    Bluetooth connections with noble
    8 Posts 3 Posters 6.5k Views 4 Watching
    • yawnsY Offline
      yawns Moderator
      How did you rebuild? Which command did toy use?
      • SvenSommerS Offline
        SvenSommer
        Hey @yawns,
        I tried to rebuild noble and bluetooth-hci-socket by:
        npm uninstall bluetooth-hci-socket
        followed by
         npm install bluetooth-hci-socket
        within the /home/pi/MagicMirror/modules/MMM-OralB/ - folder and also the
        npm rebuild bluetooth-hci-socket
        which should to to same.
        Same for the hole noble package within the same folder.
        Looking for some building inspiration?
        Check out my large, thin and metal framed mirror on robstechlog.com.
        Modules released:
        MMM-GoogleAnalytics
        MMM-GrafanaChart
        MMM-GrafanaGauges
          SvenSommer
          with the help of @dfuerst we were able to solve this issue by rebuilding electron with a special version:
          sudo npm rebuild --runtime=electron --target=1.4.6 --disturl=https://atom.io/download/atom-shell --abi=50
          Modules released:
          MMM-GoogleAnalytics
          MMM-GrafanaChart
          MMM-GrafanaGauges
          • yawnsY Offline
            yawns Moderator
            Great. That’s what I was aiming for.
              SvenSommer
              So noble is working fine. I find all bluetooth devices as expected, as long it’s not running within the MM-framework.
              It seems like noble isn’t able to power on the bluetooth adapter on the raspberry pi3 board when started by magicmirror.
              Any ideas?
              Here is a minimal example:
              var noble = require('noble');
              console.log('stateChange is: ' + noble.state);
              noble.on('stateChange', function(state) {
                console.log('changed state to: ' + noble.state);
                if (state === 'poweredOn') {
                  noble.startScanning();
                }else  {
                  noble.stopScanning();
              leeds to:
              stateChange is: unknown
              Modules released:
              MMM-GoogleAnalytics
              MMM-GrafanaChart
              MMM-GrafanaGauges
                dfuerst
                maybe using hcitool with the syntax for pairing a device before would solve this issue, have you tried that?
                as far as i understand the rpi3 bluetooth is on, at startup, but you have to pair the devices every startup, unless you use hcitool with the corresponding syntax for direct pairing within your .js
                  SvenSommer
                  We were able to solve this issue by ruinning the MM² with sudo-right. See here for details.
                  Modules released:
                  MMM-GoogleAnalytics
                  MMM-GrafanaChart
                  MMM-GrafanaGauges
