    How to modify my MMM-CalendarExt3?
    5 Posts 3 Posters 910 Views 3 Watching
    • E Offline
      etnec
      Hello there!
      First of all, thanks for the help provided in the forum it has helped my a lot during the time developing my MagicMirror. Anyway, I have not registered into the web until now because I have not found a solution for this.
      I have my MMM-CalendarExt3 set up and it’s working normally as you can see in the attached picture. Anyway, I just want to show the ongoing day and maybe 3-4 days after the ongoing day. Like this, I would like to have a better (bigger) view of the tasks on my calendar. So I am also looking for having bigger cells, bigger fonts and more tasks on my cells.
      alt text
      Any help?
      Thanks in advance!
      • emloweE Offline
        emlowe Module Developer
        I would try using Ext3Agenda version in horizontal layout - it is by the same author and it sounds like the Horizontal layout might be what you want
        https://github.com/MMRIZE/MMM-CalendarExt3Agenda
        https://github.com/MMRIZE/MMM-CalendarExt3Agenda/wiki/Horizontal-layout
        • E Offline
          etnec @emlowe
          @emlowe said in How to modify my MMM-CalendarExt3?:
          Thanks mate.
          The problem is that my mirror is not horizontal at all :D
          Anyway, do you know if with CalendarExt3Agenda I can add three (or maybe four) shared calendars from iOS?
          emloweE S 2 Replies Last reply Reply Quote 0
          • emloweE Offline
            emlowe Module Developer @etnec
            Then use Ext3Agenda in the normal way vertical way.
            In any event, it sounds like you don’t want the month view - and Ext3 does have just a week view - so maybe it’s as simple as just using week view for you.
            Ext3Agenda supports calendars in the same way AFAIK as Ext3 - so I would expect if Ext3 works then Ext3Agenda also works
              sdetweil @etnec
              @etnec the default calendar provides the events for the Ext3 family of modules
              just add another
                url: ....
              entry to the calendars:[]
              list
