    Help with calendar
    27 Posts 2 Posters 9.3k Views 2 Watching
      sdetweil @gerbenz
      @gerbenz no, the default calendar, where the events come from
      • G Offline
        gerbenz @sdetweil
                position: "middle_center",
        			coloredText: true,
                    broadcastPastEvents: false, // <= IMPORTANT to see past events
        			fetchInterval: 1000 * 60 * 1,
        					symbol: "werk stefnie",
        					url: "xxxxx"
                            symbol: "Stefanie",
                            url: "webcal://p181-caldav.icloud.com/published/xxxxx",
                            symbol: "Gezin",
                            symbol: "Amber",
                            url: "webcal://p181-caldav.icloud.com/published/xxxx",
                            symbol: "Luna",
                            url: "webcal://p181-caldav.icloud.com/published/xxxxxx",
                            symbol: "Gerben",
                            url: "webcal://p175-caldav.icloud.com/published/xxxxx",
          sdetweil @gerbenz
          @gerbenz fetch every 60 seconds?
          might be a spammer
          how about try 5 mins
          and comment out the position
          Ext3 tries not to flash the screen w updates, you are probably running into that with so frequent updates and so many cals all at different times
          you can look at the pm2’log and see timestamps when events are sent from each cal
          • G Offline
            gerbenz @sdetweil
            updating the screen works good.
            all calendars are working.
            butt when i hide the standard calendar then te addon calandar lost the events and is empty
              sdetweil @gerbenz
              @gerbenz but thats not how it works! the calendar module just keeps sending even when no position is specified.
              i have both setup on my system and it works perfectly
              maybe 10releases ago modules w no
              position would not be run
              you should be able to see the broadcasts go out in the logs
                @gerbenz show me the default calendar config whenExt3 is not working.
                • G Offline
                  gerbenz @sdetweil
                  I changed nothing, only possition to unknown dor the standard calendar.
                  And then the addon calendar is show no events
                    sdetweil @gerbenz
                    @gerbenz no, NOT unknown, thats invalid, module will not be loaded (there will be an error in the log about this)
                    just add
                    to the front of the line w position on it to comment it out
                    see mine that i posted earlier
                    https://forum.magicmirror.builders/post/123049
                    • G Offline
                      gerbenz @sdetweil
                      Okay i give it a try tomorrow.
                      Thanks so far for youre help.
                      I lett it know if it works.
                      And do i need delete the adresses from the standard calendar or not?
                        sdetweil @gerbenz
                        @gerbenz address?
                        look at my example
                        • G Offline
                          gerbenz @sdetweil
                          I mean urls,
                          I have in both the same urls for the calendar
                            sdetweil @gerbenz
                            @gerbenz i do not understand
                            • G Offline
                              gerbenz @sdetweil
                              // for the position line was the solution.
                              Thank u so much.
                              Now only need the calendar what bigger and every schedule my wife kids and me different colors and bigger text.
                              Only need to fins out how this works
                                sdetweil @gerbenz
                                @gerbenz all the size and style for Ext3 family of modules is done with css. there is lots of control, and lots to learn
                                • G Offline
                                  gerbenz @sdetweil
                                  yes a lot to learn.
                                  i have in the calendar conifg: useSymbol: false,
                                  butt then i gett a dott at the beginning of the event.
                                  is it possible to remove it?
                                  and i have six calendars with different collors and that works.
                                  but hole day events don’t color.
                                  They have black text with white border around it.
                                  i want the color that is corrosponding with the right calendar.
                                  alt text
                                  and this is my custom.css
                                  alt text
                                    sdetweil @gerbenz
                                    @gerbenz said in Help with calendar:
                                    yes, some css setting
                                    css setting
                                    css setting
                                    I don’t know all the possible css settings for this module. the author has made it quite flexible via css… but like all decent manuals/readme, he provides a reference (this module has these things) , “application” of the things takes critical thinking and exploration.
                                    one thing to help learn/make progress is to use the browser developer window, elements tab to userstand/test css changes on the live page
                                    see the second link in my signature below
