    unable to get noble package running
    6 Posts 4 Posters 5.2k Views 5 Watching
    • SvenSommerS Offline
      SvenSommer
      Platform: Raspberry Pi 3
      Node Version: v7.4.0
      MagicMirror Version: v2.1.0
      Description: For bluetooth integration I would like to add noble to a MM²-module. Whith this package I was able to interact with bluetooth devices when I ran nodejs-scripts without the MM²-framework. When I try to integrate it within the node_helper.js. I’m not able to initialise the blueetoh device.
      This is simply done by
      var noble = require('noble');
      noble.on('stateChange', function(state) {
          if (state === 'poweredOn') {
              noble.startScanning([], true);
              console.log('scanning started...');
          else  {
              noble.stopScanning();
              console.log('scanning stopped.');
      Within node_helper there is now response, no error message. Just nothing happens.
      If I run a script in the same folder, outside of MM²-Framework with
      sudo node testscript.js
      everytthing is working fine.
      Steps to Reproduce:
      1. To test the working testscript:
      • Enter your module-directory: cd ~/MagicMirror/modules
      • Clone repository : git clone https://github.com/SvenSommer/MMM-OralB
      • Enter new directory: cd ~/MagicMirror/modules/MMM-OralB
      • Install dependencies: sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev
      • Install noble module: npm install noble
      • Exceute testscript:sudo node testscript.js
      • This should lead to a output like
      scanning was started. Everything is working fine.
      1. To test the node_helper:
      • Excute first five steps from above.
      • For compatibility reasons run:
      sudo npm rebuild --runtime=electron --target=1.4.6 --disturl=https://atom.io/download/atom-shell --abi=50
      • Integrate module in config-file
              module: 'MMM-OralB',
              position: 'bottom_left',
      • Start MM², so the module gets loaded.
      Expected Results: Same console output: scanning was started. Everything is working fine.
      Actual Results: Nothing no output. No error. Pure deadly silence. :)
      Configuration: Here the config.js:
      var config = {
      	port: 8080,
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1","::ffff:192.168.188.22"],
      	language: 'de',
      	timeFormat: 24,
      	units: 'metric',
      			module: 'alert',
      			module: 'clock',
      			position: 'center'
      Additional Notes: Next to noble is a module to provide advertising Ble-Services its called bleno (from the same developer). This was successfully integrated in an module by @aschulz90. I tried to adapt to his code to find an error in my code. But this wasn’t helping either.
      https://github.com/aschulz90/ble_app_interface
      Looking for some building inspiration?
      Check out my large, thin and metal framed mirror on robstechlog.com.
      Modules released:
      MMM-GoogleAnalytics
      MMM-GrafanaChart
      MMM-GrafanaGauges
      • aschulz90A Offline
        aschulz90
        I have tested your module (both in MM and stand-alone) and in both cases i get "scanning was started. Everything is working fine." shown in the console (i use a RaspberryPi 2 with an USB-Bluetooth adapter).
        Are you runnung MagicMirror with sudo-rights? If there is no console output, then it indicates, that the bluetooth adapter wasn’t started (no “stateChange”-event).
        Is my module fully working for you? I currently can’t think of any reason it should only work in one of the both cases (except for the “version mismatch”-error).
        SvenSommerS 1 Reply Last reply Reply Quote 0
          SvenSommer @aschulz90
          @aschulz90
          Thanks for your effort and you for quick help. After using a totally new image and installing everything again. I finally started the MM² with sudo-rights without using a ssh-connection.
          This finally solved my issue.
          Via ssh-connection I’m unable to start the MM². I tried DISPLAY=:0 sudo npm start. This caused
          > magicmirror@2.1.0 start /home/pi/MagicMirror
          > electron js/electron.js
          No protocol specified
          npm ERR! Linux 4.4.45-v7+
          npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
          npm ERR! node v6.9.4
          npm ERR! npm  v3.10.10
          npm ERR! code ELIFECYCLE
          npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
          npm ERR! Exit status 1
          Is there a way to start the MM² via ssh with sudo rights?
          Modules released:
          MMM-GoogleAnalytics
          MMM-GrafanaChart
          MMM-GrafanaGauges
          aschulz90A OdomLinxO 2 Replies Last reply Reply Quote 0
            aschulz90 @SvenSommer
            @SvenSommer
            Here the following command is suggested:
            DISPLAY=:0 nohup npm start &
            • OdomLinxO Offline
              OdomLinx @SvenSommer
              @SvenSommer Late but…
              https://github.com/sandeepmistry/noble#running-without-rootsudo
              Running without root/sudo
              Run the following command:
              sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
              This grants the node binary cap_net_raw privileges, so it can start/stop BLE advertising.
              Note: The above command requires setcap to be installed, it can be installed using the following:
              sudo apt-get install libcap2-bin
              This works on my Zero W with Debian Stretch
              • K Offline
                kunakasaki
                @SvenSommer this solution worked for ur project?
                Having the same problem to run noble via ssh.
                for me the command : sudo setcap cap_net_raw+eip $(eval readlink -f which node) , seems to do nothing.
