    upgrading to latest MM version
    18 Posts 2 Posters 5.4k Views 2 Watching
      JMac
      Finally getting round to updating the base MM version.
      used @sdetweil bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
      and it did what it wanted to do.
      How do I know that the second line bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
      can be run without issue?
      I get this before it runs through all the package.json files for modules I’m using,
      Check current Node installation …
      Minimum Node version: v20.18.1
      Installed Node version: v20.8.0
      Node should be upgraded.
      Node.js upgrade defered, doing test run
      Check current NPM installation …
      Minimum npm version: V10.8.2
      Installed npm version: V10.1.0
      npm should be upgraded.
      npm upgrade defered, doing test run …
      is it safe at this point to use the code to make the changes?
      Cheers,
      John.
        JMac @sdetweil
        @sdetweil restarted the MM with PM2, still no info being displayed in the CalendarEXT3 module.
        edit to add, after letting the mirror settle down, it’s now pulling the data
          sdetweil @JMac
          @JMac yes, run the apply version
          things will be ok
          always backup first
          https://github.com/sdetweil/MagicMirror-backup-restore
            JMac
            out of curiosity, what would I do if I needed to retrieve the back up, do I need a GitHub account?
            S 2 Replies Last reply
              sdetweil @JMac
              @JMac it depends on what you want to do
              if you are just upgrading MM and don’t expect any sd card or OS issues
              – no ‘need’ to copy
              otherwise
              – at minimum you can copy the ~/MM-backup folder to some other media
              if you want you can use a githib PRIVATE repo for that
              (private only because it contains private info)
              its free, just takes a login and create a repo
              then use the repo name in the backup
              (git will prompt for the password, not my code)
              by using git and github, i also version the backup too(using git tags)
              so todays may be different than yesterday or last week…
              you can restore ANY of those…
              (and you didn’t lose a usb stick, or sd card… or whatever)
              (AND you can tell the difference between versions)
              the MM source is also tagged (git term for labeled) at each release,
              so we can get bback there pretty easily
              J 1 Reply Last reply
                sdetweil @JMac
                @JMac to restore, you run the restore script . it takes parameters to tell it what to do
                  JMac @sdetweil
                  @sdetweil This is useful to know.
                  Just add, I’ve had the same Issue as the last MM update, Calendar EXT3 is no longer pulling information from the base calendar module.
                    sdetweil @JMac
                    @JMac did you put on the fix
                    see https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
                    J 2 Replies Last reply
                      JMac @sdetweil
                      @sdetweil I hadn’t seen that, I was about to update the module individually then do some digging on here to see if others had had the issue.
                      do I use the list of commands in the link above, or the ones in this link?
                      https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                        JMac @sdetweil
                        @sdetweil I’ve hit this at the 3 command,
                        MagicMirror@raspberrypi:~/MagicMirror $ git switch _fix_clipping
                        error: Your local changes to the following files would be overwritten by checkout:
                        package-lock.json
                        Please commit your changes or stash them before you switch branches.
                        Aborting
                          sdetweil @JMac
                          @JMac rm package-lock.json
                            JMac @sdetweil
                            @sdetweil do I run that in just the MagicMirror directory or the Calendar EXT3 module directory?
                            Below was your guidance from another of my topics with issues with this module, will it work?
                            (#)put package-lock.json back to last git clone state
                            git reset package-lock.json
                            (#) update the module
                            git pull
                            (#) rerun npm install with new code
                            npm install
                            had to put the # in () to stop the font going enormous
                              sdetweil @JMac
                              @JMac in the folder you are in!
                                JMac @sdetweil
                                MagicMirror@raspberrypi:~/MagicMirror $ rm package-lock.json
                                rm: cannot remove ‘package-lock.json’: No such file or directory
                                guessing I’m not doing this right
                                  sdetweil @JMac
                                  package-lock.json
                                  Aborting
                                  so it HAS to be there
                                  ls and see if you see it
                                  once you have it so it is NOT there
                                  then do the switch again
                                    JMac @sdetweil
                                    getting this now,
                                    Already on ‘_fix_clipping’
                                    so assuming I can now restart mm?
                                      sdetweil @JMac
                                      @JMac correct, thats what the instructions say
                                        JMac @sdetweil
                                          sdetweil @JMac
                                          @JMac Ext3 tries NOT to to flash on every update so the screen doesn’t flicker
                                          he has parameters you can change to adjust the timing
                                          the base cal module does take a little longer to process large calendars
