    Toothbrush integration
    34 Posts 5 Posters 32.8k Views 8 Watching
      dfuerst
        dfuerst
          dfuerst
          ok integrated “hcitool con”, because of the very fast response,
          had to alter the parsing of NetworkScanner.
          i think i got the parsing, but networkscanner says NO DEVICES
          when i “console.log(macAddresses)” , at the end of node_helper script i get during MM in console :
          MMM-NetworkScanner received SCAN_NETWORK
          MMM-NetworkScanner is scanning for mac addresses
          [ ‘E0:E5:CF:FC:4D:8C’ ]
          shouldn’t this “macAddresses parse” be understand by NetworkScanner? What am i missing here?
          nodehelper script is as follows:
           scanNetwork: function() {
                  console.log(this.name + " is scanning for mac addresses");
                  var self = this;
                  var arp = sudo(['hcitool', 'con']);
                  var buffer = '';
                  var errstream = '';
                  arp.stdout.on('data', function (data) {
                      buffer += data;
                  arp.stderr.on('data', function (data) {
                      errstream += data;
                  arp.on('error', function (err) {
                      errstream += err;
                  arp.on('close', function (code) {
                      if (code !== 0) {
                          console.log(self.name + " received an error running arp-scan: " + code + " - " + errstream);
                          return;
                      //Parse the response
                      var rows = buffer.split('\n');
                      var macAddresses = [];
                      // HCI-TOOL SCAN table
                      for (var i = 1; i < rows.length; i++) {
                          var cells = rows[i].split(' ').filter(String);
                          if (cells[2] && macAddresses.indexOf(cells[2].toUpperCase()) === -1) {
                              macAddresses.push(cells[2].toUpperCase());
                      self.sendSocketNotification('MAC_ADDRESSES', macAddresses);
          	    console.log(macAddresses);
          SvenSommerS 1 Reply Last reply
          • SvenSommerS
            SvenSommer @dfuerst
            @dfuerst Hey, I liked your approach how to get the information about a running or a stopped toothbrush.
            So, I played some time with hcitool within the console and checked the responsive times(if the toothbrush is beeing detected as connected or not, as a turn it on or off). Unfortunately, this wasn’t very reliable nor very accurate.
            I would suggest a better approach is to use a javascript library for bluetooth such as noble to track if the toothbrush is connected or not.
            Unfortunately I wasn’t able to get noble running within the MagicMirror framework. I tried to install it with npm anbd several versions of node.js (6.x and 7.x) but got always an error like "Error: Module version mismatch. Expected 50, got 51." within the bluetooth-hci-socket - part of noble.
            Starting MagicMirror: v2.1.0
            Loading config ...
            Loading module helpers ...
            WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 50, got 51.
            App threw an error during load
                at Error (native)
                at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
                at Object.Module._extensions..node (module.js:583:18)
                at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
                at Module.load (module.js:473:32)
                at tryModuleLoad (module.js:432:12)
                at Function.Module._load (module.js:424:3)
                at Module.require (module.js:483:17)
                at require (internal/module.js:20:19)
                at Object. (/home/pi/MagicMirror/modules/MMM-OralB/node_modules/bluetooth-hci-socket/lib/native.js:3:15)
                at Error (native)
            I tried rebuilding the noble included packeages and tried it also with a clean Magicmirror installation under node.js 7.x. unfortunately nothing helped.
            Looking for some building inspiration?
            Check out my large, thin and metal framed mirror on robstechlog.com.
            Modules released:
            MMM-GoogleAnalytics
            MMM-GrafanaChart
            MMM-GrafanaGauges
            D 1 Reply Last reply
              dfuerst @SvenSommer
              @SvenSommer
              hi. nice to know that someone else (with programming skills) is interested too.
              ohh yes . ‘hcitool con’ is not perfect, first activation of the toothbrush is very accurate but as you mentioned any interruption is detected unreliably, and late.
              your problem sounds like the “white screen” issue of mmm-button, so maybe rebuilding/downgrading your electron version might help. (see the forum for this issue)
              as you can see in the posts above there is an API by OralB. At the end using it would give the highest quality of input/output. as you can also read between the lines i dont know enough about coding stuff, so i went for the low level approach via mmm-networkscanner and to integrate thereafter a simple stopwatch.
              Any help is highly welcome.
              • SvenSommerS
                SvenSommer
                I already had a look to the API provided by OralB. It’s quite disappointing.
                They will provide you with classes to develop tools for android or ios apps. Not what we are looking for right now. :wink:
                But maybe the documentation could be usefull.
                I tried to find the forum page you mentioned. Found nothing usefull yet. Maybe you can have a look and help me out here.
                I made a first attempt with noble and got some pretty nice results by reading out the braodcasted information from my brush.
                I you wanna try on your own, do the following:
                1. Install noble in a directory of your choice, by following the instructions on the noble page:
                sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev
                sudo ln -s /usr/bin/nodejs /usr/bin/node
                npm install noble
                1. Move into the new node_modules/noble/ - folder and create a new file ‘toothbrush.js’ with the following content
                var async = require('async');
                var noble = require('./index');
                var OralB_manufacturerData = 'dc00010205030000000101';
                console.log('Lookinhg for OralB Toothbrushes with manufacturerData: "' + OralB_manufacturerData +'"');
                noble.on('stateChange', function(state) {
                  if (state === 'poweredOn') {
                    noble.startScanning();
                  } else {
                    noble.stopScanning();
                noble.on('discover', function(peripheral) {
                  var advertisement = peripheral.advertisement;
                  console.log('Found device with manufacturerData: "' + advertisement.manufacturerData.toString('hex') +'" localName: ' + advertisement.localName);
                  if (advertisement.manufacturerData.toString('hex') === OralB_manufacturerData) {
                    console.log('peripheral with ID ' + peripheral.id + ' found');
                    var localName = advertisement.localName;
                    var txPowerLevel = advertisement.txPowerLevel;
                    var manufacturerData = advertisement.manufacturerData;
                    var serviceData = advertisement.serviceData;
                    var serviceUuids = advertisement.serviceUuids;
                    if (localName) {
                      console.log('  Local Name        = ' + localName);
                    if (txPowerLevel) {
                      console.log('  TX Power Level    = ' + txPowerLevel);
                    if (manufacturerData) {
                      console.log('  Manufacturer Data = ' + manufacturerData.toString('hex'));
                    if (serviceData) {
                      console.log('  Service Data      = ' + serviceData);
                    if (serviceUuids) {
                      console.log('  Service UUIDs     = ' + serviceUuids);
                    console.log();
                    explore(peripheral);
                function explore(peripheral) {
                  console.log('services and characteristics:');
                  peripheral.on('disconnect', function() {
                    process.exit(0);
                  peripheral.connect(function(error) {
                    peripheral.discoverServices([], function(error, services) {
                      var serviceIndex = 0;
                      async.whilst(
                        function () {
                          return (serviceIndex < services.length);
                        function(callback) {
                          var service = services[serviceIndex];
                          var serviceInfo = service.uuid;
                          if (service.name) {
                            serviceInfo += ' (' + service.name + ')';
                          console.log(serviceInfo);
                          service.discoverCharacteristics([], function(error, characteristics) {
                            var characteristicIndex = 0;
                            async.whilst(
                              function () {
                                return (characteristicIndex < characteristics.length);
                                var characteristic = characteristics[characteristicIndex];
                                var characteristicInfo = '  ' + characteristic.uuid;
                                if (characteristic.name) {
                                  characteristicInfo += ' (' + characteristic.name + ')';
                                async.series([
                                    characteristic.discoverDescriptors(function(error, descriptors) {
                                      async.detect(
                                        descriptors,
                                        function(descriptor, callback) {
                                          return callback(descriptor.uuid === '2901');
                                        function(userDescriptionDescriptor){
                                          if (userDescriptionDescriptor) {
                                            userDescriptionDescriptor.readValue(function(error, data) {
                                              if (data) {
                                                characteristicInfo += ' (' + data.toString() + ')';
                                              callback();
                                          } else {
                                            callback();
                                        characteristicInfo += '\n    properties  ' + characteristic.properties.join(', ');
                                    if (characteristic.properties.indexOf('read') !== -1) {
                                      characteristic.read(function(error, data) {
                                        if (data) {
                                          var string = data.toString('ascii');
                                          characteristicInfo += '\n    value       ' + data.toString('hex') + ' | \'' + string + '\'';
                                        callback();
                                    } else {
                                      callback();
                                  function() {
                                    console.log(characteristicInfo);
                                    characteristicIndex++;
                                    callback();
                              function(error) {
                                serviceIndex++;
                                callback();
                        function (err) {
                          peripheral.disconnect();
                1. Start the script by with
                sudo node toothbrush.js
                Here is what I got:
                Lookinhg for OralB Toothbrushes with mac address:54:4a:16:21:20:9f
                peripheral with ID 544a1621209f found
                  Manufacturer Data = dc00010205020000000101
                  Service Data      =
                  Service UUIDs     =
                1800 (Generic Access)
                  2a00 (Device Name)
                    properties  read
                    value       4f72616c2d4220546f6f74686272757368 | 'Oral-B Toothbrush'
                  2a01 (Appearance)
                    properties  read
                    value       0000 | ''
                  2a02 (Peripheral Privacy Flag)
                    properties  read, write
                    value       00 | ''
                  2a03 (Reconnection Address)
                    value       000000000000 | ''
                  2a04 (Peripheral Preferred Connection Parameters)
                    properties  read
                    value       5000a0000000e803 | 'P h'
                1801 (Generic Attribute)
                  2a05 (Service Changed)
                    properties  indicate
                a0f0fff050474d5382084f72616c2d42
                  a0f0fff150474d5382084f72616c2d42 (Command)
                    properties  read, write, notify
                    value       00 | ''
                  a0f0fff250474d5382084f72616c2d42 (Data)
                    value       00000000 | ''
                  a0f0fff350474d5382084f72616c2d42 (Auth)
                    value       00 | ''
                  a0f0fff450474d5382084f72616c2d42 (Secret)
                    value       00000000 | ''
                a0f0ff0050474d5382084f72616c2d42
                  a0f0ff0150474d5382084f72616c2d42 (Handle ID)
                    properties  read
                    value       00000000 | ''
                  a0f0ff0250474d5382084f72616c2d42 (Handle Type)
                    properties  read
                    value       02 | ''
                  a0f0ff0350474d5382084f72616c2d42 (User Account)
                    properties  read
                    value       01 | ''
                  a0f0ff0450474d5382084f72616c2d42 (Device State)
                    properties  read, notify
                    value       0200 | ''
                  a0f0ff0550474d5382084f72616c2d42 (Battery Level)
                    value       63 | 'c'
                  a0f0ff0650474d5382084f72616c2d42 (Button State)
                    value       00000000 | ''
                  a0f0ff0750474d5382084f72616c2d42 (Brushing Mode)
                    value       01 | ''
                  a0f0ff0850474d5382084f72616c2d42 (Brushing Time)
                    value       0000 | ''
                  a0f0ff0950474d5382084f72616c2d42 (Quadrant)
                    value       00 | ''
                  a0f0ff0a50474d5382084f72616c2d42 (Smiley)
                    value       00 | ''
                  a0f0ff0b50474d5382084f72616c2d42 (Pressure Sensor)
                    value       00 | ''
                  a0f0ff0c50474d5382084f72616c2d42 (Cache)
                    value        | ''
                a0f0ff2050474d5382084f72616c2d42
                  a0f0ff2150474d5382084f72616c2d42 (Status)
                    value       8100 | ''
                  a0f0ff2250474d5382084f72616c2d42 (RTC)
                    value       97d81120 | 'X '
                  a0f0ff2350474d5382084f72616c2d42 (Timezone)
                '   value       0d | '
                  a0f0ff2450474d5382084f72616c2d42 (Brushing Timer)
                    value       0f | ''
                  a0f0ff2550474d5382084f72616c2d42 (Brushing Modes)
                    value       0105020403000000 | ''
                PuTTY  a0f0ff2650474d5382084f72616c2d42 (Quadrant Times)
                    value       1e001e001e001e000000000000000000 | ''
                  a0f0ff2750474d5382084f72616c2d42 (Tongue Time)
                    value       00 | ''
                  a0f0ff2850474d5382084f72616c2d42 (Pressure)
                    value       03 | ''
                  a0f0ff2950474d5382084f72616c2d42 (Data)
                    properties  read
                    value       68d6fd1f7700010100000063d1e7fd1f | 'hV}wcQg}'
                  a0f0ff2a50474d5382084f72616c2d42 (Flight Mode)
                    value       00 | ''
                Modules released:
                MMM-GoogleAnalytics
                MMM-GrafanaChart
                MMM-GrafanaGauges
                  dfuerst
                  try :
                  cd ~/MagicMirror/modules/MMM-Button
                  sudo npm rebuild --runtime=electron --target=1.4.6 --disturl=https://atom.io/download/atom-shell --abi=50
                  Reply Quote 2
                    dfuerst @dfuerst
                    not in the mmmbutton folder of course
                    • SvenSommerS
                      SvenSommer @dfuerst
                      @dfuerst It worked! Thank you very much!!
                      Modules released:
                      MMM-GoogleAnalytics
                      MMM-GrafanaChart
                      MMM-GrafanaGauges
                        dfuerst
                        exciting.
                        you get everything needed for a really high quality piece of module.
                        battery level
                        brushing mode
                        brushing time
                        pressure
                        quadrant
                        smiley
                        i am a bit concerned about the user readout. (Do you think it might be possible to determine which of eg. 3 brushes is presently used?)
                        • SvenSommerS
                          SvenSommer
                          Hey,
                          I have bad news.
                          The readable informations provided by the brush via bluetooth aren’t changing. Not while the toothbrush is running. I guess the characteristics we were able to readout, are used like placeholder for the sdk.
                          Second try was to get notified if a broadcastd value (characteristic) is changing. Nothing here either.
                          Every characteristic (like brushing time, battery level, etc) is using the same id and only provides a different name. So a notification service wasn’t possible.
                          Seems like there is no way to get the information read out via bluetooth without using the sdk…
                          I also tried to include the provided sdk into the MM-framework.
                          Therefore I had a try with node-java, which allows to run java classes within nodejs. The files from the android sdk are java classes.
                          It went pretty nice in the beginning. But then I ran into an error
                          ‘Expected stackmap frame at this location.’ which is caused by the compiling the sdk classes on another system (linux not android), I would assume.
                          I was amazed that I wasn’t able to find any code snippets of frameworks from other developers to “hack the brush” when I first started. By now its seems obvious that it’s not that easy.
                          If anybody else is gonna have a try, please don’t hesitate to ask if you need assistance.
                          Modules released:
                          MMM-GoogleAnalytics
                          MMM-GrafanaChart
                          MMM-GrafanaGauges
                            dfuerst
                            should we go back to the “low level approach”?
                            as i understand you can instantly determine if there is a certain brush(matching the macaddress via the config) within the bluetooth range upon activation of these.
                            any interruption of brushing is detected, 20 sec or so too late of course i know, when the brush goes offline again.
                            so can we start a stopwatch (let’s say at the center position) upon detection, stopping when not detecting the brush anymore and reseting to 00:00 after 2min followed by vanishing the stopwatch.
                            i know that this wouldn’t be very accurate, but better then nothing. giving the user a feel for the time
                            and for a pro like you i guess this would be very easy to develop.
                            examples for start/stop/reset timers are quiet a lot available in the web.
                            how do you think about
                              dfuerst
                              maybe contacting oralB via the developer program homepage ( https://developer.oralb.com/ ) could be helpful. there might be a support team helping developers creating new apps for their brush
                              • SvenSommerS
                                SvenSommer
                                Hey,
                                guided by the idea of your simple approach I wrote a little script which tries to detect, if the brush is running or not.
                                Caused by the bluetooth behavior of the brush it is very limited in guessing when the brush was stopped or resumed.
                                Here are some details:
                                • If the toothbrush is started bluetooth is activated for 3 Seconds.
                                • If the brush is paused/stopped bluetooth is activated again for 32 Seconds.
                                This leads to the following limited possiblities in tracking a brush session.
                                • A start of a session is only trackable, if the programm/script has started with a (for 32 seconds) silent brush.
                                • A stop is only trackable 3 seconds after start.
                                • A stop/pause leads to a 32 Seconds “cooldown phase”, were no tracking is possible. This will reset the timer to 0:00.
                                This is only helpfull if you do not interrupt you brushing session. :smile:
                                If you wanna try the current setup you can run the script by:
                                1. Enter your module-directory: cd ~/MagicMirror/modules
                                2. Clone repository : git clone https://github.com/SvenSommer/MMM-OralB
                                3. Enter new directory: cd ~/MagicMirror/modules/MMM-OralB
                                4. Install dependencies: sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev
                                5. Install noble module: npm install noble
                                6. Exceute helper programm to find your brushID (this is not the mac-address): sudo node findBrushId.js
                                  This should lead to a output like
                                Searching for OralB Toothbrushes with manufacturerData: "dc00010205030000000101"...
                                changed state to:poweredOn
                                Found OralB Tootbrush with ID: 544a1621209f
                                1. Copy and paste your ID into the brushTimer.js file: sudo nano brushTimer.js
                                  (Save and exit with STRG + O and STRG + X )
                                "use strict";
                                var NodeHelper = require("node_helper");
                                var noble = require('noble');
                                //Copy Paste your ID here
                                var toothbrush_uuid = '544a1621209f';
                                1. Run script with sudo node brushTimer.js
                                  This should lead to an output like:
                                scanning started...
                                Toothbrush is running
                                0:1
                                0:2
                                0:3
                                0:4
                                0:5
                                0:6
                                0:7
                                0:8
                                0:9
                                0:10
                                0:11
                                0:12
                                0:13
                                0:14
                                0:15
                                0:16
                                0:17
                                0:18
                                Toothbrush stopped. "Cool down" for 32 seconds needed!
                                Modules released:
                                MMM-GoogleAnalytics
                                MMM-GrafanaChart
                                MMM-GrafanaGauges
                                  dfuerst
                                  Wow that was really fast!
                                  Testing your script brought me to 2 problems:
                                  testing brushTimer.js in the console worked for detecting the brush but did never stop, also not after 32 sec!
                                  including your module into the MM i got an error message upon activating the brush:
                                  “noble warning: unknown handle 64 disconnected!”
                                  “scanning was started. Everything is working fine.”
                                  this two message’s i get upon every activation, so the MM show always SEARCHING…
                                  any suggestions?
                                    dfuerst
                                    Now i made a reinstall.
                                    brushtimer.js works until i rebuild electron!!!
                                    but without rebuilding MM just shows the white screen error.
                                    after rebuilding i get this upon sudo node brushTimer.js:
                                    pi@raspberrypi:~/MagicMirror/modules/MMM-OralB $ sudo node brushTimer.js
                                    module.js:597
                                      return process.dlopen(module, path._makeLong(filename));
                                    Error: Module version mismatch. Expected 48, got 50.
                                        at Error (native)
                                        at Object.Module._extensions..node (module.js:597:18)
                                        at Module.load (module.js:487:32)
                                        at tryModuleLoad (module.js:446:12)
                                        at Function.Module._load (module.js:438:3)
                                        at Module.require (module.js:497:17)
                                        at Module._compile (module.js:570:32)
                                        at Object.Module._extensions..js (module.js:579:10)
                                    so, after this rebuild i get the error of my previous post in MM
                                    • SvenSommerS
                                      SvenSommer @dfuerst
                                      @dfuerst
                                      Module version mismatch-Error
                                      Just to summarize and for clarification:
                                      The Module version mismatch. Expected 48, got 50
                                      or
                                      NODE_MODULE_VERSION 50. This version of Node.js requires
                                      NODE_MODULE_VERSION 51. Please try re-compiling or re-installing
                                      is a known “bug”, which we were able to solve by the rebuilding of electron as you posted a few days ago.
                                      So if you want to use the module in MM you have to use this statement in the MMM-OralB-folder:
                                      If you want to test brushtimer.js-script standalone in the console, you need to build the packeges in the MMM-OralB-folder with
                                      npm rebuild
                                      Behavior of brushTimer.js script
                                      So if I understood you correctly, you were able to start the timer, but it never stopped?
                                      For a better understanding I added some debug information in the brushtimer.js -script. Cut you please trigger an update by
                                      git pull
                                      and try the following scenarios and provide me with the console output text.
                                      1. Start the Brush; wait like 10 seconds and stop.
                                      2. Start and stop within 3 seconds.
                                      3. Start, wait like 10 seconds and stop. Start again within the next 10 seconds for like 5 seconds.
                                      4. Start, wait like 10 seconds and stop. Start again after 40 seconds and stop whenever you like.
                                      Behavior of the module within the MM-framework
                                      this two message’s i get upon every activation, so the MM show always SEARCHING…"
                                      Actually this behavior is the intended action right now. As I wrote in this Bug Hunt Post I have problems in bringing noble alive within MM²-framework.
                                      Surprisingly you aren’t suffering from this error, so could you please tell me:
                                      • Which platform (Rasperry Pi 2/3, etc.),
                                      • Node - version: node --version
                                      • npm - version: npm --version
                                      • MagicMirror: cd ~/MagicMirror/ and DISPLAY=:0 npm start
                                      you are using?
                                      Modules released:
                                      MMM-GoogleAnalytics
                                      MMM-GrafanaChart
                                      MMM-GrafanaGauges
                                        dfuerst
                                        of course, i used the electron downgrade. obviously i didn’t know that i have to enter " npm rebuild" to test the .js, sorry for that.
                                        you understood me correct. the timer never stopped, i will check that again after git pull
                                        as i 'm abroad till monday i will provide this infos to you on monday.
                                        you wrote the error is the xpected behaviour? as i mentioned MM showed just SEARCHING…
                                        many thanks for your effort
                                        • SvenSommerS
                                          SvenSommer
                                          For the Bug Hunt Post I reduced the code of the MM-scripts to a absolute minmum.
                                          That’s the reason the module is always showing ‘SEARCHING…’ right now.
                                          If the scripts would work as exspected the console output would show scanning was started. Everything is working fine. all the time the MM² is started.
                                          Thats all I’m hoping to see right now.
                                          Modules released:
                                          MMM-GoogleAnalytics
                                          MMM-GrafanaChart
                                          MMM-GrafanaGauges
                                            dfuerst
                                            ok. i understand. full reply on monday
