    Bluetooth connections with noble
    8 Posts 3 Posters 6.7k Views 4 Watching
    • SvenSommerS Offline
      SvenSommer
      Hey guys,
      I need some advice how to get a bluetooth javascript-package running within the MM framework.
      I tried to install noble to search for a bluetooth device. As I followed the installation instruction on the linked page, I was able to get the package running in a simple test enviroment.
      Unfortunately I wasn’t able to get noble running within the MagicMirror framework.
      I tried to install it with npm and several versions of node.js (6.x and 7.x) but got always an error
      "Error: Module version mismatch. Expected 50, got 51." [node.js 7.x] or
      "Error: Module version mismatch. Expected 50, got 48." [node.js 6.x]
      within the bluetooth-hci-socket - part of noble.
      I tried rebuilding the noble included packages and tried it also with a clean Magic Mirror installation under node.js 7.x. unfortunately nothing helped.
      Starting MagicMirror: v2.1.0
      Loading config ...
      Loading module helpers ...
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 50, got 51.
      App threw an error during load
          at Error (native)
          at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
          at Object.Module._extensions..node (module.js:583:18)
          at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
          at Module.load (module.js:473:32)
          at tryModuleLoad (module.js:432:12)
          at Function.Module._load (module.js:424:3)
          at Module.require (module.js:483:17)
          at require (internal/module.js:20:19)
          at Object. (/home/pi/MagicMirror/modules/MMM-OralB/node_modules/bluetooth-hci-socket/lib/native.js:3:15)
          at Error (native)
      Looking for some building inspiration?
      Check out my large, thin and metal framed mirror on robstechlog.com.
      Modules released:
      MMM-GoogleAnalytics
      MMM-GrafanaChart
      MMM-GrafanaGauges
      • Y Offline
        yawns Moderator
        How did you rebuild? Which command did toy use?
          SvenSommer
          Hey @yawns,
          I tried to rebuild noble and bluetooth-hci-socket by:
          npm uninstall bluetooth-hci-socket
          followed by
           npm install bluetooth-hci-socket
          within the /home/pi/MagicMirror/modules/MMM-OralB/ - folder and also the
          npm rebuild bluetooth-hci-socket
          which should to to same.
          Same for the hole noble package within the same folder.
          Modules released:
          MMM-GoogleAnalytics
          MMM-GrafanaChart
          MMM-GrafanaGauges
            SvenSommer
            with the help of @dfuerst we were able to solve this issue by rebuilding electron with a special version:
            sudo npm rebuild --runtime=electron --target=1.4.6 --disturl=https://atom.io/download/atom-shell --abi=50
            Modules released:
            MMM-GoogleAnalytics
            MMM-GrafanaChart
            MMM-GrafanaGauges
            • Y Offline
              yawns Moderator
              Great. That’s what I was aiming for.
                SvenSommer
                So noble is working fine. I find all bluetooth devices as expected, as long it’s not running within the MM-framework.
                It seems like noble isn’t able to power on the bluetooth adapter on the raspberry pi3 board when started by magicmirror.
                Any ideas?
                Here is a minimal example:
                var noble = require('noble');
                console.log('stateChange is: ' + noble.state);
                noble.on('stateChange', function(state) {
                  console.log('changed state to: ' + noble.state);
                  if (state === 'poweredOn') {
                    noble.startScanning();
                  }else  {
                    noble.stopScanning();
                leeds to:
                stateChange is: unknown
                Modules released:
                MMM-GoogleAnalytics
                MMM-GrafanaChart
                MMM-GrafanaGauges
                  dfuerst
                  maybe using hcitool with the syntax for pairing a device before would solve this issue, have you tried that?
                  as far as i understand the rpi3 bluetooth is on, at startup, but you have to pair the devices every startup, unless you use hcitool with the corresponding syntax for direct pairing within your .js
                    SvenSommer
                    We were able to solve this issue by ruinning the MM² with sudo-right. See here for details.
                    Modules released:
                    MMM-GoogleAnalytics
                    MMM-GrafanaChart
                    MMM-GrafanaGauges
