    MMM-MPlayer
    7 Posts 3 Posters 998 Views 3 Watching
    • plainbrokeP Offline
      plainbroke
      This is what I have in my config.js for MMM-MPlayer.
      My problem is I can play big bunny and pretty much any video.
      BUT I want to show my rtsp cameras like the github shows I can.
      I installed mplayer and the videos play, so pretty sure I have the setup correct to that point. I am running this on Rpi 4 2gb ram off a ssd/usb .
      Bullseye 64b MagicMirror 2.29 I used Sams install script and it installed flawlessly as usual…
      Any help would be greatly appreciated. This is the only module running on this setup. I built it only so I could view my cameras on a bigger screen.
      Since RSTMStream is dead anymore I was really excited to see something else that might work…
      	module: "MMM-MPlayer",
              disabled: false,
              position: "middle_center",
              header: "MPlayer",
      	  useTwoWindows: true,
      	  layout: "row",
      	  monitorAspect: 0,
      	  rotate: -1,
      	  windowSize: { width: 640, height: 360 },
      	  windowPosition: { x: 5, y: 225 },
      	  streamInterval: 30000,
      	  streams: {
      		window1: [
      		  "rtsp://192.168.1.32:554/live",
      		window2: [
      		  "rtsp://192.168.1.35:554/live",
      evroomE plainbrokeP 2 Replies Last reply Reply Quote 0
      • evroomE Offline
        evroom @plainbroke
        Hi @plainbroke,
        Let’s see what we can do about it.
        First be sure that the URL can be opened and shows your stream:
        VLC Media Player
              File
                    Open Network
                       URL: rtsp://192.168.1.32:554/live
                       Open
        Then get some data from the logs:
        $ pm2 flush
        $ pm2 restart MagicMirror
        $ sleep 15  (or simply count to 15)
        $ grep 'MMM-MPlayer' ~/.pm2/logs/MagicMirror-*.log
        Also adding DEBUG will give some more information and since you only use one module, all output will be related to this module:
        logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
        Tailing the current log:
        $ pm2 logs MagicMirror --lines 100
        Also try if a single stream will work:
        (note, please adjust the indents when and where needed)
        $ vi ~/MagicMirror/config/config.js
        	module: 'MMM-MPlayer',
              disabled: false,
              position: 'middle_center',
              header: 'MPlayer',
        	      useTwoWindows: false,
        	      layout: 'row',
        	      monitorAspect: 0,
        	      rotate: -1,
        	      streams: {
        	            window1: [
        		            'rtsp://192.168.1.32:554/live',
        I am using an 8 GB RAM Raspberry Pi 4b, perhaps there are memory constrains we are not aware of.
        But when you say the mp4s are working …
        To see the memory usage:
        $ free -h -t
        MagicMirror version: 2.33.0
        Test environment:
        MagicMirror version: v2.33.0
          plainbroke @evroom
          @evroom
          I get this in the logs.
          Also when I try running the
          VLC Media Player
                File
                      Open Network
                         Open
          I get this:
          VLC Media Player
                File
                      Open Network
                         Open
          -bash: VLC: command not found
          -bash: File: command not found
          -bash: Open: command not found
          -bash: URL:: command not found
           pm2 logs --lines 100
          PM2        | 2024-12-24T11:40:29: PM2 log: Stopping app:mm id:0
          PM2        | 2024-12-24T11:40:29: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
          PM2        | 2024-12-24T11:40:29: PM2 log: pid=5586 msg=process killed
          PM2        | 2024-12-24T11:40:29: PM2 log: App [mm:0] starting in -fork mode-
          PM2        | 2024-12-24T11:40:29: PM2 log: App [mm:0] online
          /home/pi/.pm2/logs/Camera-out.log last 100 lines:
          /home/pi/.pm2/logs/Camera-error.log last 100 lines:
          0|mm       | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
          0|mm       | [2024-12-24 11:40:32.723] [WARN]  You're using a full whitelist configuration to allow for all IPs
          0|mm       | [6118:1224/114036.084607:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          0|mm       | [6118:1224/114036.084939:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          0|mm       | [6118:1224/114036.085151:ERROR:gbm_wrapper.cc(74)] Failed to get fd  for plane.: No such file or directory (2)
          0|mm       | [6118:1224/114036.085242:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          0|mm       | [6118:1224/114036.085389:ERROR:gbm_wrapper.cc(74)] Failed to get fd  for plane.: No such file or directory (2)
          0|mm       | [6118:1224/114036.085464:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          0|mm       | [6118:1224/114036.085599:ERROR:gbm_wrapper.cc(74)] Failed to get fd  for plane.: No such file or directory (2)
          0|mm       | [6118:1224/114036.085676:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          0|mm       | [6118:1224/114036.085814:ERROR:gbm_wrapper.cc(74)] Failed to get fd  for plane.: No such file or directory (2)
          0|mm       | [6118:1224/114036.085907:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          0|mm       | [6118:1224/114036.086078:ERROR:gbm_wrapper.cc(74)] Failed to get fd  for plane.: No such file or directory (2)
          0|mm       | [6118:1224/114036.086171:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          0|mm       | [6118:1224/114036.086326:ERROR:gbm_wrapper.cc(74)] Failed to get fd  for plane.: No such file or directory (2)
          0|mm       | [6118:1224/114036.086409:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          0|mm       | [6118:1224/114036.087583:ERROR:gbm_wrapper.cc(74)] Failed to get fd  for plane.: No such file or directory (2)
          0|mm       | [6118:1224/114036.087738:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          0|mm       | [6118:1224/114036.087922:ERROR:gbm_wrapper.cc(74)] Failed to get fd  for plane.: No such file or directory (2)
          0|mm       | [6118:1224/114036.088027:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          0|mm       | [6118:1224/114036.088189:ERROR:gbm_wrapper.cc(74)] Failed to get fd  for plane.: No such file or directory (2)
          0|mm       | [6118:1224/114036.088274:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          0|mm       | [6118:1224/114036.088418:ERROR:gbm_wrapper.cc(74)] Failed to get fd  for plane.: No such file or directory (2)
          0|mm       | [6118:1224/114036.088529:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          0|mm       | [6118:1224/114036.088678:ERROR:gbm_wrapper.cc(74)] Failed to get fd  for plane.: No such file or directory (2)
          0|mm       | [6118:1224/114036.088751:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          0|mm       | [6118:1224/114036.088892:ERROR:gbm_wrapper.cc(74)] Failed to get fd  for plane.: No such file or directory (2)
          0|mm       | [6118:1224/114036.088971:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          0|mm       | [6118:1224/114036.089108:ERROR:gbm_wrapper.cc(74)] Failed to get fd  for plane.: No such file or directory (2)
          0|mm       | [6118:1224/114036.089205:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          0|mm       |
          0|mm       | > magicmirror@2.29.0 start
          0|mm       | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
          0|mm       |
          0|mm       | [2024-12-24 11:40:31.951] [LOG]   Starting MagicMirror: v2.29.0
          0|mm       | [2024-12-24 11:40:31.982] [LOG]   Loading config ...
          0|mm       | [2024-12-24 11:40:31.986] [LOG]   config template file not exists,    no envsubst
          0|mm       | [2024-12-24 11:40:32.513] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
          0|mm       | [2024-12-24 11:40:32.578] [INFO]  Your configuration file doesn't contain syntax errors :)
          0|mm       | [2024-12-24 11:40:32.580] [INFO]  Checking modules structure configuration ...
          0|mm       | [2024-12-24 11:40:32.688] [INFO]  Your modules structure configuration doesn't contain errors :)
          0|mm       | [2024-12-24 11:40:32.691] [LOG]   Loading module helpers ...
          0|mm       | [2024-12-24 11:40:32.697] [LOG]   Initializing new module helper ..        .
          0|mm       | [2024-12-24 11:40:32.698] [LOG]   Module helper loaded: MMM-MPlayer
          0|mm       | [2024-12-24 11:40:32.699] [LOG]   All module helpers loaded.
          0|mm       | [2024-12-24 11:40:32.708] [LOG]   Starting server on port 8084 ...
          0|mm       | [2024-12-24 11:40:34.158] [LOG]   Server started ...
          0|mm       | [2024-12-24 11:40:34.162] [LOG]   Connecting socket for: MMM-MPlayer
          0|mm       | [2024-12-24 11:40:34.163] [LOG]   Starting MMM-MPlayer module...
          0|mm       | [2024-12-24 11:40:34.172] [LOG]   Sockets connected & modules started ...
          0|mm       | [2024-12-24 11:40:34.574] [LOG]   Launching application.
          0|mm       | [2024-12-24 11:40:35.869] [INFO]  System information:
          0|mm       | ### SYSTEM:   manufacturer: ; model: ; virtual: false
          0|mm       | ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.62+rpt-rpi-v8
          0|mm       | ### VERSIONS: electron: 31.7.5; used node: 20.18.0; installed node:20.9.0; npm: 10.1.0; pm2: 5.4.3
          0|mm       | ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
          0|mm       | [2024-12-24 11:40:36.738] [INFO]  [MMM-MPlayer] Launched mplayer process for window1 with PID 6190
          0|mm       | [2024-12-24 11:40:36.738] [INFO]  [MMM-MPlayer] mplayer -noborder -monitoraspect 0 -vf rotate=-1 -geometry 10:90 -xy 1920 980 rtsp://192.168.1.32:5        54/live
          0|mm       | [2024-12-24 11:40:37.464] [INFO]  [MMM-MPlayer] mplayer process for window1 exited with code 0
          I checked and I am running the latest VLC according to when I tried to install it
          with:
          sudo apt install vlc
          I run that url on my latop VLC and it works.
          HELP ME, I ve fallen down a rabbit hole here.
            plainbroke @plainbroke
              @evroom
              Crap on a Cracker,
              I was forgetting to put the login information in the url.
              DUH, thanks for the help it works great now…
              So if I want to show say 3 cameras 1 at a time I just add them to the window 1
                                  "rtsp://xxxxx:xxxxx@192.168.1.40:554/stream1",
                                  "rtsp://xxxxx:xxxxx@192.168.1.35:554/live",
                                  "rtsp://xxxxx:xxxxx@192.168.1.32:554/live",
              and now it actually works great.
              Thank you so much for the module.
              I have been looking for this for a long time.
              I am so happy I can veiw my cameras again.
              RTSPStream went byb bye due to no one wanting to work with it anymore…
              Thank you again for this great moduel.
              • plainbrokeP plainbroke has marked this topic as solved on
              • evroomE Offline
                evroom @plainbroke
                @plainbroke said in MMM-MPlayer:
                @evroom
                Crap on a Cracker,
                I like this expression!
                I also waited a long time for this module.
                Only made it available on Github and tweaked it a little.
                When in January the new MM version comes out, I am finally going to reinstall my old setup.
                Good to know that you got it solved.
                Test environment:
                  sdetweil @evroom
                  @evroom said in MMM-MPlayer:
                  if you used develop branch today, on jan 1, you could use my upgrade script and it will switch you back to master and do the update…
                  no need to wait if you have time now…
                  new release also needs a new version of node… SO much fun…
