    Cannot find module 'node-fetch' error with multiple MM modules
    12 Posts 5 Posters 8.1k Views 5 Watching
      blackbull
      I have several failing with the “Cannot find module ‘node-fetch’” error. (see trace below)
      I have seen this with similar other (older) modules, and sadly I have not been able to fix this.
      https://github.com/alonsourbano/publika
      https://github.com/ZakarFin/mm-hsl-timetable
      https://github.com/cSharpBastard/mmm-nordic-electrical-spot-prices
      Browsing the forums, there seems to be similar issues with other modules after the MM 2.25.0 version.
      Things tried (which I can recall):
      • npm install of that missing ‘node-fetch’
        https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later?page=1
      • Fresh MM installations with Node.js version 20
        https://github.com/nodesource/distributions
      • downgrading to Node.js version 18
      All with similar results. Any advice appreciated, thanks!
      Respectfully,
      Saku
      > magicmirror@2.25.0 start
      [05.10.2023 22:14.53.083] [LOG]   Starting MagicMirror: v2.25.0
      [05.10.2023 22:14.53.090] [LOG]   Loading config ...
      [05.10.2023 22:14.53.092] [DEBUG] config template file not exists, no envsubst
      [05.10.2023 22:14.53.097] [LOG]   Loading module helpers ...
      [05.10.2023 22:14.53.099] [LOG]   No helper found for module: alert.
      [05.10.2023 22:14.53.148] [LOG]   Initializing new module helper ...
      [05.10.2023 22:14.53.149] [LOG]   Module helper loaded: updatenotification
      [05.10.2023 22:14.53.150] [LOG]   No helper found for module: clock.
      [05.10.2023 22:14.53.151] [LOG]   No helper found for module: compliments.
      [05.10.2023 22:14.53.208] [LOG]   Initializing new module helper ...
      [05.10.2023 22:14.53.209] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
      [05.10.2023 22:14.53.234] [ERROR] (node:7772) UnhandledPromiseRejectionWarning: Error: Cannot find module 'node-fetch'
      Require stack:
      - /home/saku/MagicMirror/modules/publika/node_helper.js
      - /home/saku/MagicMirror/js/app.js
      - /home/saku/MagicMirror/js/electron.js
      - /home/saku/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
          at node:internal/modules/cjs/loader:1084:15
          at Function.<anonymous> (node:electron/js2c/browser_init:2:117500)
          at Module._resolveFilename (/home/saku/MagicMirror/node_modules/module-alias/index.js:49:29)
          at node:internal/modules/cjs/loader:929:27
          at Function._load (node:electron/js2c/asar_bundle:2:13327)
          at Module.require (node:internal/modules/cjs/loader:1150:19)
          at require (node:internal/modules/cjs/helpers:110:18)
          at Object.<anonymous> (/home/saku/MagicMirror/modules/publika/node_helper.js:3:15)
          at Module._compile (node:internal/modules/cjs/loader:1271:14)
          at Object..js (node:internal/modules/cjs/loader:1326:10)
          at Module.load (node:internal/modules/cjs/loader:1126:32)
          at node:internal/modules/cjs/loader:967:12
          at loadModule (/home/saku/MagicMirror/js/app.js:180:19)
      (Use `electron --trace-warnings ...` to show where the warning was created)
        sdetweil @blackbull
        @blackbull yes, I saw someone else with the same problem
        it was the node-fetch version
        do this
        npm install node-fetch@2
          sdetweil @blackbull
          @blackbull we remove node fetch from the magic mirror package on this release as we drop back to the integrated fetch that’s provided in node and in the electron browser unfortunately that breaks a bunch of modules.
          So you can either NPM install it in every module that needs it or you can an NPM install it in the base once for all the modules
            blackbull @sdetweil
            Thanks for info and pointers! Did the NPM install in base, but ended into a new obstacle.
            BR,
            Saku
            [05.10.2023 22:47.23.542] [ERROR] (node:8355) UnhandledPromiseRejectionWarning: Error [ERR_REQUIRE_ESM]: require() of ES Module /home/saku/MagicMirror/modules/publika/node_modules/node-fetch/src/index.js from /home/saku/MagicMirror/modules/publika/node_helper.js not supported.
            Instead change the require of index.js in /home/saku/MagicMirror/modules/publika/node_helper.js to a dynamic import() which is available in all CommonJS modules.
                at loadModules (/home/saku/MagicMirror/js/app.js:210:10)
                at async App.start (/home/saku/MagicMirror/js/app.js:258:3)
              sdetweil @blackbull
              do this
                blackbull @sdetweil
                @sdetweil YES! Big thanks! :)
                That needed to be run in the specific module folder, installing that in MM base did not work.
                Respectfully,
                Saku
                • B BEGreen87 referenced this topic on
                  myayo001 @blackbull
                  @blackbull j’ai le meme soucis. quand tu dis le dossier spécifique du module, c’est par exemple dans MMM-moonraker ou dans MMM-moonraker/node_modules?
                  Merci d’avance.
                    sdetweil @myayo001
                    @myayo001 did you see this above
                    https://forum.magicmirror.builders/post/111396
                    M bugsounetB 2 Replies Last reply Reply Quote 0
                      myayo001 @sdetweil
                      @sdetweil oui j’ai vu le post je dois installer npm install node-fetch@2
                      je l’ai installer dans le dossier MMM-moonraker et j’ai toujours l’erreur
                      • bugsounetB
                        bugsounet Banned @sdetweil
                        @sdetweil cela arrive quand la version principale de node est v10.x et que l’utilisateur demande la version v20 ou v22 avec la commande n
                        généralement resolu avec la version principale de node en v20. ensuite on peux utiliser n comme on a envie
                          myayo001 @bugsounet
                          @bugsounet je n 'ai pas trop compris ce que je devais faire.
                          mais j’ai bien node v20
                          Mirror $ node -v
                          v20.18.1
                          • KristjanESPERANTOK
                            KristjanESPERANTO Module Developer @myayo001
                            @myayo001 Just remove the the line const fetch = require("fetch"); in the file node-helper.js in the module’s directory.
                              myayo001
                              merci ca fonctionne maintenant!
