    MMM-FroniusSolar family modules
    31 Posts 5 Posters 9.0k Views 5 Watching
    • C Online
      chrisfr1976
      i was working the last days on a module to get rid of the last iframes on my mirror. These modules can all visualize solar energy data from a Fronius solar system using SVG magic :)
      • MMM-FroniusSolar: Best for simple setups prioritizing clarity and minimalism.
      • MMM-FroniusSolar2: Suitable for scenarios requiring visual feedback on power flows (e.g., monitoring dynamic energy consumption).
      • MMM-FroniusSolar3: Ideal for larger or customizable displays where scalability is important.
      If you do not have a FroniusPV but your system has an API it should be not much work to adjust the node_helper file.
      All in a column:
      MMM-FroniusSolar
      Regards, Chris.
      • C Online
        chrisfr1976 @chrisfr1976
        i found a small bug. At this moment you need to change your inverter-IP in the node_helper.js file.
        I‘ll fix this to a config entry this weekend.
        Regards, Chris.
        • C Online
          Fixed. IP can now be defined in the config.js:
          InverterIP: "<yourInverterIP>",
          Regards, Chris.
          • C Online
            I’ve added a quite special module to the “family” which is exact what I need. Maybe someone else hat also a PV on the roof controlled by the Fronius inverter and in addition a mini-PV system measuring with a Shelly-device. I have exactly that case in my house :-)
            So, that’s it: MMM-FroniusSolar4
            Added Shelly device in the monitoring:
            MMM-FroniusSolar4
            There is a small flickering effect with the text labels. SVG doesn’t like text with icons inside that much. I have no more ideas how to fix this (I tried a lot). But it is not really annoying me.
            One hint: the label text must be modified in the js-file in this part of the code:
                    svg.appendChild(createGauge( "Grid", this.config.icons.P_Grid, "top", .............));
                    svg.appendChild(createGauge( "Akku", this.config.icons.P_Akku, "bottom", ................));
                    svg.appendChild(createGauge( "", this.config.icons.P_Load, "middle",..................));
            	svg.appendChild(createGauge( "PV Mini", this.config.icons.P_Shelly, "bottom", ...............));
            The "" is the house in the middle :)
            Regards, Chris.
              alfi153
              Hi. the module looks very good.
              I installed the Fronius3. But my mirror only shows loading. The ip is correct. On an other mirror I use energy monitor and this works.
              Any idea what I make wrong
              • C Online
                chrisfr1976 @alfi153
                @alfi153
                the node_helper.js is the same for module 1,2 and 3. If one of them is not running there must be a config error. Maybe my mistake in the readme. Check what the console messages and/or pm2 logs tell and send me the result. I‘ll check parallel the documentation.
                Regards, Chris.
                  alfi153 @chrisfr1976
                  @chrisfr1976
                  Hello.
                  On the other Mirror I use MMM-Fronius2 from deg0nz. These model get information from my Gen24. But your module shows: loading. Is there anything to change in the Gen24 settings
                  C 2 Replies Last reply Reply Quote 0
                  • C Online
                    @alfi153 Hi, my module is working complete different. I don‘t know the other node_helper. The MMM-FroniusSolar 1-3 use the same node_helper. Version 4 is again different. For inverter settings nothing special is necessary. Is the ip configured corretly?
                    Which version do you try to use?
                    Chris.
                    Regards, Chris.
                    A 3 Replies Last reply Reply Quote 0
                      @chrisfr1976
                      I try to use Version 3.
                      The ip is correct
                      i have activated the API on my Fronius Gen24
                      is it possible to get any Log file?
                        • 1 / 4
