    MMM-pages - how to know which page index my module has?
    29 Posts 4 Posters 8.9k Views 4 Watching
    • evroomE Online
      evroom
      I am currently adopting MMM-MPlayer to interact with MMM-pages.
      Reason is that suspending the module does not suspend (stop) the stream, as it is an overlay.
      As long as MMM-MPlayer is running, it will always display the stream.
      From the config I can deduct the page index (3 in this case):
              ["compliments"], // page 1
              ["MMM-YrThen"], // page 2
              ["calendar"], // page 3
              ["MMM-MPlayer"], // page 4
      And I see that reflected in the log:
      0|MagicMirror  | [2025-01-18 16:13:55.383] [LOG]   [MMM-MPlayer.js:65:15] Received MMM-pages NEW_PAGE 3
      0|MagicMirror  | [2025-01-18 16:13:55.804] [LOG]   [module.js:189:7] compliments is suspended.
      0|MagicMirror  | [2025-01-18 16:13:55.835] [LOG]   [module.js:189:7] calendar is suspended.
      0|MagicMirror  | [2025-01-18 16:13:55.917] [LOG]   [module.js:189:7] MMM-YrThen is suspended.
      0|MagicMirror  | [2025-01-18 16:13:56.395] [LOG]   [module.js:196:7] clock is resumed.
      0|MagicMirror  | [2025-01-18 16:13:56.439] [LOG]   [module.js:196:7] MMM-MPlayer is resumed.
      But I would need to see my module name in the payload (MMM-MPlayer in this case), to act on the correct page index.
      Come to think of it, I also would need the keyword suspended or resumedin the payload, in order to know what to do.
      Any thoughts on this ?
      Best regards,
      E.J.
      MagicMirror version: 2.35.0
      Test environment:
      MagicMirror version: 2.36.0-develop
        sdetweil @evroom
        @evroom sorry, don’t quite understand
        your module would support the suspend/resume functions and be called at each appropriately
        MMM-pages calls hide and show
        there is also a ‘different’ way to configure pages
        use an arbitrary name for each page
        and then add that to the classes of the modules you want on that page
        see https://github.com/sdetweil/MMM-pages?tab=readme-ov-file#class-based-configuration
          @evroom
          from my SampleModule.js
          	// system notification your module is being hidden
          	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
          	suspend: function(){
          	// system notification your module is being unhidden/shown
          	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
          	resume: function(){
          S evroomE 2 Replies Last reply Reply Quote 0
            @evroom my MMM-SleepWake uses an external trigger to cause modules to be shown/hidden (screen saver where the screen won’t turn off)
            I provide a commandline command to interact with the module…
            i use a webcam with the motion project daemon to trigger show/hide
            • evroomE Online
              evroom @sdetweil
              Yeah, this module is kind of in my foster care.
              I did not come up with the code; only made some tweaks and made it available.
              There is not suspend or resume to been seen in the code.
              But I will study the stuff you mentioned and will try to implement that.
              Thx.
              Test environment:
              • evroomE Online
                evroom @evroom
                As a workaround, I will make it a requirement to put the MMM-Player on the first page (page index 0).
                When I receive 0, then I will start streaming, otherwise I will stop streaming.
                That seems to work.
                Test environment:
                evroomE M 3 Replies Last reply Reply Quote 0
                • evroomE Online
                  evroom @evroom
                  Short question:
                  There are 2 versions of MMM-pages:
                  https://github.com/edward-shen/MMM-pages
                  They seem in-sync, but which one would be the preferred one to take?
                  Test environment:
                    sdetweil @evroom
                    @evroom the core function is the same
                    i added the ability to have different page display times
                    i wrote the doc on the fixed page name approach
                    as you are using a notification now
                    just move that to suspend (same as index=0)
                    and the resume wakes you back up
                    • plainbrokeP Offline
                      plainbroke @sdetweil
                      He has the MMM-MPlayer working in pages and I am now using pages and MPlayer in my main MM.
                      Kinda of cool to be able to show a RSTP camera or 2 again…
                        sdetweil @plainbroke
                        @plainbroke cool
                          mvrlogins @evroom
                          @evroom said in MMM-pages - how to know which page index my module has?:
                          That seems to work.
                          Hi
                          Trying to use the mmm-mplayer module with mmm-pages, and it works fine, as you say, when the page index is 0.
                          However, I’d like to use it to only show video when called via notification
                          I have a single main page (without mplayer) - that shows all the time - and a single hidden page (with mplayer) to be shown when called via notification and then return the the main page with another notification.
                          I can’t currently implement this. Any ideas?
                          Thanks very much
                            sdetweil @mvrlogins
                            @mvrlogins why not? what triggers the notification??
                            button, command , …
                            you could prove this with the MMM-CommandtoNotification module
                              mvrlogins @sdetweil
                              I’m using MMM-Remote Control
                              The issue is that the video is shown all the time on page0.
                              I have 2 pages set up with MMM-Pages
                              • 1 page to be shown all the time
                              • 1 hidden page to be shown only when called.
                              The video needs to be on the hidden page. If I put classes : “hidden_page” under MMM-Player, the video feed shows on the page0 regardless.
                              The hidden page, when called, shows only the header fro MMM-Player and is otherwise blank
                              The page calling works fine with MMM-RemoteControl
                                      module: "MMM-pages",
                                          rotationTime: 1000 * 20, // rotate every 20 seconds
                                              ["page1"],           // class name for page 1
                                          fixed: ["fixed_page"],
                                          hiddenPages: {
                                              "Doorbell": ["doorbell_page"],
                              and
                              	module: 'MMM-MPlayer',
                                      classes: "doorbell_page",
                                      disabled: false,
                                      header: "MPlayer",
                              	  useTwoWindows: true,
                              	  layout: 'column',
                              	  monitorAspect: 0,
                              	  rotate: -1,
                              	  windowSize: { width: 640, height: 480 },
                              	  windowPosition: { x: 5, y: 225 },
                              	  streamInterval: 30000,
                              	  streams: {
                              		window1: [
                              		  'rtsp://10.0.1.1:7447/gv9eHrB9yZyPhgvN',
                              		window2: [
                              		  'rtsp://10.0.1.1:7447/D89zTJyDwN8YtKix',
                                mvrlogins @mvrlogins
                                Only thing I can think of right now is to put the video on page0 and the rest on page1
                                and then use a combination of the PAGE_CHANGED and PAUSE_ROTATION notifications to get what I want
                                Or is there a way to permanently pause rotation?
                                Then I can only use the PAGE_CHANGED call to get to the page I want
                                would the below disable rotation?
                                rotationTime: 1000 * 0,
                                  sdetweil @mvrlogins
                                  @mvrlogins i believe so. but you should have been able to send the notification for the named hidden page
                                  “SHOW_HIDDEN_PAGE”, “Doorbell”
                                  right?!
                                    mvrlogins @sdetweil
                                    @sdetweil said in MMM-pages - how to know which page index my module has?:
                                    right?!
                                    Yes, the notification works fine.
                                    But mplayer does not show up on the hidden page, only on the main page
                                      sdetweil @mvrlogins
                                      @mvrlogins hm, that makes no sense as the MagicMirror operations are the same
                                        sdetweil @mvrlogins
                                        @mvrlogins i opened this issue
                                        https://github.com/evroom/MMM-MPlayer/issues/4
                                        try my fork
                                        cd ~/MagicMirror/modules
                                        rename the existing folder out of the way
                                        git clone https://github.com/sdetweil/MMM-MPlayer
                                        change the page config to have the hidden page and the
                                        remote_control notification
                                        I submitted this change to the module for inclusion, depending on your results.
                                          mvrlogins @sdetweil
                                          Maybe something to do with mplayer itself, not the module MMM-Mplayer?
                                            sdetweil @mvrlogins
                                            @mvrlogins no, i fixed in my fork
