    rookie question: "builder encountered a problem, see MagicMirror messages for info"
    9 Posts 2 Posters 991 Views 2 Watching
      rkorell @sdetweil
      @sdetweil , Dear Sam,
      I’ve installed your module today (just an hour or so ago).
      Where did you get the above posted “MMM-Config” outputs?
      As I wrote I do not know where to look…
      The requested javascript is named "defaults_19492568968080.js " .
      I’ve seen your mail address in the past somewhere - I remember it’s your username here at a public mail provider.
      But I forgot, which one - was it gmx.com ?
      Again thanks for your kind help.
      Regards,
      Ralf
        sdetweil @rkorell
        @rkorell that output would be displayed in the output of npm start, or pm2 logs
        the default number of lines for pm2 logs is only 15 , so more might be necessary
        (the number is the end of the log output, most recent lines)
        pm2 logs --lines=100
        my email is the same userid as here at gmail
          rkorell @sdetweil
          O.K., than I was at the right place…
          No message found in this output.
          Just sent you an email with the .js file attached - renamed with a .txt suffix.
          Thanks and warm regards,
          Ralf
            sdetweil @rkorell
            @rkorell ok, fixed
            do this
            cd ~/MagicMirror/modules/MMM-Config
            git pull
            then restart MagicMirror
            (using pm2, its
            pm2 restart x
            where x
            is the name/number of the line for this app , in the output of
            pm2 status
              rkorell @sdetweil
              Dear Sam, (@sdetweil),
              thanks a LOT.
              Now it works (at least I get the console without an error), not tried to make any changes.
              As message from git pull shows, some work for you - THANKS.
              Just being curious: Is something special in my environment which causes this unexpected and obviously not omnipresent issue?
              What have you fixed?
              (If narrated in a feasible amount of time/words) :-)
              Warmest regards,
              Ralf
                sdetweil @rkorell
                @rkorell the module ‘discovers’ the variables defined in other modules to be configurable.
                they can BE ANYTHING… over many lines, or constructed from other variables
                you found another case that I didn’t cover…
                there are only a 1000 modules, and you tried one I hadn’t seen before… which was different
                I fixed that, which broke something else
                I expect more troubles as time goes by
                  rkorell @sdetweil
                  @sdetweil , O.K, understood.
                  Thanks for explanation - this makes sense.
                  Again: incredible work from you for the community: Many thanks!
                  Ralf
                  • R rkorell has marked this topic as solved on
                  • D dphotograph referenced this topic on
