    New module installer
    51 Posts 7 Posters 26.2k Views 6 Watching
      There has been a lot of discussion for a while about the complexities of getting MM up and running…
      I think we need an end to end solution for modules… so… well… here it is
      see the post below as the implementation has changed
      https://forum.magicmirror.builders/post/123176
      happy installing!!!
      pics
      main page
      expanded category
      expanded module
      expanded unregistered section
      F 1 Reply Last reply Reply Quote 1
        chrisfr1976
        @sdetweil it is running on my pi but until now i didn‘t need it. I have no space for a new module left ;)
        But i‘ll try tomorrow and give you a feedback.
        Regards, Chris.
          sdetweil @chrisfr1976
          @chrisfr1976 it takes space too
            chrisfr1976 @sdetweil
            @sdetweil i hope that your installer can also uninstall a module … g
            Regards, Chris.
              @chrisfr1976 no, cannot uninstall. just remove the module folder
              from above and readme
              this will NOT uninstall modules
                @chrisfr1976 but if that is a requirement… it IS possible of course
                  I think this doesn’t work as an outside command… I mean TECHNICALLY it does,
                  but it depends on too much work for the user…
                  see the corrected implementation
                    yesterday I was off. Now I tried to install it but I got this error:
                    chris@MagicPi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/installer/refs/heads/main/installit)"
                    Klone nach 'installer' ...
                    remote: Enumerating objects: 257, done.
                    remote: Counting objects: 100% (24/24), done.
                    remote: Compressing objects: 100% (18/18), done.
                    remote: Total 257 (delta 10), reused 17 (delta 6), pack-reused 233 (from 1)
                    Empfange Objekte: 100% (257/257), 1005.39 KiB | 4.31 MiB/s, fertig.
                    L?se Unterschiede auf: 100% (151/151), fertig.
                    Hinweis: Es wird davon abgeraten zu Pullen, ohne anzugeben, wie mit abweichenden
                    Hinweis: Branches umgegangen werden soll. Sie k?nnen diese Nachricht unterdr?cken,
                    Hinweis: indem Sie einen der folgenden Befehle ausf?hren, bevor der n?chste Pull
                    Hinweis: ausgef?hrt wird:
                    Hinweis:
                    Hinweis:   git config pull.rebase false  # Merge (Standard-Strategie)
                    Hinweis:   git config pull.rebase true   # Rebase
                    Hinweis:   git config pull.ff only       # ausschlie?lich Vorspulen
                    Hinweis:
                    Hinweis: Sie k?nnen statt "git config" auch "git config --global" nutzen, um
                    Hinweis: einen Standard f?r alle Repositories festzulegen. Sie k?nnen auch die
                    Hinweis: Option --rebase, --no-rebase oder --ff-only auf der Kommandozeile nutzen,
                    Hinweis: um das konfigurierte Standardverhalten pro Aufruf zu ?berschreiben.
                    Do you want execute the module installer now? (y/N)?y
                    ./installer.sh: Zeile 32: cd: ../../modules/MMM-Config: Datei oder Verzeichnis nicht gefunden
                    cp: der Aufruf von stat f?r 'module_schema_template.json' ist nicht m?glich: Datei oder Verzeichnis nicht gefunden
                    node:internal/modules/cjs/loader:1251
                      throw err;
                    Error: Cannot find module '/home/chris/MagicMirror/installers/formatModuleInfo.js'
                        at Module._resolveFilename (node:internal/modules/cjs/loader:1248:15)
                        at Module._load (node:internal/modules/cjs/loader:1074:27)
                        at TracingChannel.traceSync (node:diagnostics_channel:315:14)
                        at wrapModuleLoad (node:internal/modules/cjs/loader:217:24)
                        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:166:5)
                        at node:internal/main/run_main_module:30:49 {
                      code: 'MODULE_NOT_FOUND',
                      requireStack: []
                    Node.js v22.9.0
                    ./installer.sh: Zeile 68: ./install_module.sh: Datei oder Verzeichnis nicht gefunden
                      throw err;
                    Error: Cannot find module '/home/chris/MagicMirror/installers/runserver.js'
                      requireStack: []
                    Node.js v22.9.0
                    Regards, Chris.
                      @chrisfr1976
                      thanks for your patience… I think this will be better
                      I have merged the installer function into the MMM-Config module
                      currently the installer function is in a separate branch (with_installer) while we test it out
                      note: if you are using docker, then these steps need to be done INSIDE the running container, using
                      docker exec -it mm bash
                      to get to a commandline inside the container
                      AFTER using ssh to get to the docker host commandline
                      if you don’t have MMM-Config
                      cd ~/MagicMirror/modules
                      git clone https://github.com/sdetweil/MMM-Config
                      cd MMM-Config
                      git checkout with_installer
                      npm install
                      see the readme above on how to add this module to your config.js
                      if you already have MMM-Config
                      cd ~/MagicMirror/modules/MMM-Config
                      git pull
                      npm install
                      no configuration changes are required
                      restart your MagicMirror instance
                      for docker based MM instances, the steps are the same
                      I notice that some of the files in the git pull will be marked as changed,
                      altho its only the permissions
                      so erase those files and then git pull
                      and then checkout the with_installer branch
                      etc
                      Using the installer
                      use this url
                      http://mm_server:MM_port/installer
                      and you will get the installer module selection page
                      see the readme for usage
                      after pushing the install selected modules button and the individual module installs complete,
                      the MMM-Config configuration page will replace the installer page you had open
                      when you are done configuring the modules, press Save, Create config
                      and the current MMM-Config page will be closed, and your MM instance will be restarted
                      (in most cases)
                      from the readme
                      MMM-Config will try to restart your MagicMirror system after configuration is complete
                      if the MagicMirror instance is configured to auto restart due to config.js, that will happen naturally
                      if the MagicMirror instance is NOT configured to auto restart due to config.js, then the MMM-Config **restart option** will be used to restart
                      if the MagicMirror instance is in a docker container, like khassel's then the MagicMirror process will be killed, causing the container to restart
                      if none of those options work, then you will have to restart the MagicMirror instance manually (same as if you modified config.js on your own)
                      • plainbrokeP
                        plainbroke @sdetweil
                        All I am getting is this:
                        “Select all the modules you would like to install”
                        Nothing else it is just white below that …
                          sdetweil @plainbroke
                          @plainbroke go to the module folder and do git pull
                          then reload the installer page
                          plainbrokeP 2 Replies Last reply Reply Quote 0
                          • plainbrokeP
                            Ok did the git pull now I get the same thing but in a tan background color.
                            should i do the
                            git pull
                            npm install
                            did that and it says everything is up to date.
                            I really hoped that would get it running.
                            Sounds like a very useful module.
                            • plainbrokeP
                              http://192.168.1.200:8280/modules/MMM-Config/module_installer/module_installer.html
                              Is that the installer page you are talking about?
                              Or is there something else I should try???
                                @plainbroke hm…
                                can you open the module folder and see if
                                module_form_schema.json
                                is present
                                also can you open the config page
                                http://server:port/modules/MMM-Config/review
                                  @plainbroke if you go to /installer it redirects to the correct url
                                  • plainbrokeP
                                    pi@CameraS:~/MagicMirror/modules/MMM-Config $ dir
                                    config.html                       form-client.js                     node_helper.js     schema3_19492568968280.json  translations
                                    config_lastchange_19492568968280  MMM-Config.css                     node_modules       schemas                      webform.css
                                    create_form_for_module.cmd        MMM-Config.js                      package.json       scripts                      webform.js
                                    create_form_for_module.sh         MMM-Config.schema.json             package-lock.json  templates                    workdir
                                    defaults_19492568968280.js        module_installer                   postinstall        test_convert.cmd
                                    doc_images                        modules_lastchange_19492568968280  postinstall.cmd    test_convert.sh
                                    exec_script.js                    modules_list.txt                   README.md          touch.cmd
                                    When I ran it with review it came back.
                                    Cannot GET /modules/MMM-Config/installer
                                      @plainbroke sorry cd module_installer
                                      • plainbrokeP
                                        Yes it is in there.
                                        I am going to turn in been sick for the last 2 days. worn out…
                                        Take your time with it. I am in no hurry.
                                        S 3 Replies Last reply Reply Quote 1
                                          @plainbroke I just did a fresh install on a new MM… on a different machine
                                          when I bring up the MM page it works
                                          when I bring up the installer page it works… takes a few seconds
                                          when I open the MMM-Config/review page the configuration page comes up
                                          open the installer page
                                          http://server:port/installer
                                          open the developers window, ctrl-shift-i
                                          go to the console tab , see if there are any errors
                                          open the sources tab
                                           left nav
                                          selec modules,
                                            mmm-config
                                                module_installer
                                                       select the form-client.js
                                                       scroll the source to line 120, click on the line number
                                                       should turn blue
                                          like this
                                          hit f5 refresh the page
                                          it should look like this
                                          you should be able to scroll the mouse over the words incoming_json
                                          and it should pop up a big window of the json
                                          like this
                                            @plainbroke feel better… this is not that important
