    "Invalid Date" appears in Weather module. MM v2.29.0
    25 Posts 5 Posters 10.0k Views 4 Watching
      reilley @sdetweil
      @sdetweil said in "Invalid Date" appears in Weather module. MM v2.29.0:
      @reilley I copied your config and used my apikey
      no other changes (well I wrapped your config in code block to keep the quotes correct for copy/paste)
      So my code worked for you and the only change was the API key? This key worked two days ago, so not sure what’s happening here.
        sdetweil @reilley
        @reilley said in "Invalid Date" appears in Weather module. MM v2.29.0:
        correct
        R 1 Reply Last reply
          reilley @sdetweil
          correct
          That’s nuts. Why would an API key work two days ago and not today? Seems like maybe there’s a configuration problem elsewhere but I not sure where it would be since I made no changes to weather.js or other .js files associated with the Weather module.
            sdetweil @reilley
            @reilley I don’t know… try my approach
            do
            cd ~/MagicMirror/config
            cp config.js.sample  testcfg.js
            cd ..
            then edit the testcfg.js and paste your weather info from config.js here
            then change the units to imperial
            save
            then on the terminal window
            export MM_CONFIG_FILE=config/testcfg.js
            npm start
              reilley @sdetweil
              @sdetweil - nope, same result
              S R V 3 Replies Last reply
                sdetweil @reilley
                @reilley ok, next thing
                weather is done all in browser,
                on the MagicMirror screen ctrl-shift-i to
                open the developer window, select the console tab,
                put wea in the filter field
                look for any messages
                  reilley @reilley
                  @reilley - oh, I think I know what’s wrong now.
                    reilley @sdetweil
                    @sdetweil - you’re gonna laugh, but I found the issue. I was using an inactive API key. My backup was too old and was before the v2.29.0 API 3.0 requirement. Sorry to drag you through this!
                      sdetweil @reilley
                      @reilley glad you found it!
                        cgillinger @reilley
                        @reilley I just realized I experienced something similar, but I was preoccupied with other tasks and didn’t take the time to investigate.
                        Here’s a screenshot for reference:
                        https://github.com/cgillinger/MMM-WeatherEffects/blob/main/screenshots/rich.png
                        Based on my screenshots (as mentioned, I was focused on tweaking the module and only noticed it afterward), it seems to be intermittent.
                        I’m using api-free providers, eg SMHI.
                        • V
                          VinGroot @reilley
                          I have the same issue. These are my settings:
                            module: "weather",
                              lat: "52.262524",
                              lon: "6.797571",
                              apiKey: "****",
                              appendLocationNameToHeader: false,
                              type: "current",
                              degreeLabel: true,
                              decimalSymbol: ",",
                              showWindDirection: false,
                              showFeelsLike: false
                            sdetweil @VinGroot
                            @VinGroot current release is 2.30 . still happening there ?
                            V 1 Reply Last reply
                            • V
                              VinGroot @sdetweil
                              @sdetweil yes, still happening.
                              just noticed this second page, trouble shooting now. I get a 401 unauthorized error.
                                sdetweil @VinGroot
                                @VinGroot well 401 means apikey not right
                                • V
                                  VinGroot @sdetweil
                                  I figured it out. I use the free plan, so I cannot use API version 3.0. I have to use API version 2.5. Furthermore I have to use the /weather endpoint.
                                  I got it working again by adding these 2 settings:
                                  apiVersion: '2.5'
                                  weatherEndpoint: "/weather"
                                    sdetweil @VinGroot
                                    @VinGroot awesome
                                    • L
                                      lif
                                      I have rebuilt my installation and used backup .js files.
                                      Everything has worked apart from the weather module.
                                      I am getting the ‘Invalid date’ message a temperature of NaN.
                                      I have tried adding the apiVersion: ‘2.5’
                                      weatherEndpoint: “/weather”
                                      Lines into the config.js file but then MagicMirror doesn’t load.
                                      the section of config.sys is:
                                      			module: "weather",
                                      				type: "current",
                                      				locationID: "2983291", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                      				apiKey: "cxxxxxxxxxxxx57f81f9d82849a2fc21a"
                                      			module: "weather",
                                      			header: "Weather Forecast",
                                      				type: "forecast",
                                      				apiKey: "cxxxxxxx57f81f9d82849a2fc21a"
                                      S 2 Replies Last reply
                                        sdetweil @lif
                                        @lif are you on 2.29 or 2.30?
                                        grep version package. json
                                        see https://forum.magicmirror.builders/topic/19323/version-2-30-0-weather-module-stuck-loading-worked-fine-before-upgrade
                                          sdetweil @lif
                                          @lif said in "Invalid Date" appears in Weather module. MM v2.29.0:
                                          > I have tried adding the apiVersion: '2.5'
                                          each of those lines had trailing commas, right?
                                          L 1 Reply Last reply
                                          • L
                                            lif @sdetweil
                                            Not that line but that wasn’t the problem :-)
                                            Thanks for the link showing how to subscribe to OpenWeathermap which solved the problem.
