    Toothbrush integration
    34 Posts 5 Posters 32.0k Views 8 Watching
      Shifty
      i want this integration, too!
      If someone needs this extention and have coding skills this will be magic!
      Tanks a lot!
      Alex
      • O Offline
        onetwankyfive
        This could be pretty neat
          bhepler Module Developer
          A smart toothbrush? We truly do live in an age of wonders.
            dfuerst
            Hi again.
            Trying to modify ianperrin’s MMM-NetworkScanner to check wether the toothbrush is connected or not!
            after pairing the brush in Raspbian it is autodetected without any delay , both availability and absensence are shown instantly.
            the plan is to detect the brush and then show a timer starting at 00:00 on the mirror, counting as long as the brush is connected. lets say: scan every 3 sec. if detect show the timer and start counting, if the brush is not detected anymore stop counting until redetection, is the brush not detected for more than 20 sec reset the timer to 00:00 and dont show it anymore
            As i mentioned, i m a noob in coding.
            i have found the command to check if an bluetoothdevice is connected : ‘hcitool con’
            but wasn’t able to use this command in the Networkscanner, i guess because of the space between ‘hcitool’ and ‘con’
            using the command manually looks as follows:(first with brush off, then with brush on)
            pi@raspberrypi:~/MagicMirror $ hcitool con
            Connections:
            Connections:
            	< Unknown E0:E5:CF:FC:4D:8C handle 64 state 1 lm MASTER
            unsure how i can integrate this command into the MMM-Networkscanner??? and check the MAC !!! help please
              dfuerst
                dfuerst
                  dfuerst
                  ok integrated “hcitool con”, because of the very fast response,
                  had to alter the parsing of NetworkScanner.
                  i think i got the parsing, but networkscanner says NO DEVICES
                  when i “console.log(macAddresses)” , at the end of node_helper script i get during MM in console :
                  MMM-NetworkScanner received SCAN_NETWORK
                  MMM-NetworkScanner is scanning for mac addresses
                  [ ‘E0:E5:CF:FC:4D:8C’ ]
                  shouldn’t this “macAddresses parse” be understand by NetworkScanner? What am i missing here?
                  nodehelper script is as follows:
                   scanNetwork: function() {
                          console.log(this.name + " is scanning for mac addresses");
                          var self = this;
                          var arp = sudo(['hcitool', 'con']);
                          var buffer = '';
                          var errstream = '';
                          arp.stdout.on('data', function (data) {
                              buffer += data;
                          arp.stderr.on('data', function (data) {
                              errstream += data;
                          arp.on('error', function (err) {
                              errstream += err;
                          arp.on('close', function (code) {
                              if (code !== 0) {
                                  console.log(self.name + " received an error running arp-scan: " + code + " - " + errstream);
                                  return;
                              //Parse the response
                              var rows = buffer.split('\n');
                              var macAddresses = [];
                              // HCI-TOOL SCAN table
                              for (var i = 1; i < rows.length; i++) {
                                  var cells = rows[i].split(' ').filter(String);
                                  if (cells[2] && macAddresses.indexOf(cells[2].toUpperCase()) === -1) {
                                      macAddresses.push(cells[2].toUpperCase());
                              self.sendSocketNotification('MAC_ADDRESSES', macAddresses);
                  	    console.log(macAddresses);
                  SvenSommerS 1 Reply Last reply Reply Quote 0
                  • SvenSommerS Offline
                    SvenSommer @dfuerst
                    @dfuerst Hey, I liked your approach how to get the information about a running or a stopped toothbrush.
                    So, I played some time with hcitool within the console and checked the responsive times(if the toothbrush is beeing detected as connected or not, as a turn it on or off). Unfortunately, this wasn’t very reliable nor very accurate.
                    I would suggest a better approach is to use a javascript library for bluetooth such as noble to track if the toothbrush is connected or not.
                    Unfortunately I wasn’t able to get noble running within the MagicMirror framework. I tried to install it with npm anbd several versions of node.js (6.x and 7.x) but got always an error like "Error: Module version mismatch. Expected 50, got 51." within the bluetooth-hci-socket - part of noble.
                    Starting MagicMirror: v2.1.0
                    Loading config ...
                    Loading module helpers ...
                    WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 50, got 51.
                    App threw an error during load
                        at Error (native)
                        at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
                        at Object.Module._extensions..node (module.js:583:18)
                        at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
                        at Module.load (module.js:473:32)
                        at tryModuleLoad (module.js:432:12)
                        at Function.Module._load (module.js:424:3)
                        at Module.require (module.js:483:17)
                        at require (internal/module.js:20:19)
                        at Object. (/home/pi/MagicMirror/modules/MMM-OralB/node_modules/bluetooth-hci-socket/lib/native.js:3:15)
                        at Error (native)
                    I tried rebuilding the noble included packeages and tried it also with a clean Magicmirror installation under node.js 7.x. unfortunately nothing helped.
                    Looking for some building inspiration?
                    Check out my large, thin and metal framed mirror on robstechlog.com.
                    Modules released:
                    MMM-GoogleAnalytics
                    MMM-GrafanaChart
                    MMM-GrafanaGauges
                      dfuerst @SvenSommer
                      @SvenSommer
                      hi. nice to know that someone else (with programming skills) is interested too.
                      ohh yes . ‘hcitool con’ is not perfect, first activation of the toothbrush is very accurate but as you mentioned any interruption is detected unreliably, and late.
                      your problem sounds like the “white screen” issue of mmm-button, so maybe rebuilding/downgrading your electron version might help. (see the forum for this issue)
                      as you can see in the posts above there is an API by OralB. At the end using it would give the highest quality of input/output. as you can also read between the lines i dont know enough about coding stuff, so i went for the low level approach via mmm-networkscanner and to integrate thereafter a simple stopwatch.
                      Any help is highly welcome.
                        SvenSommer
                        I already had a look to the API provided by OralB. It’s quite disappointing.
                        They will provide you with classes to develop tools for android or ios apps. Not what we are looking for right now. :wink:
                        But maybe the documentation could be usefull.
                        I tried to find the forum page you mentioned. Found nothing usefull yet. Maybe you can have a look and help me out here.
                        I made a first attempt with noble and got some pretty nice results by reading out the braodcasted information from my brush.
                        I you wanna try on your own, do the following:
                        1. Install noble in a directory of your choice, by following the instructions on the noble page:
                        sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev
                        sudo ln -s /usr/bin/nodejs /usr/bin/node
                        npm install noble
                        1. Move into the new node_modules/noble/ - folder and create a new file ‘toothbrush.js’ with the following content
                        var async = require('async');
                        var noble = require('./index');
                        var OralB_manufacturerData = 'dc00010205030000000101';
                        console.log('Lookinhg for OralB Toothbrushes with manufacturerData: "' + OralB_manufacturerData +'"');
                        noble.on('stateChange', function(state) {
                          if (state === 'poweredOn') {
                            noble.startScanning();
                          } else {
                            noble.stopScanning();
                        noble.on('discover', function(peripheral) {
                          var advertisement = peripheral.advertisement;
                          console.log('Found device with manufacturerData: "' + advertisement.manufacturerData.toString('hex') +'" localName: ' + advertisement.localName);
                          if (advertisement.manufacturerData.toString('hex') === OralB_manufacturerData) {
                            console.log('peripheral with ID ' + peripheral.id + ' found');
                            var localName = advertisement.localName;
                            var txPowerLevel = advertisement.txPowerLevel;
                            var manufacturerData = advertisement.manufacturerData;
                            var serviceData = advertisement.serviceData;
                            var serviceUuids = advertisement.serviceUuids;
                            if (localName) {
                              console.log('  Local Name        = ' + localName);
                            if (txPowerLevel) {
                              console.log('  TX Power Level    = ' + txPowerLevel);
                            if (manufacturerData) {
                              console.log('  Manufacturer Data = ' + manufacturerData.toString('hex'));
                            if (serviceData) {
                              console.log('  Service Data      = ' + serviceData);
                            if (serviceUuids) {
                              console.log('  Service UUIDs     = ' + serviceUuids);
                            console.log();
                            explore(peripheral);
                        function explore(peripheral) {
                          console.log('services and characteristics:');
                          peripheral.on('disconnect', function() {
                            process.exit(0);
                          peripheral.connect(function(error) {
                            peripheral.discoverServices([], function(error, services) {
                              var serviceIndex = 0;
                              async.whilst(
                                function () {
                                  return (serviceIndex < services.length);
                                function(callback) {
                                  var service = services[serviceIndex];
                                  var serviceInfo = service.uuid;
                                  if (service.name) {
                                    serviceInfo += ' (' + service.name + ')';
                                  console.log(serviceInfo);
                                  service.discoverCharacteristics([], function(error, characteristics) {
                                    var characteristicIndex = 0;
                                    async.whilst(
                                      function () {
                                        return (characteristicIndex < characteristics.length);
                                        var characteristic = characteristics[characteristicIndex];
                                        var characteristicInfo = '  ' + characteristic.uuid;
                                        if (characteristic.name) {
                                          characteristicInfo += ' (' + characteristic.name + ')';
                                        async.series([
                                            characteristic.discoverDescriptors(function(error, descriptors) {
                                              async.detect(
                                                descriptors,
                                                function(descriptor, callback) {
                                                  return callback(descriptor.uuid === '2901');
                                                function(userDescriptionDescriptor){
                                                  if (userDescriptionDescriptor) {
                                                    userDescriptionDescriptor.readValue(function(error, data) {
                                                      if (data) {
                                                        characteristicInfo += ' (' + data.toString() + ')';
                                                      callback();
                                                  } else {
                                                    callback();
                                                characteristicInfo += '\n    properties  ' + characteristic.properties.join(', ');
                                            if (characteristic.properties.indexOf('read') !== -1) {
                                              characteristic.read(function(error, data) {
                                                if (data) {
                                                  var string = data.toString('ascii');
                                                  characteristicInfo += '\n    value       ' + data.toString('hex') + ' | \'' + string + '\'';
                                                callback();
                                            } else {
                                              callback();
                                          function() {
                                            console.log(characteristicInfo);
                                            characteristicIndex++;
                                            callback();
                                      function(error) {
                                        serviceIndex++;
                                        callback();
                                function (err) {
                                  peripheral.disconnect();
                        1. Start the script by with
                        sudo node toothbrush.js
                        Here is what I got:
                        Lookinhg for OralB Toothbrushes with mac address:54:4a:16:21:20:9f
                        peripheral with ID 544a1621209f found
                          Manufacturer Data = dc00010205020000000101
                          Service Data      =
                          Service UUIDs     =
                        1800 (Generic Access)
                          2a00 (Device Name)
                            properties  read
                            value       4f72616c2d4220546f6f74686272757368 | 'Oral-B Toothbrush'
                          2a01 (Appearance)
                            properties  read
                            value       0000 | ''
                          2a02 (Peripheral Privacy Flag)
                            properties  read, write
                            value       00 | ''
                          2a03 (Reconnection Address)
                            value       000000000000 | ''
                          2a04 (Peripheral Preferred Connection Parameters)
                            properties  read
                            value       5000a0000000e803 | 'P h'
                        1801 (Generic Attribute)
                          2a05 (Service Changed)
                            properties  indicate
                        a0f0fff050474d5382084f72616c2d42
                          a0f0fff150474d5382084f72616c2d42 (Command)
                            properties  read, write, notify
                            value       00 | ''
                          a0f0fff250474d5382084f72616c2d42 (Data)
                            value       00000000 | ''
                          a0f0fff350474d5382084f72616c2d42 (Auth)
                            value       00 | ''
                          a0f0fff450474d5382084f72616c2d42 (Secret)
                            value       00000000 | ''
                        a0f0ff0050474d5382084f72616c2d42
                          a0f0ff0150474d5382084f72616c2d42 (Handle ID)
                            properties  read
                            value       00000000 | ''
                          a0f0ff0250474d5382084f72616c2d42 (Handle Type)
                            properties  read
                            value       02 | ''
                          a0f0ff0350474d5382084f72616c2d42 (User Account)
                            properties  read
                            value       01 | ''
                          a0f0ff0450474d5382084f72616c2d42 (Device State)
                            properties  read, notify
                            value       0200 | ''
                          a0f0ff0550474d5382084f72616c2d42 (Battery Level)
                            value       63 | 'c'
                          a0f0ff0650474d5382084f72616c2d42 (Button State)
                            value       00000000 | ''
                          a0f0ff0750474d5382084f72616c2d42 (Brushing Mode)
                            value       01 | ''
                          a0f0ff0850474d5382084f72616c2d42 (Brushing Time)
                            value       0000 | ''
                          a0f0ff0950474d5382084f72616c2d42 (Quadrant)
                            value       00 | ''
                          a0f0ff0a50474d5382084f72616c2d42 (Smiley)
                            value       00 | ''
                          a0f0ff0b50474d5382084f72616c2d42 (Pressure Sensor)
                            value       00 | ''
                          a0f0ff0c50474d5382084f72616c2d42 (Cache)
                            value        | ''
                        a0f0ff2050474d5382084f72616c2d42
                          a0f0ff2150474d5382084f72616c2d42 (Status)
                            value       8100 | ''
                          a0f0ff2250474d5382084f72616c2d42 (RTC)
                            value       97d81120 | 'X '
                          a0f0ff2350474d5382084f72616c2d42 (Timezone)
                        '   value       0d | '
                          a0f0ff2450474d5382084f72616c2d42 (Brushing Timer)
                            value       0f | ''
                          a0f0ff2550474d5382084f72616c2d42 (Brushing Modes)
                            value       0105020403000000 | ''
                        PuTTY  a0f0ff2650474d5382084f72616c2d42 (Quadrant Times)
                            value       1e001e001e001e000000000000000000 | ''
                          a0f0ff2750474d5382084f72616c2d42 (Tongue Time)
                            value       00 | ''
                          a0f0ff2850474d5382084f72616c2d42 (Pressure)
                            value       03 | ''
                          a0f0ff2950474d5382084f72616c2d42 (Data)
                            properties  read
                            value       68d6fd1f7700010100000063d1e7fd1f | 'hV}wcQg}'
                          a0f0ff2a50474d5382084f72616c2d42 (Flight Mode)
                            value       00 | ''
                        Modules released:
                        MMM-GoogleAnalytics
                        MMM-GrafanaChart
                        MMM-GrafanaGauges
                          dfuerst
                          try :
                          cd ~/MagicMirror/modules/MMM-Button
                          sudo npm rebuild --runtime=electron --target=1.4.6 --disturl=https://atom.io/download/atom-shell --abi=50
                          D 1 Reply Last reply Reply Quote 2
                            dfuerst @dfuerst
                            not in the mmmbutton folder of course
                              SvenSommer @dfuerst
                              @dfuerst It worked! Thank you very much!!
                              Modules released:
                              MMM-GoogleAnalytics
                              MMM-GrafanaChart
                              MMM-GrafanaGauges
                                dfuerst
                                exciting.
                                you get everything needed for a really high quality piece of module.
                                battery level
                                brushing mode
                                brushing time
                                pressure
                                quadrant
                                smiley
                                i am a bit concerned about the user readout. (Do you think it might be possible to determine which of eg. 3 brushes is presently used?)
                                  SvenSommer
                                  Hey,
                                  I have bad news.
                                  The readable informations provided by the brush via bluetooth aren’t changing. Not while the toothbrush is running. I guess the characteristics we were able to readout, are used like placeholder for the sdk.
                                  Second try was to get notified if a broadcastd value (characteristic) is changing. Nothing here either.
                                  Every characteristic (like brushing time, battery level, etc) is using the same id and only provides a different name. So a notification service wasn’t possible.
                                  Seems like there is no way to get the information read out via bluetooth without using the sdk…
                                  I also tried to include the provided sdk into the MM-framework.
                                  Therefore I had a try with node-java, which allows to run java classes within nodejs. The files from the android sdk are java classes.
                                  It went pretty nice in the beginning. But then I ran into an error
                                  ‘Expected stackmap frame at this location.’ which is caused by the compiling the sdk classes on another system (linux not android), I would assume.
                                  I was amazed that I wasn’t able to find any code snippets of frameworks from other developers to “hack the brush” when I first started. By now its seems obvious that it’s not that easy.
                                  If anybody else is gonna have a try, please don’t hesitate to ask if you need assistance.
                                  Modules released:
                                  MMM-GoogleAnalytics
                                  MMM-GrafanaChart
                                  MMM-GrafanaGauges
                                    dfuerst
                                    should we go back to the “low level approach”?
                                    as i understand you can instantly determine if there is a certain brush(matching the macaddress via the config) within the bluetooth range upon activation of these.
                                    any interruption of brushing is detected, 20 sec or so too late of course i know, when the brush goes offline again.
                                    so can we start a stopwatch (let’s say at the center position) upon detection, stopping when not detecting the brush anymore and reseting to 00:00 after 2min followed by vanishing the stopwatch.
                                    i know that this wouldn’t be very accurate, but better then nothing. giving the user a feel for the time
                                    and for a pro like you i guess this would be very easy to develop.
                                    examples for start/stop/reset timers are quiet a lot available in the web.
                                    how do you think about
                                      dfuerst
                                      maybe contacting oralB via the developer program homepage ( https://developer.oralb.com/ ) could be helpful. there might be a support team helping developers creating new apps for their brush
                                        SvenSommer
                                        Hey,
                                        guided by the idea of your simple approach I wrote a little script which tries to detect, if the brush is running or not.
                                        Caused by the bluetooth behavior of the brush it is very limited in guessing when the brush was stopped or resumed.
                                        Here are some details:
                                        • If the toothbrush is started bluetooth is activated for 3 Seconds.
                                        • If the brush is paused/stopped bluetooth is activated again for 32 Seconds.
                                        This leads to the following limited possiblities in tracking a brush session.
                                        • A start of a session is only trackable, if the programm/script has started with a (for 32 seconds) silent brush.
                                        • A stop is only trackable 3 seconds after start.
                                        • A stop/pause leads to a 32 Seconds “cooldown phase”, were no tracking is possible. This will reset the timer to 0:00.
                                        This is only helpfull if you do not interrupt you brushing session. :smile:
                                        If you wanna try the current setup you can run the script by:
                                        1. Enter your module-directory: cd ~/MagicMirror/modules
                                        2. Clone repository : git clone https://github.com/SvenSommer/MMM-OralB
                                        3. Enter new directory: cd ~/MagicMirror/modules/MMM-OralB
                                        4. Install dependencies: sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev
                                        5. Install noble module: npm install noble
                                        6. Exceute helper programm to find your brushID (this is not the mac-address): sudo node findBrushId.js
                                          This should lead to a output like
                                        Searching for OralB Toothbrushes with manufacturerData: "dc00010205030000000101"...
                                        changed state to:poweredOn
                                        Found OralB Tootbrush with ID: 544a1621209f
                                        1. Copy and paste your ID into the brushTimer.js file: sudo nano brushTimer.js
                                          (Save and exit with STRG + O and STRG + X )
                                        "use strict";
                                        var NodeHelper = require("node_helper");
                                        var noble = require('noble');
                                        //Copy Paste your ID here
                                        var toothbrush_uuid = '544a1621209f';
                                        1. Run script with sudo node brushTimer.js
                                          This should lead to an output like:
                                        scanning started...
                                        Toothbrush is running
                                        0:1
                                        0:2
                                        0:3
                                        0:4
                                        0:5
                                        0:6
                                        0:7
                                        0:8
                                        0:9
                                        0:10
                                        0:11
                                        0:12
                                        0:13
                                        0:14
                                        0:15
                                        0:16
                                        0:17
                                        0:18
                                        Toothbrush stopped. "Cool down" for 32 seconds needed!
                                        Modules released:
                                        MMM-GoogleAnalytics
                                        MMM-GrafanaChart
                                        MMM-GrafanaGauges
                                          dfuerst
                                          Wow that was really fast!
                                          Testing your script brought me to 2 problems:
                                          testing brushTimer.js in the console worked for detecting the brush but did never stop, also not after 32 sec!
                                          including your module into the MM i got an error message upon activating the brush:
                                          “noble warning: unknown handle 64 disconnected!”
                                          “scanning was started. Everything is working fine.”
                                          this two message’s i get upon every activation, so the MM show always SEARCHING…
                                          any suggestions?
                                            dfuerst
                                            Now i made a reinstall.
                                            brushtimer.js works until i rebuild electron!!!
                                            but without rebuilding MM just shows the white screen error.
                                            after rebuilding i get this upon sudo node brushTimer.js:
                                            pi@raspberrypi:~/MagicMirror/modules/MMM-OralB $ sudo node brushTimer.js
                                            module.js:597
                                              return process.dlopen(module, path._makeLong(filename));
                                            Error: Module version mismatch. Expected 48, got 50.
                                                at Error (native)
                                                at Object.Module._extensions..node (module.js:597:18)
                                                at Module.load (module.js:487:32)
                                                at tryModuleLoad (module.js:446:12)
                                                at Function.Module._load (module.js:438:3)
                                                at Module.require (module.js:497:17)
                                                at Module._compile (module.js:570:32)
                                                at Object.Module._extensions..js (module.js:579:10)
                                            so, after this rebuild i get the error of my previous post in MM
