    New module installer
    51 Posts 7 Posters 26.8k Views 6 Watching
      @chrisfr1976
      thanks for your patience… I think this will be better
      I have merged the installer function into the MMM-Config module
      currently the installer function is in a separate branch (with_installer) while we test it out
      note: if you are using docker, then these steps need to be done INSIDE the running container, using
      docker exec -it mm bash
      to get to a commandline inside the container
      AFTER using ssh to get to the docker host commandline
      if you don’t have MMM-Config
      cd ~/MagicMirror/modules
      git clone https://github.com/sdetweil/MMM-Config
      cd MMM-Config
      git checkout with_installer
      npm install
      see the readme above on how to add this module to your config.js
      if you already have MMM-Config
      cd ~/MagicMirror/modules/MMM-Config
      git pull
      npm install
      no configuration changes are required
      restart your MagicMirror instance
      for docker based MM instances, the steps are the same
      I notice that some of the files in the git pull will be marked as changed,
      altho its only the permissions
      so erase those files and then git pull
      and then checkout the with_installer branch
      etc
      Using the installer
      use this url
      http://mm_server:MM_port/installer
      and you will get the installer module selection page
      see the readme for usage
      after pushing the install selected modules button and the individual module installs complete,
      the MMM-Config configuration page will replace the installer page you had open
      when you are done configuring the modules, press Save, Create config
      and the current MMM-Config page will be closed, and your MM instance will be restarted
      (in most cases)
      from the readme
      MMM-Config will try to restart your MagicMirror system after configuration is complete
      if the MagicMirror instance is configured to auto restart due to config.js, that will happen naturally
      if the MagicMirror instance is NOT configured to auto restart due to config.js, then the MMM-Config **restart option** will be used to restart
      if the MagicMirror instance is in a docker container, like khassel's then the MagicMirror process will be killed, causing the container to restart
      if none of those options work, then you will have to restart the MagicMirror instance manually (same as if you modified config.js on your own)
      plainbrokeP 1 Reply Last reply
      • plainbrokeP
        plainbroke @sdetweil
        All I am getting is this:
        “Select all the modules you would like to install”
        Nothing else it is just white below that …
          sdetweil @plainbroke
          @plainbroke go to the module folder and do git pull
          then reload the installer page
          plainbrokeP 2 Replies Last reply
          • plainbrokeP
            Ok did the git pull now I get the same thing but in a tan background color.
            should i do the
            git pull
            npm install
            did that and it says everything is up to date.
            I really hoped that would get it running.
            Sounds like a very useful module.
            • plainbrokeP
              http://192.168.1.200:8280/modules/MMM-Config/module_installer/module_installer.html
              Is that the installer page you are talking about?
              Or is there something else I should try???
                @plainbroke hm…
                can you open the module folder and see if
                module_form_schema.json
                is present
                also can you open the config page
                http://server:port/modules/MMM-Config/review
                  @plainbroke if you go to /installer it redirects to the correct url
                  • plainbrokeP
                    pi@CameraS:~/MagicMirror/modules/MMM-Config $ dir
                    config.html                       form-client.js                     node_helper.js     schema3_19492568968280.json  translations
                    config_lastchange_19492568968280  MMM-Config.css                     node_modules       schemas                      webform.css
                    create_form_for_module.cmd        MMM-Config.js                      package.json       scripts                      webform.js
                    create_form_for_module.sh         MMM-Config.schema.json             package-lock.json  templates                    workdir
                    defaults_19492568968280.js        module_installer                   postinstall        test_convert.cmd
                    doc_images                        modules_lastchange_19492568968280  postinstall.cmd    test_convert.sh
                    exec_script.js                    modules_list.txt                   README.md          touch.cmd
                    When I ran it with review it came back.
                    Cannot GET /modules/MMM-Config/installer
                      @plainbroke sorry cd module_installer
                      • plainbrokeP
                        Yes it is in there.
                        I am going to turn in been sick for the last 2 days. worn out…
                        Take your time with it. I am in no hurry.
                        S 3 Replies Last reply
                          @plainbroke I just did a fresh install on a new MM… on a different machine
                          when I bring up the MM page it works
                          when I bring up the installer page it works… takes a few seconds
                          when I open the MMM-Config/review page the configuration page comes up
                          open the installer page
                          http://server:port/installer
                          open the developers window, ctrl-shift-i
                          go to the console tab , see if there are any errors
                          open the sources tab
                           left nav
                          selec modules,
                            mmm-config
                                module_installer
                                       select the form-client.js
                                       scroll the source to line 120, click on the line number
                                       should turn blue
                          like this
                          hit f5 refresh the page
                          it should look like this
                          you should be able to scroll the mouse over the words incoming_json
                          and it should pop up a big window of the json
                          like this
                            @plainbroke feel better… this is not that important
                              @plainbroke i pushed a bunch of fixes.
                              • plainbrokeP
                                I removed it with rm -rf MMM-Config
                                Then rebooted Pi
                                Then reinstalled with:
                                cd MMM-Config
                                npm install
                                THAT DID NOT WORK.
                                threw all kinds of errors in shift+ctrl+i
                                So I went back to the
                                cd MMM_Config module and ran
                                git pull
                                npm install
                                rebooted the Pi
                                Now it works.
                                Why I do not know.
                                But it does. I am going to try it out with MMM-MPlayer.
                                Thanks for the great work…
                                S 2 Replies Last reply
                                  @plainbroke said in New module installer:
                                  yes, that will put you on the root branch main or master
                                  you have to checkout the other branch that has the installer function in it
                                    @plainbroke pushed a few more updates… now open repo button in configuration screens as well as installer
                                    M 1 Reply Last reply
                                      MDWEBB @sdetweil
                                      @sdetweil Hi Sam,
                                      I update the fetch interval on my CalendarExt3 module via MMM-Config as i had a power flick and events hadn’t came back quick enough for my liking. However now the whole CalendarExt3 module is not display and i am getting errors on start up saying it can’t calidate main module.js i hadn’t made any changes outside of the config module. I tried uninstalling CalendaerExt3 and reinstalling but without any luck would love some guidance. Will past the latest config module below also.
                                      mdwebb@raspberrypi:~/MagicMirror $ npm start
                                      > magicmirror@2.31.0-develop start
                                      > npm run start:x11
                                      > magicmirror@2.31.0-develop start:x11
                                      [2025-01-20 20:36:52.086] [LOG]   Starting MagicMirror: v2.31.0-develop
                                      [2025-01-20 20:36:52.114] [LOG]   Loading config ...
                                      [2025-01-20 20:36:52.116] [LOG]   config template file not exists, no envsubst
                                      [2025-01-20 20:36:52.693] [INFO]  Checking config file /home/mdwebb/MagicMirror/config/config.js ...
                                      [2025-01-20 20:36:52.837] [INFO]  Your configuration file doesn't contain syntax errors :)
                                      [2025-01-20 20:36:52.839] [INFO]  Checking modules structure configuration ...
                                      [2025-01-20 20:36:52.983] [INFO]  Your modules structure configuration doesn't contain errors :)
                                      [2025-01-20 20:36:52.985] [LOG]   Loading module helpers ...
                                      [2025-01-20 20:36:52.997] [LOG]   Initializing new module helper ...
                                      [2025-01-20 20:36:52.998] [LOG]   Module helper loaded: updatenotification
                                      [2025-01-20 20:36:52.999] [LOG]   No helper found for module: clock.
                                      [2025-01-20 20:36:53.000] [LOG]   No helper found for module: MMM-CountDown.
                                      [2025-01-20 20:36:53.244] [LOG]   Initializing new module helper ...
                                      [2025-01-20 20:36:53.244] [LOG]   Module helper loaded: MMM-ImagesPhotos
                                      [2025-01-20 20:36:53.265] [LOG]   Initializing new module helper ...
                                      [2025-01-20 20:36:53.265] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
                                      [2025-01-20 20:36:53.429] [LOG]   Initializing new module helper ...
                                      [2025-01-20 20:36:53.429] [LOG]   Module helper loaded: MMM-Config
                                      [2025-01-20 20:36:53.430] [LOG]   No helper found for module: MMM-CalendarExt3.
                                      [2025-01-20 20:36:53.430] [LOG]   No helper found for module: alert.
                                      [2025-01-20 20:36:53.526] [LOG]   Initializing new module helper ...
                                      [2025-01-20 20:36:53.527] [LOG]   Module helper loaded: calendar
                                      [2025-01-20 20:36:53.650] [LOG]   Initializing new module helper ...
                                      [2025-01-20 20:36:53.650] [LOG]   Module helper loaded: MMM-Remote-Control
                                      [2025-01-20 20:36:53.698] [LOG]   Initializing new module helper ...
                                      [2025-01-20 20:36:53.698] [LOG]   Module helper loaded: MMM-ModuleScheduler
                                      [2025-01-20 20:36:53.699] [LOG]   All module helpers loaded.
                                      [2025-01-20 20:36:53.711] [LOG]   Starting server on port 8080 ...
                                      [2025-01-20 20:36:54.371] [LOG]   Server started ...
                                      [2025-01-20 20:36:54.377] [LOG]   Connecting socket for: updatenotification
                                      [2025-01-20 20:36:54.378] [LOG]   Starting module helper: updatenotification
                                      [2025-01-20 20:36:54.384] [LOG]   Connecting socket for: MMM-ImagesPhotos
                                      [2025-01-20 20:36:54.386] [LOG]   Starting node helper for: MMM-ImagesPhotos
                                      [2025-01-20 20:36:54.389] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
                                      [2025-01-20 20:36:54.390] [LOG]   Starting node_helper for MMM-OpenWeatherMapForecast
                                      [2025-01-20 20:36:54.396] [LOG]   Connecting socket for: MMM-Config
                                      [2025-01-20 20:36:54.727] [LOG]   will pull config data at 17:00:00 in 22985320 ms
                                      [2025-01-20 20:36:54.729] [LOG]   Connecting socket for: calendar
                                      [2025-01-20 20:36:54.736] [LOG]   Starting node helper for: calendar
                                      [2025-01-20 20:36:54.738] [LOG]   Connecting socket for: MMM-Remote-Control
                                      [2025-01-20 20:36:54.744] [LOG]   Starting node helper for: MMM-Remote-Control
                                      [2025-01-20 20:36:54.848] [LOG]   Connecting socket for: MMM-ModuleScheduler
                                      [2025-01-20 20:36:54.849] [LOG]   Starting node helper for: MMM-ModuleScheduler
                                      [2025-01-20 20:36:54.850] [LOG]   Sockets connected & modules started ...
                                      [2025-01-20 20:36:55.644] [LOG]   Launching application.
                                      [2025-01-20 20:36:57.126] [INFO]  System information:
                                      ### SYSTEM:   manufacturer: ; model: ; virtual: false
                                      ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
                                      ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
                                      ### OTHER:    timeZone: Australia/Melbourne; ELECTRON_ENABLE_GPU: undefined
                                      [2025-01-20 20:36:57.162] [ERROR] ERROR! Could not validate main module js file.
                                      [2025-01-20 20:36:57.168] [ERROR] ReferenceError: HTMLElement is not defined
                                          at Object.<anonymous> (/home/mdwebb/MagicMirror/modules/MMM-CalendarExt3/MMM-CalendarExt3.js:6:26)
                                          at Module._compile (node:internal/modules/cjs/loader:1484:14)
                                          at Module._extensions..js (node:internal/modules/cjs/loader:1564:10)
                                          at Module.load (node:internal/modules/cjs/loader:1295:32)
                                          at Module._load (node:internal/modules/cjs/loader:1111:12)
                                          at c._load (node:electron/js2c/node_init:2:16955)
                                          at Module.require (node:internal/modules/cjs/loader:1318:19)
                                          at require (node:internal/modules/helpers:179:18)
                                          at Class.loadModuleDefaultConfig (/home/mdwebb/MagicMirror/modules/MMM-Remote-Control/node_helper.js:317:30)
                                          at /home/mdwebb/MagicMirror/modules/MMM-Remote-Control/node_helper.js:271:26
                                          at FSReqCallback.oncomplete (node:fs:198:5)
                                      [3636:0120/203657.414249:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [3636:0120/203657.423716:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [3636:0120/203657.424432:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [3636:0120/203657.424789:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [3636:0120/203657.425361:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [3636:0120/203657.425726:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [3636:0120/203657.426131:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [3636:0120/203657.426495:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [3636:0120/203657.431838:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [3636:0120/203657.439567:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [3636:0120/203657.451490:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [3636:0120/203657.455922:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [3636:0120/203657.456469:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [3636:0120/203657.456802:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [3636:0120/203657.458595:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [3636:0120/203657.463710:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [3636:0120/203657.468093:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [3636:0120/203657.471514:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [3636:0120/203657.472361:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [3636:0120/203657.472678:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [3636:0120/203657.473397:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [3636:0120/203657.479438:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [3636:0120/203657.485371:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [3636:0120/203657.485794:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [3636:0120/203657.486390:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [3636:0120/203657.486682:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [3636:0120/203657.487070:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [3636:0120/203657.488116:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [2025-01-20 20:36:58.222] [LOG]
                                      [2025-01-20 20:37:00.003] [LOG]   Config based debug=module_3_MMM-ImagesPhotos
                                      [2025-01-20 20:37:00.008] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/ - Interval: 3600000
                                      [2025-01-20 20:37:00.017] [LOG]   MMM-ModuleScheduler is removing all scheduled jobs
                                      [2025-01-20 20:37:00.018] [LOG]   MMM-ModuleScheduler received CREATE_NOTIFICATION_SCHEDULE
                                      [2025-01-20 20:37:00.021] [LOG]   MMM-ModuleScheduler cannot create schedule. Missing `schedule` in `notification_schedule`: true
                                      [2025-01-20 20:37:00.029] [INFO]  updatenotification: Updater Class Loaded!
                                      [2025-01-20 20:37:00.030] [INFO]  updatenotification: Checking PM2 using...
                                      [2025-01-20 20:37:00.031] [INFO]  updatenotification: [PM2] You are not using pm2
                                      [2025-01-20 20:37:00.033] [INFO]  Checking git for module: MMM-CountDown
                                      [2025-01-20 20:37:00.070] [INFO]  Checking git for module: MMM-ImagesPhotos
                                      [2025-01-20 20:37:00.104] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
                                      [2025-01-20 20:37:00.171] [INFO]  Checking git for module: MMM-Config
                                      [2025-01-20 20:37:00.213] [INFO]  Checking git for module: MMM-CalendarExt3
                                      [2025-01-20 20:37:00.240] [INFO]  Checking git for module: MMM-Remote-Control
                                      [2025-01-20 20:37:00.265] [INFO]  Checking git for module: MMM-ModuleScheduler
                                      [2025-01-20 20:37:00.319] [INFO]  Checking git for module: MagicMirror
                                      [2025-01-20 20:37:05.720] [INFO]  Calendar-Fetcher: Broadcasting 970 events from https://calendar.google.com/calendar/ical...
                                      [2025-01-20 20:37:06.063] [LOG]   Shutting down server...
                                      [2025-01-20 20:37:06.066] [LOG]   Stopping module helper: updatenotification
                                      [2025-01-20 20:37:06.067] [LOG]   Stopping module helper: MMM-ImagesPhotos
                                      [2025-01-20 20:37:06.069] [LOG]   Stopping module helper: MMM-OpenWeatherMapForecast
                                      [2025-01-20 20:37:06.070] [LOG]   Stopping module helper: MMM-Config
                                      [2025-01-20 20:37:06.071] [LOG]   Stopping module helper: calendar
                                      [2025-01-20 20:37:06.076] [LOG]   Stopping module helper: MMM-ModuleScheduler
                                      [2025-01-20 20:37:06.078] [LOG]   Node_helpers stopped ...
                                      Config file
                                        var config = {
                                          address: "0.0.0.0",
                                          port: 8080,
                                          basePath: "/",
                                          ipWhitelist: [
                                            "127.0.0.1",
                                            "::ffff:127.0.0.1",
                                            "::1",
                                            "192.000.00.000",
                                            "192.000.00.00"
                                          language: "en",
                                          locale: "en-US",
                                          logLevel: [
                                            "INFO",
                                            "LOG",
                                            "WARN",
                                            "ERROR"
                                          timeFormat: 24,
                                          units: "metric",
                                          useHttps: false,
                                              module: "updatenotification",
                                              position: "top_bar",
                                              order: "*",
                                              disabled: false,
                                              animateIn: "None",
                                              animateOut: "None",
                                              config: {}
                                              module: "clock",
                                              order: "*",
                                              animateIn: "None",
                                              animateOut: "None",
                                              index: 0,
                                              label: "instance 1",
                                                displayType: "digital",
                                                timeFormat: "24",
                                                displaySeconds: true,
                                                showPeriod: true,
                                                showDate: true,
                                                showTime: true,
                                                dateFormat: "dddd, LL",
                                                analogSize: "200px",
                                                analogFace: "simple",
                                                analogPlacement: "bottom",
                                                analogShowDate: "top",
                                                secondsColor: "#888888",
                                                lat: 47.630539,
                                                lon: -122.344147,
                                                showPeriodUpper: false,
                                                clockBold: false,
                                                showWeek: false,
                                                sendNotifications: false,
                                                showSunTimes: false,
                                                showMoonTimes: false
                                              disabled: false
                                              module: "MMM-CountDown",
                                                date: "2025-02-21",
                                                event: "Webb Holiday"
                                              order: "*",
                                              disabled: false,
                                              animateIn: "None",
                                              animateOut: "None"
                                              module: "MMM-ImagesPhotos",
                                              position: "top_center",
                                                animationSpeed: 1000,
                                                updateInterval: 30000,
                                                maxHeight: "500px",
                                                maxWidth: "500px",
                                                path: ""
                                              order: "*",
                                              disabled: false,
                                              animateIn: "None",
                                              animateOut: "None"
                                              module: "weather",
                                              disabled: true,
                                              order: "*",
                                              index: 0,
                                              animateIn: "none",
                                              animateOut: "none",
                                                weatherProvider: "openmeteo",
                                                type: "current",
                                                units: "metric",
                                                tempUnits: "metric",
                                                windUnits: "metric",
                                                timeFormat: "24",
                                                useBeaufort: true,
                                                lang: "en",
                                                useKmh: false,
                                                showHumidity: false
                                              module: "weather",
                                              disabled: true,
                                              label: "instance 2",
                                              order: "*",
                                              index: 1,
                                              animateIn: "none",
                                              animateOut: "none",
                                                type: "forecast",
                                                units: "metric",
                                                updateInterval: 600000,
                                                timeFormat: "24",
                                                showPeriod: true,
                                                showWindDirection: true,
                                                useBeaufort: true,
                                                lang: "en",
                                                showSun: true,
                                                decimalSymbol: ".",
                                                maxNumberOfDays: 5,
                                                maxEntries: 5,
                                                fade: true,
                                                fadePoint: 0.25,
                                                initialLoadDelay: 0,
                                                appendLocationNameToHeader: true,
                                                calendarClass: "calendar",
                                                tableClass: "small",
                                                showFeelsLike: true,
                                                roundTemp: false,
                                                useKmh: false,
                                                showWindDirectionAsArrow: false,
                                                showHumidity: false,
                                                degreeLabel: false,
                                                showIndoorTemperature: false,
                                                showIndoorHumidity: false,
                                                ignoreToday: false,
                                                onlyTemp: false,
                                                showPrecipitationAmount: false,
                                                colored: false,
                                                absoluteDates: false
                                              module: "MMM-OpenWeatherMapForecast",
                                              header: "Weather",
                                              classes: "default everyone",
                                                apikey: "",
                                                latitude: "-38.314560",
                                                longitude: "146.419373",
                                                iconset: "4c",
                                                concise: false,
                                                forecastLayout: "table",
                                                maxDailiesToShow: 5,
                                                showWind: false,
                                                units: "metric",
                                                language: "en",
                                                showExtraCurrentConditions: false,
                                                showHourlyForecast: false,
                                                forecastHeaderText: ""
                                              order: "*",
                                              disabled: false,
                                              animateIn: "None",
                                              animateOut: "None"
                                              module: "MMM-Config",
                                                restart: "none"
                                              order: "*",
                                              disabled: false,
                                              animateIn: "none",
                                              animateOut: "none"
                                              module: "MMM-CalendarExt3",
                                              position: "bottom_bar",
                                              title: "",
                                                instanceId: "basicCalendar",
                                                locale: "en-US",
                                                maxEventLines: 6,
                                                firstDayOfWeek: "0",
                                                weekIndex: 0,
                                                weeksInView: 4,
                                                eventHeight: "15px",
                                                useMarquee: true,
                                                refreshInterval: 600,
                                                eventTransformer: (ev)=> {
                                        if (ev.title.search('DINNER') > -1) ev.symbol = ['fluent-color:food-28']
                                        if (ev.title.search('Arnold') > -1) ev.symbol = ['fluent-emoji-flat:dog']
                                        if (ev.title.search('Gus') > -1) ev.symbol = ['fluent-emoji-flat:dog']
                                        if (ev.title.search('Dogs') > -1) ev.symbol = ['fluent-emoji-flat:dog']
                                        if (ev.title.search('dogs') > -1) ev.symbol = ['fluent-emoji-flat:dog']
                                        if (ev.title.search('Marcus') > -1) ev.symbol = ['noto:pretzel']
                                        if (ev.title.search('Pretzel') > -1) ev.symbol = ['noto:pretzel']
                                        if (ev.title.search('Recycle Bin') > -1) ev.symbol = ['game-icons:soda-bottle']
                                        if (ev.title.search('Green Waste bins') > -1) ev.symbol = ['streamline-emojis:leaf-fluttering-in-wind']
                                        if (ev.title.search('Cleaning Day') > -1) ev.symbol = ['openmoji:broom']
                                        if (ev.title.search('Swimming') > -1) ev.symbol = ['fxemoji:swimming']
                                        if (ev.title.search('Phils') > -1) ev.symbol = ['twemoji:baby-angel-light-skin-tone']
                                        if (ev.title.search('Phyllis') > -1) ev.symbol = ['twemoji:baby-angel-light-skin-tone']
                                        if (ev.title.search('Birthday') > -1) ev.symbol = ['emojione:birthday-cake']
                                        if (ev.title.search('birthday') > -1) ev.symbol = ['emojione:birthday-cake']
                                        if (ev.title.search('Hugo') > -1) ev.symbol = ['cryptocurrency-color:hight']
                                        if (ev.title.search('Maggie') > -1) ev.symbol = ['cryptocurrency-color:xmy']
                                        if (ev.title.search('Lucas') > -1) ev.symbol = ['openmoji:man-judge-light-skin-tone']
                                        if (ev.title.search('Hudge') > -1) ev.symbol = ['twemoji:gemini']
                                        if (ev.title.search('Danielle') > -1) ev.symbol = ['twemoji:gemini']
                                        if (ev.title.search('Factory') > -1) ev.symbol = ['emojione-v1:cow']
                                        if (ev.title.search('factory') > -1) ev.symbol = ['emojione-v1:cow']
                                        return ev
                                                eventFilter: (ev) =>  {
                                       return true
                                                manipulateDateCell: (cellDom, events) =>  {
                                                weatherPayload: (payload) =>  {
                                       return payload
                                                eventPayload: (payload) =>  {
                                       return payload
                                              order: "*",
                                              disabled: false,
                                              animateIn: "None",
                                              animateOut: "None"
                                              module: "newsfeed",
                                              disabled: true,
                                              order: "*",
                                              animateIn: "None",
                                              animateOut: "None",
                                              index: 0,
                                                feeds: [
                                                    title: "New York Times",
                                                    url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml",
                                                    encoding: "UTF-8"
                                                showSourceTitle: true,
                                                showPublishDate: true,
                                                broadcastNewsFeeds: true,
                                                broadcastNewsUpdates: true,
                                                wrapTitle: true,
                                                wrapDescription: true,
                                                truncDescription: true,
                                                lengthDescription: 400,
                                                reloadInterval: 300000,
                                                updateInterval: 10000,
                                                animationSpeed: 2500,
                                                maxNewsItems: 0,
                                                ignoreOlderThan: 86400000,
                                                scrollLength: 500,
                                                showAsList: false,
                                                showDescription: false,
                                                showTitleAsUrl: false,
                                                hideLoading: false,
                                                ignoreOldItems: false,
                                                logFeedWarnings: false,
                                                dangerouslyDisableAutoEscaping: false,
                                                startTags: [],
                                                endTags: [],
                                                prohibitedWords: []
                                              module: "alert",
                                              order: "*",
                                              animateIn: "None",
                                              animateOut: "None",
                                              index: 0,
                                                effect: "slide",
                                                alert_effect: "jelly",
                                                display_time: 3500,
                                                position: "center",
                                                welcome_message: false
                                              disabled: false
                                              order: "*",
                                              animateIn: "None",
                                              animateOut: "None",
                                              index: 0,
                                                maximumEntries: 10,
                                                maximumNumberOfDays: 365,
                                                limitDays: 0,
                                                pastDaysCount: 0,
                                                displaySymbol: true,
                                                defaultSymbol: "calendar-alt",
                                                defaultSymbolClassName: "fas fa-fw fa-",
                                                maxTitleLength: 25,
                                                maxLocationTitleLength: 25,
                                                maxTitleLines: 3,
                                                maxEventTitleLines: 3,
                                                fetchInterval: 3600000,
                                                animationSpeed: 2000,
                                                fade: true,
                                                fadePoint: 0.25,
                                                urgency: 7,
                                                timeFormat: "relative",
                                                dateFormat: "MMM Do",
                                                dateEndFormat: "LT",
                                                fullDayEventDateFormat: "MMM Do",
                                                getRelative: 6,
                                                hideDuplicates: true,
                                                    symbol: "calendar-alt",
                                                    url: "https://calendar.google.com/calendar/ical/
                                                customEvents: [
                                                    keyword: ".*",
                                                    transform: {
                                                      search: "De verjaardag van "
                                                    keyword: ".*",
                                                    transform: {
                                                      search: "'s birthday"
                                                locationTitleReplace: {
                                                  "street ": ""
                                                broadcastEvents: true,
                                                broadcastPastEvents: true,
                                                updateOnFetch: true,
                                                showLocation: false,
                                                displayRepeatingCountTitle: false,
                                                wrapEvents: false,
                                                wrapLocationEvents: false,
                                                showEnd: false,
                                                showEndsOnlyWithDuration: false,
                                                hidePrivate: false,
                                                hideOngoing: false,
                                                hideTime: false,
                                                showTimeToday: false,
                                                colored: false,
                                                forceUseCurrentTime: false,
                                                sliceMultiDayEvents: false,
                                                nextDaysRelative: false,
                                                selfSignedCert: false,
                                                coloredText: false,
                                                coloredBorder: false,
                                                coloredSymbol: false,
                                                coloredBackground: false,
                                                limitDaysNeverSkip: false,
                                                flipDateHeaderTitle: false,
                                                excludedEvents: []
                                              disabled: false
                                              module: "MMM-Remote-Control",
                                                apiKey: ""
                                              order: "*",
                                              disabled: false,
                                              animateIn: "None",
                                              animateOut: "None"
                                              module: "MMM-ModuleScheduler",
                                                notification_schedule: true
                                              order: "*",
                                              disabled: false,
                                              animateIn: "None",
                                              animateOut: "None"
                                      S M 4 Replies Last reply
                                        sdetweil @MDWEBB
                                        @MDWEBB hm, could not validate file…
                                        edit: ---- you said you reinstalled, so this is not a file corruption problem
                                        lets go to the MMM-CalendarExt3 folder
                                        and do
                                        git status
                                        it should not list any files
                                        please show the reults
                                          sdetweil @MDWEBB
                                          @MDWEBB also you changed refreshInterval to 600
                                          milliseconds down from 30 minutes!! (the module cannot redraw that fast)
                                          i think you need to change the waitFetch value up to 10000
                                          milliseconds.
                                          i don’t think refreshInterval should ever be less that 300000
                                          (5 minutes)
                                            @MDWEBB I could not recreate the error by setting one of my Ext3 instances to refreshInterval :600
