    Installation issues
    13 Posts 2 Posters 2.3k Views 2 Watching
    • N Offline
      neo_anderson
      Hi there,
      Happy holidays.
      New to the community.
      Happy to be here.
      This is my first time trying to build a smart mirror.
      Im in the installation phase and getting an error.
      Seems there is a compatibility issue.
      The version Ive got is 2.29.0.
      See attached for a screenshot.
      How do I address this?
      Thank you for your help.
      • N Offline
        neo_anderson @sdetweil
        @sdetweil I got it working. Tried the manual method but it didnt work so then I tried your automatic script and it worked perfectly. much appreciated.
        is there a way to get the software to prompt for the user to select from a pre-built list of modules and syn with an email account?
          sdetweil @neo_anderson
          @neo_anderson no screen shot
          • N Offline
              @neo_anderson yes, MagicMirror requires node version 20 or 22. your system has node 10
              if you run the automated install script, (listed in alternative install methods) it would have auto upgraded node to the proper level
              we currently don’t support mode 23, but the release next week (jan 1) does
              • N Offline
                @sdetweil thanks for the response.Capture 2.PNG I went to the alternative installation methods and tried to run the automatic installation script but it asked me to update rasp OS. i did that using the script on their website: sudo apt full-upgrade which ran successfully but when i went back to try to run the automatic installation script it gives me the same error. any help would be great.
                  @neo_anderson apt upgrade does not change your system to new version, only bring this version up to date
                  lsb_release -a
                  shows the os version detail
                  buster is 2 versions back
                  bullseye and bookworm since then, bookworm, the current version, has been out over a year now
                  N 2 Replies Last reply Reply Quote 0
                  • N Offline
                    @sdetweil Thanks. that makes sense. Im on buster. see below. I was searching how to upgrade to bookwork but from my understanding it’s not very simple. any recommendations?
                    pi@raspberrypi:~ $ lsb_release -a
                    No LSB modules are available.
                    Distributor ID: Raspbian
                    Description: Raspbian GNU/Linux 10 (buster)
                    Release: 10
                    Codename: buster
                    • N Offline
                      @sdetweil alternatively, is it simple better to format the pi and install bookworm from scratch?
                        @neo_anderson said in Installation issues:
                        yes, better to start with new base
                        backup MM config…
                        see my https://github.com/sdetweil/MagicMirror-backup-restore
                        make sure to copy backup folder (MM_backup) off or push to git
                        so you can have it for restore
                        • N Offline
                            @neo_anderson no we don’t have that
                            i am working in a new module installer that will let you pick from the 3rd party list catalog.
                            then after installing those will open my mmm-config module to allow you to configure the modules you installed
                            (and you can go back there at any tine, installer or config)
                            i don’t think there is any concept of pre-built list of modules
                            my restore script works from a list of the urls (created at backup tine), but its just a text file list
                            • N Offline
                              @sdetweil Hi there, Hope your Jan went well. Just wanted to touch base to see how youre making out with the new module. Sounds quite exciting.
                                @neo_anderson you can try it out
                                See
                                https://forum.magicmirror.builders/post/123306
                                There is more info before that post, but this gets you the latest version
