    New module installer
    51 Posts 7 Posters 25.1k Views 6 Watching
      MDWEBB @sdetweil
      @sdetweil i am using your remote control module yes very handy, however having issues utilising the MMM-Module-Scheduler to to turn my monitor on and off via Remote-Control. i can see in the developer window its trying to send the notification however my monitor isn’t turning off. Am i missing something?
              module: 'MMM-ModuleScheduler',
                  notification_schedule: [
                      // TURN THE MONITOR/SCREEN ON AT 07:30 EVERY DAY
                      {notification: 'REMOTE_ACTION', schedule: '30 7 * * *', payload: {action: "MONITORON"}},
                      // TURN THE MONITOR/SCREEN OFF AT 22:30 EVERY DAY
                      {notification: 'REMOTE_ACTION', schedule: '01 14 * * *', payload: {action: "MONITOROFF"}},
                      // RESTART THE MAGICMIRROR PROCESS AT 2am EVERY SUNDAY
                      {notification: 'REMOTE_ACTION', schedule: '0 2 * * SUN', payload: {action: "RESTART"}}
        sdetweil @MDWEBB
        @MDWEBB issue on remotecontrol
        is not MY remote control, I just fixed the error trap that was misleading
        no other code change
        https://github.com/Jopyth/MMM-Remote-Control/issues/303
        which one of the 10 or 12 ways does it try to turn monitor off??
        which OS is different
        which window compositor is different x11/wayland/labwc is different
        I know MMM-PIR has been working hard on making it woirk thru all the choices
        did it work before and doesn’t now??
        I don’t know the module internals…
          @MDWEBB I just resynced my fork with his latest remote-control
          he had most of my changes and seemed to catch that error… maybe
            I just updated the code again, this time to provide opening the readme for the repo in both install and config
            its on a different branch again
            git pull
            git checkout better_repo_url
            npm install     # <--- required.. added another library and copies a template file
            everything else is the same, except there is a button to open the module readme
            an example from the installer page, exactly the same on the config page
            still have some trouble with our own docs site, gitlab
            the readme window will open at the button position
              @sdetweil said in New module installer:
              just posted another update for better handling of the repo readme (in most cases)
              and handles readme’s for repo ADDs to the 3rd party list list, deletes worked ok before
              and for the readme during config, use the file in the installed module folder, instead of trying to get the github repo version
              same process
              git pull
              git checkout better_repo_url  # if already there not needed
              the copy fixes a bug in the readme list file
              and if this is first time using, make sure to add
              MMM-Config to your config.js
                    module:"MMM-Config"
                     position:"...", // only for qrcode if you use that
                      config:{
              • H Offline
                hadal
                Hi All
                I don’t know where I made a mistake, can you help me?
                  sdetweil @hadal
                  @hadal did you do the npm install? and add MMM-Config to your config.js
                  can you show
                  in the MMM-Config folder
                  do
                  git branch
                  ls module_url_hash.json
                  in the module_installer folder
                  ls module_selector_schema.json
                    added new url for launching the config side
                    http://mm_address:mm_port/configure
                    both main and better_repo_url branches
                      updated for missing calendar url… properties, and missing module header…
                        i am considering merging the extra branches back w the base
                        but its been quiet, so i am not sure if there are other changes, or if ive got the functionality right
                        any feedback welcomed
                          now merged w base branch, main
                          • F Offline
                            furqanhamid @sdetweil
                            This is awesome! Having a streamlined, end-to-end solution for modules will make setting up MM so much easier. Appreciate the effort. BTW, I am still confused that whether it is still working or not!
                              sdetweil @furqanhamid
                              @furqanhamid which says you didnt try it.
                                Anybody try this and have any feedback?
                                  Just added search in the installer
                                  • 3 / 3
