upgrading to latest MM version
18 Posts 2 Posters 1.9k Views 2 Watching
    JMac
    Finally getting round to updating the base MM version.
    used @sdetweil bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
    and it did what it wanted to do.
    How do I know that the second line bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
    can be run without issue?
    I get this before it runs through all the package.json files for modules I’m using,
    Check current Node installation …
    Minimum Node version: v20.18.1
    Installed Node version: v20.8.0
    Node should be upgraded.
    Node.js upgrade defered, doing test run
    Check current NPM installation …
    Minimum npm version: V10.8.2
    Installed npm version: V10.1.0
    npm should be upgraded.
    npm upgrade defered, doing test run …
    is it safe at this point to use the code to make the changes?
    Cheers,
    John.
    S 1 Reply Last reply Jan 12, 2025, 11:52 AM Reply Quote 0
      JMac @sdetweil
      @sdetweil restarted the MM with PM2, still no info being displayed in the CalendarEXT3 module.
      edit to add, after letting the mirror settle down, it’s now pulling the data
      S 1 Reply Last reply Jan 13, 2025, 6:42 PM Reply Quote 0
        sdetweil @JMac
        @JMac yes, run the apply version
        things will be ok
        always backup first
        https://github.com/sdetweil/MagicMirror-backup-restore
          JMac
          out of curiosity, what would I do if I needed to retrieve the back up, do I need a GitHub account?
          S 2 Replies Last reply Jan 12, 2025, 2:12 PM Reply Quote 0
            sdetweil @JMac
            @JMac it depends on what you want to do
            if you are just upgrading MM and don’t expect any sd card or OS issues
            – no ‘need’ to copy
            otherwise
            – at minimum you can copy the ~/MM-backup folder to some other media
            if you want you can use a githib PRIVATE repo for that
            (private only because it contains private info)
            its free, just takes a login and create a repo
            then use the repo name in the backup
            (git will prompt for the password, not my code)
            by using git and github, i also version the backup too(using git tags)
            so todays may be different than yesterday or last week…
            you can restore ANY of those…
            (and you didn’t lose a usb stick, or sd card… or whatever)
            (AND you can tell the difference between versions)
            the MM source is also tagged (git term for labeled) at each release,
            so we can get bback there pretty easily
            J 1 Reply Last reply Jan 13, 2025, 5:29 PM Reply Quote 0
              sdetweil @JMac
              @JMac to restore, you run the restore script . it takes parameters to tell it what to do
                JMac @sdetweil
                @sdetweil This is useful to know.
                Just add, I’ve had the same Issue as the last MM update, Calendar EXT3 is no longer pulling information from the base calendar module.
                S 1 Reply Last reply Jan 13, 2025, 5:31 PM Reply Quote 0
                  sdetweil @JMac
                  @JMac did you put on the fix
                  see https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
                  J 2 Replies Last reply Jan 13, 2025, 5:33 PM Reply Quote 0
                    JMac @sdetweil
                    @sdetweil I hadn’t seen that, I was about to update the module individually then do some digging on here to see if others had had the issue.
                    do I use the list of commands in the link above, or the ones in this link?
                    https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                      JMac @sdetweil
                      @sdetweil I’ve hit this at the 3 command,
                      MagicMirror@raspberrypi:~/MagicMirror $ git switch _fix_clipping
                      error: Your local changes to the following files would be overwritten by checkout:
                      package-lock.json
                      Please commit your changes or stash them before you switch branches.
                      Aborting
                      S 1 Reply Last reply Jan 13, 2025, 5:47 PM Reply Quote 0
                        sdetweil @JMac
                        @JMac rm package-lock.json
                        J 1 Reply Last reply Jan 13, 2025, 5:51 PM Reply Quote 0
