    [ERROR] unable to write js/positions.js
    14 Posts 4 Posters 3.5k Views 4 Watching
    • F
      FalcoonnnnPUNCH
      Newbie here, sorry if this is an obvious fix.
      I just installed MagicMirror on a Pi 3 A+ yesterday. I can start the magic mirror application but it only displays a blank black screen.
      I followed the following installation guide: https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
      full error message:
      “unable to write js/positions.js with the discovered module positions make the MagicMirror/js folder writeable by the uder starting MagicMirror”
      I’ve attempted to change ownership of the folder but was unsuccessful.
      • F
        FalcoonnnnPUNCH
        Hello all,
        So based on some of the comments here, i tried a new SD and a new pi. I had spare SDs lying around and I had a pi 4B that I was going to use initially but didn’t have a micro hdmi cable at the time so I had to use the 3. Micro HDMI cable came in, loaded piOS on the new SD, followed the MagicMirror install instructions and it came up first try.
        Not sure what the initial issue was with the original install but I honestly just needed a win before getting bogged down in the weeds with stuff. I would like to have some fun with it first. Might go back to the original pi3 at a later date just to try and correct the initial issue, but for now, I’m happy.
        The inital install, I had used sudo for the installation of MagicMirror, in this iteration I did not. I only utilized sudo to install the node.js
        thanks everyone for the advice/comments.
        S 2 Replies Last reply
          sdetweil @FalcoonnnnPUNCH
          @FalcoonnnnPUNCH tell me more. how is MagicMirror installed where?
          there was a bug on windows on 2.29, but it was fixed on 2.30 the current release
          did you use sudo while installing MagicMirror
          emloweE 1 Reply Last reply
          • emloweE
            emlowe Module Developer @sdetweil
            Although it’s not related to your problem - I have a lot of trouble getting MM to run on the 512MB Pi3 A+.
            It freezes often - possibly it’s bad h/w or sd card although it all tests fine - but after several days of running and it ends up frozen and inaccessible. (ie can’t ssh to it, etc unless I restart it)
            I tried using some of the lower memory options instead of using electron without much success. It runs for a little longer but eventually still dies. None of my Pi3 B models with the 4GB RAM have had similar problems - so I tend to think it is something related to RAM
            Just to say that you may find the experience in running on the Pi 3 A+ to be “complicated”
              sdetweil @emlowe
              @emlowe what os level are you running?
              i recommend the 32 bit legacy image
              if you use my install script i will increase the swap spacr
              • emloweE
                uname -m
                armv7l
                cat /etc/os-release
                PRETTY_NAME="Raspbian GNU/Linux 12 (bookworm)"
                free -h
                               total        used        free      shared  buff/cache   available
                Mem:           425Mi       316Mi        99Mi       8.1Mi        67Mi       108Mi
                Swap:          732Mi       274Mi       457Mi
                swapon -s
                Filename				Type		Size		Used		Priority
                /var/swap                               file		204796		0		-2
                /dev/zram0                              partition	544892		299760		15
                zramctl
                NAME       ALGORITHM DISKSIZE   DATA COMPR  TOTAL STREAMS MOUNTPOINT
                /dev/zram0 lz4         532.1M 292.7M 98.2M 101.8M       4 [SWAP]
                Jan 26 22:00:46 kid-mirror kernel: Out of memory: Killed process 23127 (WebKitWebProces) total-vm:1178000kB, anon-rss:184084kB, file-rss:0kB, shmem-rss:0kB, UID:1000 pgtables:1044kB oom_score_adj:0
                  sdetweil @emlowe
                  @emlowe yes, i would try the 32 but legacy image on bullseye
                  bookworm seems about 500m bigger
                    sdetweil @emlowe
                    @emlowe out of memory
                    plainbrokeP 1 Reply Last reply
                    • plainbrokeP
                      plainbroke @sdetweil
                      @FalcoonnnnPUNCH
                      @emlowe
                      I have had that problem before and it was a bad card. One other time it was a bad USB drive… Might try a different sdcard.
                        sdetweil @plainbroke
                        @plainbroke good point, I have had a number of sd card failures over the years, and they have all become read-only
                        • F
                          FalcoonnnnPUNCH
                          Hello all,
                            @FalcoonnnnPUNCH IF you had used my install script it would have done all that for you
                              @FalcoonnnnPUNCH and sudo would have caused the prior problem. as the folder would have been write protected
                              F 1 Reply Last reply
                              • F
                                FalcoonnnnPUNCH @sdetweil
                                @sdetweil Thank you! To fix that issue, reinstall MagicMirror without using sudo command?
                                  @FalcoonnnnPUNCH correct. NEVER use sudo for any MagicMirror related commands
                                  sudo makes everything owned by root
                                  where no user can modify
                                  just use my install/upgrade scripts. listed in alternative install section of MagicMirror doc
