    Weather issue
    10 Posts 2 Posters 904 Views 2 Watching
      atl944
      Hi, new to MagicMirror and looking for a little advise. Not sure why my weather is showing some weird temps. I am using the default config.js file and I tried changing some of the values with Fahrenheit to Celsius. But that did not make difference. I am just trying to set it to Bluffton, SC 29910.
      Any help would be appreciated.
      I am attaching a screen showing the wrong values and my config.js file.
      thanks
      [config.js](Invalid file type. Allowed types are: .jpg, .jpeg, .png, .gif, .png, .jpg, .jpeg, .gif)
        sdetweil @atl944
        @atl944 temp is set to Celsius/metric
        settings in config.js you may want to change
                language: "en",
                locale: "en-US",
                timeFormat: 12,
                units: "imperial",
        these are mine changed
          sdetweil @atl944
          @atl944 can u copy/paste the weather config
          xxx out your apikey
          A 2 Replies Last reply Reply Quote 0
            atl944 @sdetweil
            @sdetweil Not using an API key, but here i s what I have:
            			module: "weather",
            				weatherProvider: "openmeteo",
            				type: "current",
            				lat: 40.776676,
            				lon: -73.971321
            			module: "weather",
            			header: "Weather Forecast",
            				type: "forecast",
            				lat: 40.776676,
            				lon: -73.971321
              sdetweil @atl944
              @atl944 lat/lon for Bluffton, SC
              the lat/lon in in the sample is ny central park
                atl944 @sdetweil
                @sdetweil thanks for the help…
                {			module: "weather",
                				type: "current",
                				lat: 40.776676,
                				lon: -73.971321 {
                			module: "weather",
                				type: "forecast",
                				lat: 40.776676,
                				lon: -73.971321
                  sdetweil @atl944
                  @atl944 don’t post duplicate messages. anyone with reputation below 2 gets every message reviewed before publishing
                  but you didn’t put the correct values in for lat/lon
                  those are the sample values
                    atl944 @sdetweil
                    sorry about the dup post, didn’t think the first one posted.
                    If that is for NY, why is it displaying 2.2 >? What is that? It can’t be 2.2 degrees.
                    thanks again
                      sdetweil @atl944
                              language: "en",
                              locale: "en-US",
                              timeFormat: 12,
                              units: "imperial",
                        atl944 @sdetweil
                        You don’t know how much I appreciate the help, I will make the changes and test.
                        On another note, do you have any good resources for MagicMirror in general?
                          sdetweil @atl944
                          @atl944 said in Weather issue:
                          what do you mean?
                          there is the doc, linked in the top menu
                          https://docs.magicmirror.builders/configuration/introduction.html#basic-configuration-of-magicmirror2
                          and here of course
                          we don’t provide any video tutorials, altho others have done that for some solutions
                          i am the moderator here, but also module developer, and support the install/upgrade scripts, and backup/restore scripts too…
