    rookie question: "builder encountered a problem, see MagicMirror messages for info"
    9 Posts 2 Posters 971 Views 2 Watching
      rkorell
      Hi gurus,
      I’ve just found MMM-config and tried - but get this error messsage:
      “builder encountered a problem, see MagicMirror messages for info”…
      Where I can find “Magic Mirror Messages”?
      Nothing on the screen, nothing on (pm2 logs) log…
      Any hint would be appreciated!
      Regards,
      Ralf
        sdetweil @rkorell
        @rkorell hm… second time in a week the trap output not found…
        (when did you install it? today?? one fix for this was 2 days ago)
        should look something like this (just to force an error)
        --------------------MMM-Config
        module MMM-OpenWeatherMapForecast has an error in the construction of its defaults section
        the error line is         maxHourliesToShow:fred,
        please change it to the literal value of the referenced variable
        and restart MagicMirror
        email me the ~/MagicMirror/modules/MMM-Config/defaults_???.js
        ??? is some number
        you will have to rename the file to .txt to send via email
          rkorell @sdetweil
          @sdetweil , Dear Sam,
          I’ve installed your module today (just an hour or so ago).
          Where did you get the above posted “MMM-Config” outputs?
          As I wrote I do not know where to look…
          The requested javascript is named "defaults_19492568968080.js " .
          I’ve seen your mail address in the past somewhere - I remember it’s your username here at a public mail provider.
          But I forgot, which one - was it gmx.com ?
          Again thanks for your kind help.
          Regards,
          Ralf
            sdetweil @rkorell
            @rkorell that output would be displayed in the output of npm start, or pm2 logs
            the default number of lines for pm2 logs is only 15 , so more might be necessary
            (the number is the end of the log output, most recent lines)
            pm2 logs --lines=100
            my email is the same userid as here at gmail
              rkorell @sdetweil
              O.K., than I was at the right place…
              No message found in this output.
              Just sent you an email with the .js file attached - renamed with a .txt suffix.
              Thanks and warm regards,
              Ralf
                sdetweil @rkorell
                @rkorell ok, fixed
                do this
                cd ~/MagicMirror/modules/MMM-Config
                git pull
                then restart MagicMirror
                (using pm2, its
                pm2 restart x
                where x
                is the name/number of the line for this app , in the output of
                pm2 status
                  rkorell @sdetweil
                  Dear Sam, (@sdetweil),
                  thanks a LOT.
                  Now it works (at least I get the console without an error), not tried to make any changes.
                  As message from git pull shows, some work for you - THANKS.
                  Just being curious: Is something special in my environment which causes this unexpected and obviously not omnipresent issue?
                  What have you fixed?
                  (If narrated in a feasible amount of time/words) :-)
                  Warmest regards,
                  Ralf
                    sdetweil @rkorell
                    @rkorell the module ‘discovers’ the variables defined in other modules to be configurable.
                    they can BE ANYTHING… over many lines, or constructed from other variables
                    you found another case that I didn’t cover…
                    there are only a 1000 modules, and you tried one I hadn’t seen before… which was different
                    I fixed that, which broke something else
                    I expect more troubles as time goes by
                      rkorell @sdetweil
                      @sdetweil , O.K, understood.
                      Thanks for explanation - this makes sense.
                      Again: incredible work from you for the community: Many thanks!
                      Ralf
                      • R rkorell has marked this topic as solved on
                      • D dphotograph referenced this topic on
