socket.close();   //<--- add this line
                                        				socket.destroy();
                                        save and restart MagicMirror
                                          rushmuzik @sdetweil
                                          @sdetweil This is what I’m using. with Firefox ESR as the browser because Chromium and regular firefox are no longer supported on a Pi zero. Also, I’m using an API to connect to my Tempest weather station and that works fine. In addition all the other default modules work as they should except for calendar.
                                            sdetweil @rushmuzik
                                            @rushmuzik pi zero. ok… let me set that up
