    Getting LED Strip on in conjunction with MMM-Pir
    16 Posts 2 Posters 2.3k Views 2 Watching
      rkorell
      Hi folks,
      I’ve searched a long while and found several (some of them really old) posts regarding the “easy” question:
      “How can I synchronize on/off switching of a LED strip with MMM-Pir’s on/off switching of monitor”?
      None of them are “answered” to a final solution - so I currently stuck…
      I’ve seen that in module MMM-Pir seems to be a notification ‘USER_PRESENCE’.
      (on and off, I assume).
      What I cannot figure out: Where and how I can use this?
      I’ve found a LED-strip module (MMM-FrameLight) which can handle notifications but is awaiting notifications in an own format e.g. “FRAMELIGHT_ON”.
      How can I fetch the PIR “event” = notification for user presens/absence (from WWW-Pir) and how can I overhand this in changed format to an other module (WWW-FrameLight)?
      Or is this simple not possible or do I even make an error in my approach - will this be solved in a completely other manner?
      I would like to avoid to write own code to do the same work as already given modules.
      For sure there is something obvious which I currently cannot see …
      (To be honest I’m FAR away from real understanding what happens inside MM and I’m an absolute beginner in JavaScript - so the above mentioned “writing code at my own” would be really hard).
      Thanks for any guidance.
      Ralf
        sdetweil @rkorell
        @rkorell i think framelight can also listen and act on other ‘system’ (any) notification
        as these two are from another module, not the core ‘system’.
        therefore you can setup for ANY notification
          sdetweil @rkorell
          @rkorell modules receive notifications at the
          notificationReceived() function in the modulename.js file
          the function takes two parms
          notificationReceived( notification_code, data(or payload))
          a notifcation_code is that “USER_PRESENCE”,
          and the data/payload is a notification specific data structure/value
          for user_Presence its true and false
            rkorell @sdetweil
            @sdetweil OK, thanks for this.
            Any chance that there is a module around that handles “intermodule communication” - like an application broker?
            If not and I got you right than my way must be to adjust a given source code which leads me in trouble with updates.
            Any other idea how I can solve my problem “How can I synchronize on/off switching of a LED strip with MMM-Pir’s on/off switching of monitor”?
            Thanks for any suggestion.
            Ralf
              sdetweil @rkorell
                rkorell @sdetweil
                @sdetweil awesome…
                I’ve missed that, I’m so sorry!
                Thanks for your effort in tutoring!
                Highly appreciated!
                Just another quick question - fiddling with the developer console in Chrome:
                I’ve found the Application tab and there is a recorder for “notifications” but there is no notification shown up.
                Any chance to debug the notifications in my config (I would like to see “sender” and “payload” …
                Thanks again for your kind support!
                Warmest regards,
                Ralf
                • R rkorell has marked this topic as solved on
                  sdetweil @rkorell
                  @rkorell their idea of notifications is not the same as MagicMirror’s usage
                  you can use MMM-ViewNotifications. it presents a window( config change to leave them there for awhile, as default clears them too fast during development use)
                    rkorell @sdetweil
                    Dear Sam, (@sdetweil ),
                    as always (!) Great.
                    this worked - thanks a LOT!
                    With this little “sniffer” I was able to figure out, what happens…
                    It is just a rumour that MMM-Pir sends a “USER_PRESENCE” notification.
                    In fact there is one and only one notification “MMM_PIR-SCREEN_POWERSTATUS”.
                    With a little bit trial & error I was able to identify that the payload is true / false for the events “screen on” / “screen off”.
                    With further searches today I found @MMRIZE’s module MMM-NotificationTrigger which seems to do what I’m looking for - Tranlating SCREENPOWERSTATUS-true to FRAMELIGHT_ON and opposite.
                    Hopefully I can figure out how to use MMRize’s module in right manner.
                    Warmest regards,
                    Ralf
                    (I have to wait for LED strip - they are shipping currently)
                    Keep you posted.
                      rkorell @rkorell
                      @sdetweil , as expected :-( I’m not able to figure this out…
                      I’m in the fog of instances and .this / not .this…
                      Can somebody guid me, please?
                      I’m trying to configure MMM-NotificationTrigger to send two different notifications depending on the payload.
                      So my idea is to evaluate payload in given payload filter, store the result in a variable and decide with this variable which fire statement is the correct one.
                      But I’m stuck in referencing this variable which seems to be unknown outside the trigger-evaluation part.
                      This currently is my (non working) approach in my config.js file:
                      		  module: 'MMM-NotificationTrigger',
                      		  disabled: false,
                      		    useWebhook: false, // If you want to activate webhook as Notification emitter, set true. (eg. IFTTT)
                      		    triggers:[ // Array of triggers.
                      		        trigger: "MMM_PIR-SCREEN_POWERSTATUS", //REQUIRED
                      		        triggerPayloadFilter: (payload) => { //OPTIONAL should return true or false
                      		          if (payload.value == 'true' ) {
                      		            this.ScreenStatus = "on"
                      		            return true
                      		          this.ScreenStatus = "off"
                      		          return true
                      		        fires: [ // Array of fires. You can enable multi-firing with one trigger.
                      			         if (ScreenStatus == 'on') {
                                  			fire: "SCREEN_IS_ON",
                                				} else {
                                  			fire: "SCREEN_IS_OFF",
                      I’ve tried to reference Screenstatus with “payload.ScreenStatus” as well as “triggerPayloadFilter.screenstatus”, but the dot is rejected as config error in both cases.
                      Any tip is highly appreciated.
                      Sorry for being this stupid…
                      Warm regards,
                      Ralf
                        sdetweil @rkorell
                        @rkorell i haven’t tried this but it should work
                        anything created IN the filter will die in the filter
                        so you need something persistent
                        lets cheat
                        as the config is persistent lets add your variable to the config block, the module wont know its there and wont use it
                                             ScreenStatus:null,
                        		    triggers:[
                        now in your trigger filter and fires use
                        this.config.ScreenStatus
                        using the browser developers window , sources tab expand left nav to find the modulename.js) you should find the module source where it calls the filter and put a stop there and(f5 to reload the page) step INTO ( down arrow icon above the code in sources view) to see your filter execute
                          rkorell @sdetweil
                          @sdetweil , thanks!!!
                          Sounds plausible but doesn’t work :-(
                          I can reference this.config.ScreenStatus in the TriggerPayloadFilter.
                          But when I do this, the fire isn’t working (no notification broadcast appears).
                          In addition referencing of this.config.ScreenStatus in the fire block causes an error “Cannot read properties of undefined (reading ‘ScreenStatus’)”…
                          Any direct reference in the fire block in an IF statement creates an "unecpected ‘this’ " error message …
                          you can see my dumb trials commented in this snippet:
                          		  disabled: false,
                          		    ScreenStatus:"INIT",
                          		            //this.config.ScreenStatus = "on"
                          		            return true
                          		          //this.config.ScreenStatus = "off"
                          		            return true
                          			         /* if (this.config.ScreenStatus == 'on') {
                                    			  	} else {
                                    			//fire: this.config.ScreenStatus,
                                    			fire: "BROADCAST",
                          I’m SO sorry…
                          Ralf
