Unsolved OwnCloud integration
Doesn’t Owncloud provide a ical url? You could use that without any problem in the calendar module :)
as i can see in my owncloud they are providing CalDAV adresses. I’m not using the calendar function but should be no problem to integrate.
I would also like to sync the MM with my owncloud calendar. The bad news is, that you need a username and a password for the owncloud ical file. I didn’t find an option to enter a user and password in the MM-Modul. So I tried to do a workaround (this project is my first expirience with JS, so it’s pretty hard for me to understand.) I found a little bash script to download the ical file to my homefolder. But I can’t enter the homefolder location with the MM-Modul. Perhaps someone has a good idea to do this job. :)#!/bin/bash
ical=‘http://ownclouddomain.de/remote.php/caldav/calendars/admin/blubb?export’
dir=/home/pi/
user=‘admin’
pw=‘blablabla’
curl $ical -u$user:$pw > $dir’MYical.ics’ -
I found another important information. It’s still very dirty, and everyone who knows how to do something like this will just laugh about me, but I got a working way to import my owncloud calendar. I just changed the directory to /home/pi/MagicMirror/modules/default/calendar/public
and added the following to the config.js:config: { calendars: [ { symbol: 'calendar-check-o ', url: 'http://127.0.0.1:8080/calendar/MYical.ics' } ] }
this is my bash script now:
#!/bin/bash
ical='http://ownclouddomain.de/remote.php/caldav/calendars/admin/blubb?export’
dir=/home/pi/MagicMirror/modules/default/calendar/public
user='admin’
pw=‘blablabla’
curl $ical -u$user:$pw > $dir’MYical.ics’so you only have to make a cronjob now, which starts the bash script.
I hope this helps someone, even if it is very, very dirty… :)
Why not do
username:password@yourdomain.com
in the config? -
@paviro said in OwnCloud integration:
Why not do
in the config?because it doesn’t work. :) I got this Error in the console:
logger.js:23 Calendar Error. Could not fetch calendar: user:password@myowncloud.de/remote.php/caldav/calendars/user/calendar?export -
Can you try executing
curl -L http://user:password@myowncloud.de/remote.php/caldav/calendars/user/calendar?export
in a shell? -
hmmm… that works…
ok, now it works completly. Perhaps I had a mistake inside my code. Thank you for your help!
@Shampooman do you have this publicly anywhere? I have a bash script that does something I want an MMM to do but have no idea how to get it working and it looks to me thats what you are doing.
