    Cannot find module 'node-fetch' error with multiple MM modules
    12 Posts 5 Posters 8.1k Views 5 Watching
      sdetweil @blackbull
      @blackbull we remove node fetch from the magic mirror package on this release as we drop back to the integrated fetch that’s provided in node and in the electron browser unfortunately that breaks a bunch of modules.
      So you can either NPM install it in every module that needs it or you can an NPM install it in the base once for all the modules
        blackbull @sdetweil
        Thanks for info and pointers! Did the NPM install in base, but ended into a new obstacle.
        BR,
        Saku
        [05.10.2023 22:47.23.542] [ERROR] (node:8355) UnhandledPromiseRejectionWarning: Error [ERR_REQUIRE_ESM]: require() of ES Module /home/saku/MagicMirror/modules/publika/node_modules/node-fetch/src/index.js from /home/saku/MagicMirror/modules/publika/node_helper.js not supported.
        Instead change the require of index.js in /home/saku/MagicMirror/modules/publika/node_helper.js to a dynamic import() which is available in all CommonJS modules.
            at Function._load (node:electron/js2c/asar_bundle:2:13327)
            at Object.<anonymous> (/home/saku/MagicMirror/modules/publika/node_helper.js:3:15)
            at loadModule (/home/saku/MagicMirror/js/app.js:180:19)
            at loadModules (/home/saku/MagicMirror/js/app.js:210:10)
            at async App.start (/home/saku/MagicMirror/js/app.js:258:3)
        (Use `electron --trace-warnings ...` to show where the warning was created)
          sdetweil @blackbull
          @blackbull yes, I saw someone else with the same problem
          it was the node-fetch version
          do this
          npm install node-fetch@2
            blackbull @sdetweil
            @sdetweil YES! Big thanks! :)
            That needed to be run in the specific module folder, installing that in MM base did not work.
            Respectfully,
            Saku
            • B BEGreen87 referenced this topic on
              myayo001 @blackbull
              @blackbull j’ai le meme soucis. quand tu dis le dossier spécifique du module, c’est par exemple dans MMM-moonraker ou dans MMM-moonraker/node_modules?
              Merci d’avance.
                sdetweil @myayo001
                @myayo001 did you see this above
                https://forum.magicmirror.builders/post/111396
                M bugsounetB 2 Replies Last reply Reply Quote 0
                  myayo001 @sdetweil
                  @sdetweil oui j’ai vu le post je dois installer npm install node-fetch@2
                  je l’ai installer dans le dossier MMM-moonraker et j’ai toujours l’erreur
                  • bugsounetB
                    bugsounet Banned @sdetweil
                    @sdetweil cela arrive quand la version principale de node est v10.x et que l’utilisateur demande la version v20 ou v22 avec la commande n
                    généralement resolu avec la version principale de node en v20. ensuite on peux utiliser n comme on a envie
                      myayo001 @bugsounet
                      @bugsounet je n 'ai pas trop compris ce que je devais faire.
                      mais j’ai bien node v20
                      Mirror $ node -v
                      v20.18.1
                      • KristjanESPERANTOK
                        KristjanESPERANTO Module Developer @myayo001
                        @myayo001 Just remove the the line const fetch = require("fetch"); in the file node-helper.js in the module’s directory.
                          myayo001
                          merci ca fonctionne maintenant!
