    Weather issue
    10 Posts 2 Posters 903 Views 2 Watching
      atl944 @sdetweil
      @sdetweil Not using an API key, but here i s what I have:
      			module: "weather",
      				weatherProvider: "openmeteo",
      				type: "current",
      				lat: 40.776676,
      				lon: -73.971321
      			module: "weather",
      			header: "Weather Forecast",
      				type: "forecast",
      				lat: 40.776676,
      				lon: -73.971321
        sdetweil @atl944
        @atl944 lat/lon for Bluffton, SC
        the lat/lon in in the sample is ny central park
          atl944 @sdetweil
          @sdetweil thanks for the help…
          {			module: "weather",
          				type: "current",
          				lat: 40.776676,
          				lon: -73.971321 {
          			module: "weather",
          				type: "forecast",
          				lat: 40.776676,
          				lon: -73.971321
            sdetweil @atl944
            @atl944 don’t post duplicate messages. anyone with reputation below 2 gets every message reviewed before publishing
            but you didn’t put the correct values in for lat/lon
            those are the sample values
              atl944 @sdetweil
              sorry about the dup post, didn’t think the first one posted.
              If that is for NY, why is it displaying 2.2 >? What is that? It can’t be 2.2 degrees.
              thanks again
                sdetweil @atl944
                @atl944 temp is set to Celsius/metric
                settings in config.js you may want to change
                        language: "en",
                        locale: "en-US",
                        timeFormat: 12,
                        units: "imperial",
                these are mine changed
                  atl944 @sdetweil
                  You don’t know how much I appreciate the help, I will make the changes and test.
                  On another note, do you have any good resources for MagicMirror in general?
                    sdetweil @atl944
                    @atl944 said in Weather issue:
                    what do you mean?
                    there is the doc, linked in the top menu
                    https://docs.magicmirror.builders/configuration/introduction.html#basic-configuration-of-magicmirror2
                    and here of course
                    we don’t provide any video tutorials, altho others have done that for some solutions
                    i am the moderator here, but also module developer, and support the install/upgrade scripts, and backup/restore scripts too…
